Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 7th Jun 2006, 07:14   #1
saxman
Multimodder
saxman has yet to learn the way of the Dremel
RCA to computer monitor
I have been looking for a good way to hook up standard RCA from a VCR or gaming system into a computer monitor. I have been thinking of buying a tuner card but not wanting to go through the computer. You guys have any ideas
saxman is offline   Reply With Quote
Old 7th Jun 2006, 08:05   #2
geek1017
Hypermodder
geek1017's Avatar
geek1017 has yet to learn the way of the Dremel
afaik going direct from a VCR or other video source to a monitor (CRT) is fairly impossible. You can find cheap cards that give you composite input.
Sound will most likely need to be changed from RCA to 1/8" jack via a common converter cable.
I had my VCR hooked up this way into a capture card to record some old VHS onto my hdd but with some software it can also just display on your monitor.
__________________
Thought I'd put something here.
Apparently I'm 47.53452% geek
I expected more
geek1017 is offline   Reply With Quote
Old 7th Jun 2006, 09:52   #3
ozstrike
yip yip yip yip
ozstrike has yet to learn the way of the Dremelozstrike has yet to learn the way of the Dremel
This could work.
__________________
Last.FM | Flickr | Enter the POTM! | Blog
ozstrike is offline   Reply With Quote
Old 7th Jun 2006, 10:18   #4
DougEdey
I pwn all your storage
DougEdey's Avatar
DougEdey has yet to learn the way of the DremelDougEdey has yet to learn the way of the DremelDougEdey has yet to learn the way of the DremelDougEdey has yet to learn the way of the Dremel
There are literally loads of variations on what ozstriker reccomends.
Check places like lik-sang for ones reccomended for gaming. I took a cheap option and iot was atrocious.
DougEdey is offline   Reply With Quote
Old 7th Jun 2006, 14:14   #5
geek1017
Hypermodder
geek1017's Avatar
Well, I stand corrected then.
Those are probably a better solution than a TV card even at about the same price.
PC cards tend to have lag when used for game consoles.
I completely forgot about these sort of aftermarket devices.
__________________
I expected more
Old 8th Jun 2006, 04:46   #6
saxman
Multimodder
Ok so there are cards out there. I figured there was a way wo make a cable to do the job. But i think a wile and remember that VGA is a coaxial wire and hard to work with. Say I was just after TV on my monitor then the best way would just be a tuner card. any recomendations. I am on a fairly tight budget. Still after a solution to the first Q though. The sound I would take down to a 1/8" cable via a converter cable.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
