Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 7th May 2006, 18:09   #1
jbehmoaras
Modder
jbehmoaras has yet to learn the way of the Dremel
Dual Monitor vs. One Large Monitor
So I'm thinking of creating this new set-up in my room.
I wanted to have one large LCD TV in the 32" range and have a dual monitor set-up on my computer. The LCD TV and my computer would be connected if I wanted to play media from my computer and the LCD TV would also be connected to a cable feed.
But I have a question regarding the dual monitor portion. Is there any way to get a larger screen that works like a dual monitor without the divider in the middle. I'm assuming that most large LCD's cant do this because they dont have resolutions larger than 1300 or whatever. Is this a true assumption?
Otherwise Id rather have one widescreen that works like two monitors in one rather than having two seperate monitors for my comp. Is there any way to make this possible?
jbehmoaras is offline   Reply With Quote
Old 8th May 2006, 09:25   #2
Atomic
Gerwaff
Atomic's Avatar
Atomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming Saiyan
LCD TVs have way lower resolutions than their PC Monitor counterparts.
My advice is just to keep TVs away from normal PC use, showing media on them is fine though.
You can buy Widescreen monitors, but i dont understand why youd want to make it act like two seperate monitors?
__________________
:: ASUS Maximus IV GENE-Z :: i5 2500K @ 4GHz :: 16GB Corsair Vengeance :: 256GB Samsung 830 ::
:: Awesome, Reliable Website & Server Hosting ::
Atomic is offline   Reply With Quote
Old 9th May 2006, 05:34   #3
jbehmoaras
Modder
well is there any way to have a dual monitor setup without two monitors, in other words, one large widescreen monitor with the resolution of two monitors side by side so that theer is no divider in the middle.
Old 9th May 2006, 09:06   #4
Atomic
Gerwaff
Atomic's Avatar
A widescreen monitor is widescreen... so the resolution will be wider than a normal monitor anyway.
Do you want a monitor that is 8:3 but in a single monitor?
I really dont understand what you on about except for that?
__________________
Old 9th May 2006, 12:40   #5
adam197
Supermodder
adam197 has yet to learn the way of the Dremel
The resolution isnt a software thing. Its restricted by the actual display. You cant have a higher resolution than the optimum resolution of the display. The aspect ratio wouldnt work anyway, as (if you could do it) you would have a 8:3 ratio.
For others: As far as I can tell he is trying to have twice the real estate on one monitor. Such as having 2 x 1024x768 work areas side by side on a single widescreen monitor.
adam197 is offline   Reply With Quote
Old 9th May 2006, 14:54   #6
jbehmoaras
Modder
you see dual monitor are obviously 2 seperate monitors as a result the two screens arent seamless as there is a divide in the middle of the screen that results from having two seperaet monitors. Is there any way to have one big wide monitor that have the funtionality of two monitors so you have a large workspace.
Old 9th May 2006, 15:37   #7
Atomic
Gerwaff
Atomic's Avatar
yes a widescreen monitor like you said in your post
(ive put it in aspect ratio not resolution as the numbers make more sence)
dual monitors is two 4:3 screens together (8:3 to make it easy)
widescreen = 16:9
NO MANUFACTURERS make 8:3 screens without a divide in the middle as it isnt a display standard.
Dual monitors or widescreen, thats you only choice.
__________________
Old 9th May 2006, 15:42   #8
jbehmoaras
Modder
I apreciate the smart comment which was clearly made by someone who doesnt know much about monitors. If you go to a store to purchase a wall screen, it will not double the width of the resolution so you can have two monitors in one and they generally top out in 1300's im asking if anyone knows of a monitor in the 2500 width range
Old 9th May 2006, 15:43   #9
Atomic
Gerwaff
Atomic's Avatar
did you not read my post?
__________________
Old 9th May 2006, 15:43   #10
gbeeby
Supermodder
gbeeby's Avatar
gbeeby has yet to learn the way of the Dremel
i have seen monitors that have a very small frame around them, so smaller divider in the middle
but if your like me it will still bug you
__________________
Main rig - dell axim X30
gbeeby is offline   Reply With Quote
Old 9th May 2006, 15:46   #11
jbehmoaras
Modder
atomic its ok you obviously dont know too much about monitors, and gbeeby have you found a solution to this problem anywhere
Old 9th May 2006, 16:05   #12
Atomic
Gerwaff
Atomic's Avatar
I do know about monitors. You are getting monitors and TVs confused.
TVs generally go upto about 1366x768, whilst a Computer monitor will go much higher.
The 30" Dell for instance will do 2560x1600.
