RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 6th Jul 2006, 14:11   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
ASUS M2N32-SLI Deluxe WiFi Edition
http://www.bit-tech.net/hardware/200...xe_wifi/1.html
Tim S is offline   Reply With Quote
Old 6th Jul 2006, 14:31   #2
atanum141
I fapped to your post!
atanum141's Avatar
atanum141 is on a distinguished road
great work fron Bindi again.
__________________
Welcome to Thunderdome, B*tch
XBL: atanum141
atanum141 is offline   Reply With Quote
Old 6th Jul 2006, 14:54   #3
koola
Eat my...
koola's Avatar
koola is on a distinguished road
Hmm, I think bit was biggin this board up a lil too much. Imo, it's a good board (don't get me wrong) but its positioning is horrible. Not to mention the tight space around the CPU area.
If you flavor a better designed board but are willing to sacrifice the extra 4 phase power, then the Asus M2N-SLi Deluxe is by far the better choice
__________________
PSN: koola-uk
koola is offline   Reply With Quote
Old 6th Jul 2006, 14:59   #4
teamtd11
I *am* a Dremel
teamtd11's Avatar
teamtd11 will become famous soon enoughteamtd11 will become famous soon enough
great review.
a typo??? on the first page you said "and three PCI expansion slots" but dose't it only have two?
__________________
Main: AMD X2 3ghz, x1900xt, DFI NF590SLI, 4gb pc2-8500 [Watercooled]
Retro: AMD Barton 2ghz, 9600xt, 512mb pc-2700
Animal Crossing: LGTTC - 2492-7863-6464
Member of CK Appreciation Society Group
teamtd11 is offline   Reply With Quote
Old 6th Jul 2006, 15:03   #5
korhojoa
Multimodder
korhojoa is on a distinguished road
Originally Posted by teamtd11
great review.
Exactly.
Two full-bandwidth PCI-Express x16 slots with SLI support, one PCI-Express x4 slot and three PCI expansion slots;
__________________
the world is not enough, i gotta have modding too.
korhojoa is offline   Reply With Quote
Old 6th Jul 2006, 15:17   #6
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
Actually, the board pictured is DIFFERENT from the one I reviewed:
Thank you for pointing that out! Most strange!!
The positioning is fine, just a bit abnormal. Unless you REALLY REALLY need that extra SATA port. The extra 4 phase power is WELL worth it unless you absoultely have to use a MAHOOSIVE cooler, but most large coolers are heatpiped anyway and raise above the board a good few centemeters so it shouldnt ever be a problem. Even if it is close, it doesnt matter if they touch. Most coolers fall within the CPU surround guidelines so itll never be a problem, even the largest AMD heatpipe coolers fitted.
EDIT: OK this is totally totally nuts, but it appears the Wifi edition has the x1 slot but the non-Wifi edition has a PCI slot. The two aren't clearly dis-similar. I'd personally say go for the non-wifi edition cause 3 PCI slots are definately worth it. This is the first time Ive ever experienced an optional inclusion actually changing the board layout when the optional item doesnt have anything to do with the change in the board. It makes no sense.
Bindibadgi is online now   Reply With Quote
Old 6th Jul 2006, 15:38   #7
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
We've actually got both boards in the labs and I needed to photograph the WiFi Edition (as that was the one that Rich tested originally). It was my fault for assuming that the two boards had the same array of expansion slots - I sent Rich one of the two non-WiFi Edition boards we have, so that the pictures could be done in the studio.
I also worked on the overclocking and stability side of the article this week, too.
Old 6th Jul 2006, 15:42   #8
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
You see, the board on the right still has the Wifi plug (in blue) above the 4pin 12v plug. It's strange, there should be no reason to change between the PCI and PCIe slot, it's not something you expect.
Old 6th Jul 2006, 15:47   #9
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
The 8-phase PWM helps with voltage regulation (and thus overclocking) and nForce 570 SLI isn't meant to be as overclockable as nForce 590 SLI (the latter is cherry picked silicon). We will be reviewing some 570 SLI mobos this month to find out whether the myth is true or not.
Old 6th Jul 2006, 16:24   #10
DXR_13KE
Madeira's banana is the best!!!
DXR_13KE's Avatar
DXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to behold
it would be great if the sata conectors were on the side of the bord rotated 90 degrees.
and it has only one pata conector.....hmmm....so you can connect 6 sata harddrives and 2 optical drives, or mount a pata drive sacrificing one of the optical ones.
or input you need to purchase the optional card that plugs into the onboard header
if i want to use the microfone i have to purchase a optional card?
__________________
Renegade X - 0.40 Release! <---- CLICK!
