Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
nForce 590 SLI: Foxconn C51XEM2AA
__________________
#2 |
I have a dremel.
Apart from the close proximity of the memory slots/cpu, it looks pretty cool. Did the nvidia reference have them so close?
#3 |
Pewlius Caesar
bit-tech Staff
It basically is the NV reference design.
__________________
#4 |
Lazy Lurker
Swanky. Id use it in a mod simply because its all black. We need more motherboards like this; simple, unobtrusive, and good performers.
__________________
Technology Schmecnology Last edited by RotoSequence; 14th Jun 2006 at 16:40. |
| RotoSequence |
| View Public Profile |
| Find More Posts by RotoSequence |
#5 |
Supermodder
Absolutely agree. This board is looking pretty awesome. If Foxconn were willing to bring out a revision to fix these *minor* glitches this could prove to be a very popular board. I would consider getting it even if they didn't. One thing though, would the close proximity of the DIMMs to the CPU be a problem for watercooling?
-ed out |
#6 |
Pewlius Caesar
bit-tech Staff
I don't think it will be much of a problem with watercooling, providing the block doesn't go too far outside the size of the AM2 mounting system.
__________________
#7 |
Hypermodder
Yer i was wondering that bigz, watercooling should be fine, but large fans such as the Asus StarIce 4 in 1 CPU cooler or the Gigabyte GH PCU31-SD 3D, you could have problems for these large copper heat sink fans, because of the width of the copper surround... And then there are the large fanless heatsink, basically a huge block of aluminum, that could cause you problems...
| olly_lewis |
| Find More Posts by olly_lewis |
#8 |
Multimodder
I would proble buy this mobo if it had a passive mobo cooler and the ram slot's were set as the dfi mobo but arr well, ill wait for review on the asus m2n32-sli deluxe layout looks sweet just hope performance wise its good.
all in all good effort foxconn :P |
#9 |
When did I get a custom title!?!
One question, on some of the benchmarks the "SLI" memory has tightend the timings. For a direct comparision shouldent the other systems be run with the same tightened timings?
__________________
Sn45g game server mod My Electronics Site![]() Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit |
#10 | |
DUR HUR
I also like the fact it comes with rounded cables, it annoys the hell out of me to have to buy more cables because the mobo comes with horrible flat ones. |
#11 |
It's Big, and It's Clever
Would look nice in my rig... all you'd see is my water pipes! Cool.
That CPU placement is not the best piece of design I've seen. It shouldn't be a problem with most watercooling, but anything other than a stock HSF may be a problem. Not happy with that 12v connector either. The beauty of having that, and the ATX almost next to each other is that both big fat power cables can be tied together, and it's easier to tidy the wiring. Having two seperate power cables going to the board is messy. It's bad enough trying to hide the ATX and 12v cables when they'r lashed together, but when they're on opposite sides of the board there's not a great deal you can do about that. Not the most impressive HT speeds either. Looks a nice board, but the above would bother me too much I think. Good review tho
__________________
Intel i7 920 @ 3.8GHz ¦¦ Asus P6T Deluxe ¦¦ 6Gb Corsair Dominator C8 ¦¦ XFX GTX295 ¦¦ 2x 1Tb Samsung F1 ¦¦ 1x Seagate 7200.11 1.5Tb ¦¦ Gigabyte Odin 800W PSU ¦¦ Dell 2405FPW.
#12 |
The Froggy Poster
Looks good, and i'm glad Nvidia's ref is a nice board. What i do wish is that more manufacturers did the DFI thing, and put the 24 and 8 pins within MM of each other...
__________________
Desky E8400 @ 4.0 1.42v; P5K-E WiFi; 4x1 Kingmax Mars 1066 @ 1129 CAS 5; 2x [TOO CHEAP TO SPONSOR] 4850 @ 675/1050; Enermax Liberty; WCing in a CM690 |
#13 | |
Pewlius Caesar
bit-tech Staff
__________________
#14 |
Ultra csavarkulcs
Banned Join Date: Mar 2006
looks pretty cool to me
hopefully we can get some really tight timing memory for the NF5 boards ![]() Im very interesting in the packet scheduling technology - is bit tech going to evaluate this ? (game and bittorent maybe ?) |
#15 |
Pewlius Caesar
bit-tech Staff
It only works if you're transferring data out... downloads are not affected (bit-torrent doesn't work - we tested it in the office before Computex). It's more for file sharing at LAN Parties
__________________
#16 |
Eat my...
I don't like it at all tbh. Foxconn should of rearanged the layout to provide a bit more space around the cpu as mentioned in the review. This just shows that Foxconn can't design motherboards very well. In fact, I would go as far to say they lack innovation
__________________
PSN: koola-uk |
#17 | |
Rick Relixed
Good review. I find it troubling when I come accross motherboards that have issues like this. Its too bad they don't take it for a final review. I'm not very familiar with Foxconn's product line or how many revisions they do on their boards, but do you think they may fix a few issues in a revision?
__________________
My Flickr [00:59] * yodasarmpit changes topic to '(+Astrum|Lap) everyone knows irc is the most important thing in my life'[00:59] <+Astrum|Lap> yodasarmpit: why do you hate me? |
#18 |
Modder
The further away the Ram slots are from the CPU, the more interference and potential latency/timing issues you get. AFAIK, its the whole reason the slots further away from the CPU usually don't overclock as well on many motherboards. I don't like the stupid placement of the chipset (under pci-e x16 slot 1 AGAIN?! i thought manufacturers already learnt not to do this after NF3 AND NF4), otherwise it looks fine.
__________________
no, your face. Last edited by TMM; 16th Jun 2006 at 09:17. |
#19 | |
Supermodder
-ed out |
#20 | |
Ultra csavarkulcs
| Thread Tools | |