__________________
Old 9th May 2006, 16:13   #13
Atomic
Gerwaff
Atomic's Avatar
Just to show I do know what im on about, I run dual 19" monitors at work and a widescreen at home (i prefer it over duals)
__________________
Old 9th May 2006, 16:13   #14
jbehmoaras
Modder
I wish you had clarifyied that earlier because i have been looking for large computer monitors that still do not increase their resolution but im glad you pointed out one that did
Old 9th May 2006, 16:34   #15
Atomic
Gerwaff
Atomic's Avatar
Widescreen monitor resolutions:
20" - 1680x1050
24" - 1920x1200
30" - 2560x1600
The Dell 2405FPW (24") is a great display if you cant quite afford the beastie that is the 30"!
Im upgrading my 2005FPW to the 2405 soon for the extra resolution.
ps.
__________________
Old 9th May 2006, 22:57   #16
Da_BaCoN
Ultramodder
Da_BaCoN's Avatar
Da_BaCoN has yet to learn the way of the Dremel
*pats Atmoic on the back*
It's ok - I understood you at least
__________________
/me baaaaarfs all over the thread
Da_BaCoN is offline   Reply With Quote
Old 10th May 2006, 08:56   #17
Atomic
Gerwaff
Atomic's Avatar
Phew wasnt me just being an invalid!
__________________
Old 12th May 2006, 12:27   #18
dullonien
Master of the unfinished.
dullonien's Avatar
dullonien is a Super Spamming Saiyandullonien is a Super Spamming Saiyandullonien is a Super Spamming Saiyandullonien is a Super Spamming Saiyandullonien is a Super Spamming Saiyandullonien is a Super Spamming Saiyandullonien is a Super Spamming Saiyandullonien is a Super Spamming Saiyandullonien is a Super Spamming Saiyandullonien is a Super Spamming Saiyandullonien is a Super Spamming Saiyan
Urm, unfortunately jbehmoaras, u are making no sense atall in what u are asking. Atomic has pointed out all your options, and yet u still say that he knows nothing. All u have to do is listen to atomic, he obviouly knows alot more than you about this topic.
As Atomic has pointed out it is impossible to get 1 widescren monitor that matches exactly with 2x15"/17"/19" monitors.
__________________
Main SilverStone FT03B | Intel i5 2500K@4.0GHz | Corsair H70 | Maximus IV Gene-Z | 16GB DDR3 | Zotac GTX 470 | Corsair HX520 | 500GB HDD | 2 x HP ZR24W Monitors |
Server
Fractal Design Define R5 | Intel Core 2 Quad Q6600 | Corsair H50 | EVGA 680i SLI | 8GB DDR2 | Sapphire HD4870 | Corsair AX750 | HighPoint RocketRAID 2680SGL | 8 x 1.5TB HDD's in RAID5 | 1TB HDD | 500GB HDD |
dullonien is offline   Reply With Quote
Old 5th Jun 2006, 22:26   #19
hllywood14
What's a Dremel?
hllywood14 has yet to learn the way of the Dremel
as someone that used to work for DELL dare I speak the name all monitors are made and then housed in a dell case..mainly face plate..if you search well you can find a monitor with the same spec..that is alot cheaper...just my 2 cents.
hllywood14 is offline   Reply With Quote
Old 6th Jun 2006, 07:31   #20
Pookeyhead
It's big, and it's clever.
Pookeyhead's Avatar
Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.
20" - 1680x1050
24" - 1920x1200
30" - 2560x1600
ps.
tbh.. i could afford the 30, but chose the 24. It's too big for a desktop. Sitting at desktop distances the viewing angle difference between looking at one side then back to centre is so great, you actually see a difference in brightness. In order to get around this, you have to sit sao far away as make the whole point of having a big monitor redundant. Plus.. most people's desks dont allow you to place it far enough back.
2504 is ideal for desktop use, and I much prefer it over dual monitor set ups. If you game, duals are crap anyway, cos your cross hairs are hidden by the monitor bezles, and if you only use one for gaming, what's the point?
__________________
MAIN RIG |Intel i7 3960X @ 4.7GHz ¦¦ H105 ¦¦ Asus Rampage IV Extreme ¦¦ 16Gb Mushkin DDR3 2133 ¦¦ 512GB Samsung 830 SSD ¦¦ 4TB of HDD Storage ¦¦ EVGA GTX980 Super-Clocked¦¦ Corsair 650D ¦¦ Eizo ColorEdge CG303W & Dell 2007FP ¦¦
EARTH| Celeron E3200 ¦¦ Gigabyte G31M-ES2L ¦¦ LSI SAS9260-8i ¦¦ 3TB RAID5 ¦¦ Headless - VNC administered
MOON | Thecus N3200pro 3TB RAID5
Pookeyhead is offline   Reply With Quote
Reply
Tags
htpc
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