DXR_13KE is offline   Reply With Quote
Old 6th Jul 2006, 19:46   #11
koola
Eat my...
koola's Avatar
Good stuff. It will be interesting to see some comparisons between the two chipsets.
__________________
PSN: koola-uk
Old 6th Jul 2006, 20:03   #12
EK-MDi
Multimodder
EK-MDi is on a distinguished road
I have some questions if you don't mind...
1. Does the integrated Wi-Fi card support WPA2 encryption?
2. What's the point in AI Nap, when that's what we have Microsoft Windows for?
3. How the heck did you manage to run some games in full HDR, with 4xAA, at a high resolution of 1600x1200, on an Nvidia 7900GTX, with a magnificent frame rate of 107.5? I though that current Nvidia cards aren't able to run games with AA and HDR both on at the same time, at a high resolution and acceptable frame rates... Unless the games in test uses that 'special approach' to beat the restraint.
EK-MDi is offline   Reply With Quote
Old 6th Jul 2006, 20:11   #13
MidnghtDrgn
Multimodder
MidnghtDrgn is on a distinguished road
So if the pins are still there on the non-WiFi board, could it be possible to get the WiFi card some other way (ASUS releasing separately later, or something along those lines), and put it on the non-WiFi edition, giving you the 3 PCI and the integrated Wireless?
MidnghtDrgn is offline   Reply With Quote
Old 6th Jul 2006, 20:35   #14
DXR_13KE
DXR_13KE's Avatar
is it me or this cooling solution is being used allot?
http://www.gigabyte.com.tw/FileList/...ures-6quad.htm
__________________
Old 6th Jul 2006, 20:42   #15
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
MidnightDragon:
Possibly! But it'll probably be the same as getting the S/PDIF input PCI connector which Asus says "is avaliable for purchase separately" but I've never seen extras like that avaliable in shops.
Want something even more confusing? My box SAYS Wireless Edition! So you don't know WHAT you're buying now.
DXR: P// harddisks are "non existent" in terms of use in these modern motherboards. ICH8 produced by Intel has NO parallel ports currently. You are forced to upgrade to SATA, just like you're forced into PCIe graphics.
As for microphone, no, that's on the back I/O panel but if you want S/PDIF In, then you'll have to find the card.. somewhere. I suppose they sell it in Taiwan.
As for cooling: Yep, because it works and when you get THAT MUCH power regs, instead of ducting the heat into the mobo like they used to do you have to dissipate it elsewhere now.
EK:
1) Can't say for sure if the Wifi card supports WPA2, I havent got the manual for it but you can try downloading the manual from the Asus website.
2) No idea, I had the same reasoning.
3) HL2 engine uses partial precision HDR not FP16 blend. This means you can enable HDR on the ATI x800 series which doesnt have the FP16 blend function as well.
Old 6th Jul 2006, 20:42   #16
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Source allows HDR+AA on all video cards.
Here is the WiFi card specs:
HTH
Old 6th Jul 2006, 21:45   #17
Latoron
What's a Dremel?
Latoron is on a distinguished road
Awesome review
I've read that the Foxconn was a better overclocker than the Asus M2N32, but I believe that the Asus beats the Foxconn in overclocking.
I've got a question - do 570 chipsets support dual x16 lanes in SLi? Because that is what I thought was a major advantage between the 570 chipset and the 590 (besides the other stuff).
Also another question, can the wireless connection on the Asus be used for high end gaming?
Like say if you play BF2 wirelessly with the Asus board, will you get low ping?
I'm still confused on this subject b/c I want to play online games wirelessly with my router, but I'm afraid I'll get low ping. Like will I need a T1 connection to play wirelessly, or will I need to wait for 802.11n?
Ugg so confused
Latoron is offline   Reply With Quote
Old 6th Jul 2006, 22:32   #18
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
I've personally used the wireless connection on the board, and gamed on it for some time. The pings were fine - I game over WiFi at home, too.
The main difference between the 570 SLI and 590 SLI is the number of PCI-E lanes available. Each PCI-Express x16 interconnect only has 8 lanes when using SLI mode on the 570 SLI. You can read more about the differences here: http://www.bit-tech.net/hardware/200...force_5/1.html
Old 6th Jul 2006, 23:21   #19
EK-MDi
Multimodder
HTH
OK thanks. So judging by that, it does support WPA2 .
Old 7th Jul 2006, 07:21   #20
Nature
Supermodder
Nature's Avatar
Nature is on a distinguished road
How is the audio quality compared to the previous ACL/97??
__________________
Peace, Love, Empathy, Respect, Generosity, Smiles, and Hugs
Nature is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
