RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 12th Apr 2006, 15:16   #1
WilHarris
Just another nobody
WilHarris's Avatar
WilHarris is on a distinguished road
Matrox Triplehead2Go
http://www.bit-tech.net/hardware/200...ad_2_go/1.html
WilHarris is offline   Reply With Quote
Old 12th Apr 2006, 15:23   #2
rupbert
Hypermodder
rupbert's Avatar
rupbert is on a distinguished road
Need!
rupbert is offline   Reply With Quote
Old 12th Apr 2006, 15:53   #3
Drexial
Supermodder
Drexial is on a distinguished road
doesnt ATi in crossfire suport using the other DVI connections for multiple displays like this?
Drexial is offline   Reply With Quote
Old 12th Apr 2006, 16:13   #4
LogicalJester
Multimodder
LogicalJester is on a distinguished road
OK, perhaps you could get one of these in for review as a comparison?
http://216.127.51.88/monitors/athens/features/index.htm
Then when you are done, they probably won't want it back, so you could just pop it in the post to me?
LogicalJester is offline   Reply With Quote
Old 12th Apr 2006, 16:22   #5
Cobalt
Multimodder
Cobalt is on a distinguished road
@ Logical: Those monitors don't exist. the company went bust although for some reason they kept their site running.
If SLI can already support three monitors though DVI then what is the actual benefit of this? Especially if it doesn't work with xfire. The only use I can see is for professionals who want larger desktop space (eg. for image editing) when they only have one gfx card. If I ever get xfire or SLI I'm just likly to play in the three monitors to the gfx cards directly.
Cobalt is offline   Reply With Quote
Old 12th Apr 2006, 16:31   #6
fantastic dan
Supermodder
fantastic dan is on a distinguished road
Although it's an option i can't see how this product is designed for it. Surely it's purpose is for people that carry a laptop about but want multiple monitors for work.
fantastic dan is offline   Reply With Quote
Old 12th Apr 2006, 16:31   #7
BioSniper
I Mod, Therefore I Own
BioSniper's Avatar
BioSniper has a spectacular aura aboutBioSniper has a spectacular aura about
being super picky here, is it me or do the oblivion gates in your screens have some seriously weird diagonal artifacting?
__________________
My Flickr :: Bit-tech Flickr
Wii: 1792 1527 2926 7945 :: Xbox Live: BioSnipr :: PSN: Biosnipr
BioSniper is offline   Reply With Quote
Old 12th Apr 2006, 17:27   #8
Lovah
Apple and Canon fanboy
Lovah's Avatar
Lovah is on a distinguished road
Very nice, just like the two monitor option. Too bad that it, just like the two monitor option, only supports identical monitors (resolution wise). So I can't use my old 17" LCD with my new 20" LCD..
L
__________________
MacBook Pro 15" | 20" Dell 2005FPW | iPod Touch 16GB
Canon 400D + BG-E3 | RS-60E3
EF-s 10-22mm F3.5-4.5 | EF 17-40mm F4 L | EF 50mm F1.4 | EF 70-200mm F4 L
Manfrotto 190ProB + 486RC2 | LumoPro LP604 | Canon 430EX + OC-E2 | Nikon SB-26*2 | PocketWizard Plus II*3
Lovah is offline   Reply With Quote
Old 12th Apr 2006, 18:37   #9
Firehed
Why not? I own a domain to match.
Firehed's Avatar
Firehed has a spectacular aura aboutFirehed has a spectacular aura aboutFirehed has a spectacular aura about
I'll assume that frame from Oblivion is the only one produced in a minute, at that resolution.
As to the SLi comment towards the end - have nVidia finally changed their drivers so you can properly mix SLi and multiple displays? Last I knew, you still had to software-disable SLi mode to have more than one display socket put out anything, and I'd assumed there'd have been a decent commotion if that was finally fixed.
