RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 21st Apr 2006, 15:30   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
DFI LANParty UT CFX3200-DR
http://www.bit-tech.net/hardware/200...3200-dr/1.html
Tim S is offline   Reply With Quote
Old 21st Apr 2006, 16:01   #2
RotoSequence
Lazy Lurker
RotoSequence's Avatar
RotoSequence is on a distinguished road
Woohoo, nice to see DFI has got it right again. Sweetness
__________________
Technology Schmecnology
RotoSequence is offline   Reply With Quote
Old 21st Apr 2006, 16:10   #3
teamtd11
I *am* a Dremel
teamtd11's Avatar
teamtd11 will become famous soon enoughteamtd11 will become famous soon enough
wow . got to start saving.
__________________
Main: AMD X2 3ghz, x1900xt, DFI NF590SLI, 4gb pc2-8500 [Watercooled]
Retro: AMD Barton 2ghz, 9600xt, 512mb pc-2700
Animal Crossing: LGTTC - 2492-7863-6464
Member of CK Appreciation Society Group
teamtd11 is offline   Reply With Quote
Old 21st Apr 2006, 16:58   #4
Buzzons
Mod Master
Buzzons is on a distinguished road
question : why do all these boards now have like 8 SATA ports -- most cases can only hold 4 harddisks and most users only want 2 DVD drivers. Seein as these are aimed at gamers etc, its not like they will be havin huge RAID5 arrays etc or mamouth amounts of storage space.
Also, why 2 NICs, I have never worked that out either. Surly they could remove some of this stuff and make the board cheeper // more spaced out // more other features.
Buzzons is offline   Reply With Quote
Old 21st Apr 2006, 17:02   #5
RotoSequence
Lazy Lurker
A lot of people around here have hard drives out the wazoo-and a fair number of them actually do use RAID because their data is valuable to them. Its fair to provide it. And honestly, a case that holds 4 hard disks is a cheap piece of junk or a small one IMHO.
__________________
Old 21st Apr 2006, 17:40   #6
teamtd11
I *am* a Dremel
teamtd11's Avatar
my case can hold 9hdd's. and i had 3 dvd rom drives (till 1 broke) the more the merryer!!! :P
and you want more features. but you want to remove some *confused*
__________________
Old 21st Apr 2006, 20:27   #7
1e8o
Supermodder
1e8o's Avatar
1e8o is on a distinguished road
Nice MB, I'll consider it when I buy a new pc (If I have the money :P).
DFI keep up the good work
__________________
NEW!!! X2 4200+| 2 x XFX Geforce 6600 gt in SLI | Asus A8N-SLI Deluxe | 4 x hitachi 250 gb sata hdd + Maxtor 160 usb 2.0 total of 1160 GB | 2 x 1024 MB DDR-400 (2 GB ) | Tagan U force 580 Watt | Saving money for an macbook and an Iphone (2nd edition)
1e8o is offline   Reply With Quote
Old 22nd Apr 2006, 01:09   #8
specofdust
Banned
specofdust's Avatar
specofdust has a spectacular aura aboutspecofdust has a spectacular aura about
Yup, they could remove some of the stuff, but they're trying to appeal to a wide market, and at the high end of the mobo market, the money saved on missing out an extra NIC or using one less SATA controller wouldn't swing many people towards the mobo, but might put quite a few off due a competitors high end mobo having more SATA ports of Ethernet ports. As for the idea that gamers don't have lots of data, I think thats very far off. PC gamers tend to be general techies, who have the internet, and many are going to have very large collections of media.
specofdust is online now   Reply With Quote
Old 22nd Apr 2006, 01:33   #9
webchimp
Supermodder
webchimp's Avatar
webchimp is on a distinguished road
With AMD Socket M2 just a few months away, is it wise to buy socket 939 motherboard or processor at the moment, especially top of the range stuff?
I'm still using a socket A Athlon XP and I've been putting off upgrading for quite a while, so I may as well hold on for a little longer, skip socket 939 altogether and go straight to M2.
webchimp is offline   Reply With Quote
Old 22nd Apr 2006, 01:41   #10
specofdust
Banned
specofdust's Avatar
I think hanging around for M2 is still a bad idea. Being an early adopter sucks, it costs too much, the tech is generally buggy, and speed benefits are often questionable. The time to really think "should I hold on for M2" is once the first gen crap is released, thens the time to start evaluating whether M2 is going to be decent and cheap enough to warrent waiting a while, or whether 939 is still king.
