Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 19th Jun 2006, 13:15   #1
adamhorden
What's a Dremel?
adamhorden has yet to learn the way of the Dremel
XFX Geforce 7800GTX 256mB DDR3 Advice
Hi All,
I have a shuttle XPC board in a hoojum cubit 5 case. I only have one PCI E slot so I need a graphics card that will fit in a single slot and most of the new high end cards take two slots.
I am in the UK so I looked at the XFX Geforce 7800GTX but there are 3 part numbers for this card and I dont know the diffrence between the 3 but all the specs look the same?
The part numbers are:
PV-T70F-UDF7
PV-T70F-UDER
PV-T70F-UDFR
What are the diffrences for each for these cards? They are all diffrent prices as well. I am looking at buying it from ebuyer in the UK.
I like the XFX Geforce 7800GTX and I can use it in linux. I also looked at BFG tech but never used BFG but had lots of XFX cards in the past,
Thanks,
Adam
adamhorden is offline   Reply With Quote
Old 19th Jun 2006, 17:03   #2
alastor
I Mod, Therefore I Own
alastor's Avatar
alastor can run Crysisalastor can run Crysisalastor can run Crysisalastor can run Crysisalastor can run Crysisalastor can run Crysisalastor can run Crysisalastor can run Crysisalastor can run Crysis
Well the UDF7 has a core clock of 450Mhz while the UDER is the 'eXtreme' version with a 475Mhz core, cant really find anything about the third part number though.
Have you considered a 7900GT? Should be cheaper with equal or better performance, and runs cooler as it's based on a smaller manufacturing process. Would probably be better suited for the Cubit than a 7800.
__________________
Main Rig: C2D E6850 (3.0GHz) : Asus P5E (X38) : 4GB XMS2 PC6400 : HD4870 512MB : Enermax 620W : 2 x Samsung F1 1TB : Antec P182
My Flickr : My XBOX
alastor is offline   Reply With Quote
Reply
Tags
graphics
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