Still, very cool idea, but I'll stick with my 2405fpw/2005fpw combo. It's nice to have the game running on the big screen with all my perfmons and FAQs open on the other I pwn alt-tab. I definately need a 7900gt now seeing how most games hold up in 1920x1200 - even CSS/HL2 can get a bit choppy from time to time, and I'm barely able to squeeze 1680x1050 out of my 6800gt in Oblivion with almost all the eye candy turned off.
I'm waiting for the 6x24" model. 360-degree FOV completely surrounding your head. Could make for a pretty awkward desk.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net
40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8
MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD
Firehed is offline   Reply With Quote
Old 12th Apr 2006, 18:48   #10
korhojoa
Multimodder
korhojoa is on a distinguished road
I have the best idea ever.
Use three displays. Connect them up via vga to the triplehead 2 go, and then connect the dvi inputs to the regular inputs. Use as normal displays thru dvi when working with windows, and switch over to the vga triplehead when gaming. win-win!
__________________
the world is not enough, i gotta have modding too.
korhojoa is offline   Reply With Quote
Old 12th Apr 2006, 19:08   #11
yahooadam
Ultra csavarkulcs
Banned
yahooadam's Avatar
yahooadam is on a distinguished road
Yeh i was going to say, as far as i know SLI doesnt support more then a single moniter
you have to disable SLI (reverting to multiple GFX cards) to get up to 4 displays
yahooadam is offline   Reply With Quote
Old 12th Apr 2006, 19:33   #12
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
The three screens equate to one display (as far as the NVIDIA driver is concerned) with the Triplehead2Go
Tim S is offline   Reply With Quote
Old 12th Apr 2006, 19:45   #13
Lionheart
What's a Dremel?
Lionheart is on a distinguished road
So if im running 2 7900GTX in SLI with 3 monitors do i even need to buy that or can the same thing be done thorugh SLI?
Lionheart is offline   Reply With Quote
Old 12th Apr 2006, 19:50   #14
sl1xx
Multimodder
sl1xx is on a distinguished road
is this only recommended with the nvidia geforce 7 series ?
sl1xx is offline   Reply With Quote
Old 12th Apr 2006, 20:02   #15
Kameleon
is watching you...
Kameleon's Avatar
Kameleon is on a distinguished road
This is my thinking. SLI = lots of monitors anyway, what's the point of this? If it had come out when SLI was still limited to 1 monitor (whatever happened with that, anyway?) it would have sold like hotcakes, though.
Kameleon is offline   Reply With Quote
Old 12th Apr 2006, 20:03   #16
yahooadam
Ultra csavarkulcs
Banned
yahooadam's Avatar
as far as i know you cannot run 3 moniters with your GFX cards in SLI mode
Edit
the above post would seem to prove me wrong, hiowever, have they fixed the problem ??
Old 12th Apr 2006, 20:08   #17
Kameleon
is watching you...
Kameleon's Avatar
I didn't know they had, but then I've been out of the ultra-high end GFX scene for a few months now and might've missed it. The article would seem to suggest it's been fixed, though...
"If you're running SLI in your machine, you can already connect up three monitors digitally and arrange them using the NVIDIA desktop tool, so you're going to be getting better image quality without having to stump up for an extra box."
Old 12th Apr 2006, 20:10   #18
Lionheart
What's a Dremel?
Thats what i thought.
Old 12th Apr 2006, 20:13   #19
yahooadam
Ultra csavarkulcs
Banned
yahooadam's Avatar
well Bit-tech have the SLI 7900's and 3 screens
perhaps they could answer this question ....
Old 12th Apr 2006, 20:21   #20
DeX
Mube Codder
DeX's Avatar
DeX is on a distinguished road
Isn't it slightly annoying having to look at you health all the way in the bottom-left corner of the left screen and your ammo all the way in the bottom-right corner of the right screen?
I think you should have some actual 'value' points to your review rather than just 'ooh that looks nice' points. Let's have some average number of kills in CSS with and without 3 screens.
__________________
Play my game: Shyguy's Cave of Death!
If you dont have the time to check your spelling and grammar, you dont have the time to post! -Liquid K9
DeX is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