Old 22nd Apr 2006, 02:33   #11
webchimp
Supermodder
webchimp's Avatar
I agree, it's probably not best to get the first M2 processors and motherboards off the production lines, but hold on for a couple of months after that. However, socket 939 will be a dead end once socket M2 gets underway and as I've managed with Socket A up until now, holding on for another 3, 4 or even 5 months won't hurt.
If I'm honest my ageing XP 2600 does everything I "need" to just fine. It's only really some later games where it's showing it's age and that's partly down to my middling graphics card. I've held off upgrading the AGP graphics card as when I finally do get a newer motherboard it will be PCI Express and I will have to get a new graphics card anyway. Socket M2 will also need DDR2 memory, so this is going to be quite an expensive upgrade when I finally do it.
Old 22nd Apr 2006, 13:39   #12
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
AM2 also doesn't provide much of a benefit at the moment based on the benchmarks that are already out there... if you're looking to stick with DDR for the time being, this board is likely to be worth your pennies.
Old 22nd Apr 2006, 15:44   #13
LoveJoy
Modder
LoveJoy is on a distinguished road
eer why is DFI striping all the features from their packages like here http://us.dfi.com.tw/Product/xx_prod...YPE=LP&SITE=US
that enqludes everything you might possibly need and more, but now they only give you a few s-ata cabels, IDE-cabels and some more
LoveJoy is offline   Reply With Quote
Old 22nd Apr 2006, 15:49   #14
Callum
Supermodder
Callum's Avatar
Callum is on a distinguished road
Am I right in taking from this the impression that this Crossfire board is a better board than the SLI board?
Callum is offline   Reply With Quote
Old 22nd Apr 2006, 16:25   #15
Firehed
Why not? I own a domain to match.
Firehed's Avatar
Firehed has a spectacular aura aboutFirehed has a spectacular aura aboutFirehed has a spectacular aura about
I've gotta agree - the stock version of my case holds a dozen, and the smaller version holds six. My cheap fileserver case holds five plus a couple more in floppy bays, and is a reasonably small case.
Starting the article with "for the win"? Oh the hypocicy...
Looks like a nice board though, however set I am with mine for now.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net
40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8
MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD
Firehed is offline   Reply With Quote
Old 22nd Apr 2006, 17:23   #16
webchimp
Supermodder
webchimp's Avatar
It's not so much of a case of wanting extra performance from the AM2 socket as not wanting to buy a premium priced motherboard which in a few months will be obslolete. I believe that once socket AM2 hits the market no new socket 939 CPUs will be developed, which means that there will be limited potential for futute CPU upgrades.
In addition, even if you were considering socket 939, we may see some price reductions in a few months when socket AM2 is released. Either way, I think now is a bad time to buy a socket 939 motherboard or CPU, unless of course your current PC has failed and you absolutely need a replacement immediately.
Old 22nd Apr 2006, 23:55   #17
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
It depends how often you're looking to upgrade - this board isn't for people who've not already got a socket 939 system. If you're using something other than a socket 939 Athlon 64, this board isn't for you and you may as well wait for AM2.
However, people don't want to upgrade from AGP because it means they've got to buy a new motherboard and a new graphics card. If you've got a socket 939 chip and want to upgrade to AM2, you're going to have to buy new memory, a new motherboard, a new CPU and if you're an AGP user, you're going to have to buy a new graphics card too.
The performance difference that is seen between AM2 and S939 isn't something that is worth shelling out all of your hard earned cash for if you've got a S939 system already... I'd say that it is those people that are likely to be in the hunt or a new motherboard like this.
Old 22nd Apr 2006, 23:59   #18
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Hi & welcome to the forums.
There are two different types of bundle under the LANParty series. LANParty is all bells, all whistles and LANParty UT comes with a cut down bundle... Hope that helps.
Old 23rd Apr 2006, 00:02   #19
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Depends what you're looking for. Choose your graphics platform first and then look at the mobo - I use an nF4 SLI-DR in my own system, but I'm running NVIDIA graphics at the moment. If I was using ATI graphics and wanted to run CrossFire, I'd choose this board above any other CrossFire-capable board out there.
Old 23rd Apr 2006, 00:27   #20
chemo
True Jungle Brother
chemo's Avatar
chemo is on a distinguished road
im very glad to see that DFI has now changed the layout of the NB location and the pcie gfx slots. looks like you can use a pretty decent cooler on the chipset now
__________________
Don't hate the Geek, Hate the code!
chemo is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
