#1 |
Supermodder
messenger with video function
lo all
would like to use my built in isight on my MBP to video chat with my wife abroad. was wondering what software u guys would recommend? i know that msn for mac doesnt have video support. thanks for any help |
#2 |
theorycrafting
If your wife is also sported with an Apple, than simply use iChat. Otherwise you can use the Skype, which supports also Video (Version 2.x).
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB] |
#3 |
Multimodder
Only seems to be http://www.mercury.to/ that you can use video over MSN. Skype is only upto 1.4 on Mac =/
#4 |
Supermodder
nope...sorry, should have mentioned. she's on a windows machine.
was just looking at skype. might that a try. thanks Tarff, will look into that too. 1.4? |
#5 | |
Ultramodder
#6 |
Supermodder
what about AIM (AOL INSTANT MESSENGER?)
#7 |
bondage master!
newest version of AIM does not work on a MBP as it doesn't have a PPC processor (or at least I have issues getting it to work)
iChat would be my first choice, but since you wife lacks a mac, it makes it not feasible. i'm not to familiar with all the annoying other messengers (I tend to use iChat in mac and gaim on windows or linux) other options include loading windows onto a small partition on your MBP specifically so you can run MSN etc (i believe boot camp provides a driver for iSight, but don't take me on that one, as I've not played with it) or buying your wife a powerbook, or mac mini
__________________
Portable: 15" Unibody MacBook Pro, C2D 2.4GHz/4GB/500GB Handhelds: iPhone 8GB |
| Tags |
| apple |
| Thread Tools | |
