Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 17th Apr 2006, 16:52   #1
ou7blaze
sensational.
ou7blaze's Avatar
ou7blaze has yet to learn the way of the Dremel
Weird yet annoying message!
EDIT: sry forgot to type what the problem is LOL.
I can't get onto MSN at all, it passes all the tests and yet won't let me log on.
Later, I find out that Zonealarm is the source of the problem, basically it somehow became corrupted and to protect me the user it disabled a port I guess and didn't let IE (at first) and now MSN to run, yet allowing me to connect to the Internet of course.
However it's really getting to me since I can't uninstall or reinstall Zonealarm because I keep getting the following message whatever I try to do:
Code:
Validation failed for C:\windows\system32\vsinit.dll
You are probably missing a necessary root certificate.
__________________
Originally Posted by Greeneyedguy
advice to all u masturbators...
its a good idea to keep a pringles can with the bottom cut out next to u so u can put it over ur wang when ur parents come and tell em u were enjoyong some delicious low-fat potato chips...
ou7blaze is offline   Reply With Quote
Old 17th Apr 2006, 20:24   #2
ou7blaze
sensational.
ou7blaze's Avatar
Update on the problem.
Whilst trying to reinstall/install, however you want to put it I now get this following message:
Code:
Setup is unable to log into the TrueVector service.
Install cannot conitnue without logging into the TrueVector service.
Please use the service manager to shut down the TrueVector service
and then restart the installer program.
__________________
Old 18th Apr 2006, 17:10   #3
AJB2K3
I *am* a Dremel
AJB2K3's Avatar
AJB2K3 has yet to learn the way of the Dremel
isn't truevector to do with avg?
__________________
4 Men went to mow, Went to mow a meadow,
AJB2K3 is offline   Reply With Quote
Old 18th Apr 2006, 17:30   #4
furqan
Supermodder
furqan's Avatar
furqan has yet to learn the way of the Dremel
it's to do with zonealarm afaik
__________________
H2O FTW
AMD Opteron 146 | 1GB Corsair XMS3700PT | Asus A8N Sli | Powercolor X800XL
£££ Click here if you dare!!! £££
furqan is offline   Reply With Quote
Old 18th Apr 2006, 17:39   #5
fev
Industry Fallout
fev's Avatar
fev - it's over 9000!!!!!!!!1!1!1!!!fev - it's over 9000!!!!!!!!1!1!1!!!fev - it's over 9000!!!!!!!!1!1!1!!!fev - it's over 9000!!!!!!!!1!1!1!!!fev - it's over 9000!!!!!!!!1!1!1!!!fev - it's over 9000!!!!!!!!1!1!1!!!fev - it's over 9000!!!!!!!!1!1!1!!!fev - it's over 9000!!!!!!!!1!1!1!!!fev - it's over 9000!!!!!!!!1!1!1!!!fev - it's over 9000!!!!!!!!1!1!1!!!fev - it's over 9000!!!!!!!!1!1!1!!!
you need to enter zee password you set during setup.. usually done by popping up the settings dialogue
__________________
I know what I'm doing, do you?
Follow me on Twitter..go on
fev is offline   Reply With Quote
Old 19th Apr 2006, 00:44   #6
Cirkustanz
Minimodder
Cirkustanz has yet to learn the way of the Dremel
This is a very common problem that I've seen, and a microsoft article can provide you with information on fixing it. (look for the link detailing how to manually and completely uninstall zonealarm)
http://support.microsoft.com/?kbid=291793
I had to do this to my girlfriends computer once, and I did end up having to use the search tool in regedit for all references to zonealarm.........be sure to export your registry before you do that if you're not confident.
It is my personal opinion that the scenario is a result of zonealarms really piss-poor job of the firewall program trying to "protect itself".
She bought a new router, and no longer needs a software based firewall now.
__________________
SanDiego 3700+, BFG 7800GToc, Asus A8nSliPremium
Cirkustanz is offline   Reply With Quote
Old 19th Apr 2006, 07:33   #7
ou7blaze
sensational.
ou7blaze's Avatar
OMG, thanks alot you're a life saver I was just considering whether or not to reformat my computer this morning seeing as there was little to no supplies and all the searches on Google i've done for peope with the same problem led me to nowhere.
I hope this works, thanks anyways.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
