RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 7th Jul 2006, 13:36   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Samsung SyncMaster 215TW
http://www.bit-tech.net/hardware/200...r_215tw/1.html
Tim S is offline   Reply With Quote
Old 7th Jul 2006, 14:18   #2
Spacecowboy92
Gettin' Lazy
Spacecowboy92's Avatar
Spacecowboy92 is on a distinguished road
I like the way you can just plug in difrent devices so easily.
__________________
Spacecowboy92 is offline   Reply With Quote
Old 7th Jul 2006, 14:48   #3
DXR_13KE
Madeira's banana is the best!!!
DXR_13KE's Avatar
DXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to behold
the only thing i would take out of this screen would be the speakers, it would cost a little less i think and be a little more thin.
__________________
RENEGADE X CONTEST! <---- CLICK if you want to win a free Command & Conquer 4 beta key!
DXR_13KE is offline   Reply With Quote
Old 7th Jul 2006, 14:58   #4
teamtd11
I *am* a Dremel
teamtd11's Avatar
teamtd11 will become famous soon enoughteamtd11 will become famous soon enough
yea. i have no idea why they put speakers in pc monitors. especially ones like this. if people are going to spend this much on a monitor. then they are going to have some good quality surround sound speakers
__________________
Main: AMD X2 3ghz, x1900xt, DFI NF590SLI, 4gb pc2-8500 [Watercooled]
Retro: AMD Barton 2ghz, 9600xt, 512mb pc-2700
Animal Crossing: LGTTC - 2492-7863-6464
Member of CK Appreciation Society Group
teamtd11 is offline   Reply With Quote
Old 7th Jul 2006, 15:03   #5
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
personally, I don't think it is a big issue - the speakers are very small and don't interfere with the overall looks too much, IMHO.
Old 7th Jul 2006, 15:21   #6
orb
satisfying.
orb's Avatar
orb is on a distinguished road
Still a little bit short of 1080i resolution?
__________________
[ ADDICT ]
orb is offline   Reply With Quote
Old 7th Jul 2006, 15:28   #7
Veles
DUR HUR
Veles's Avatar
Veles will become famous soon enoughVeles will become famous soon enough
Thats very true they are well sized and placed for monitor speakers, my old monitor added about 4" to each side to accomodate speakers I never used. Also, when you put a 21" screen on your desk, you loose quite a bit of room to put the speakers, so it can be a problem on a large desk.
That being said I do agree that this screen would've been better off without them, someone who pays this much for a monitor would have at least a half decent set of 2.1 speakers, which would be far superior to the puny things you get on monitors.
Have to say I really like Samsung screens, from the specs they always seem to be a bit better than the competitors in thier price range, especially with the contrast ratio. My SM913N has the best contrast ratio and brightness of all the screens I found in it's price bracket.
The fact it supports multiple connections AND HDCP is fantastic, add to that it being a very adjustable screen it's a big winner for me. Also great that it comes in black too
But...if I'm gonna spend £450 on a monitor, I may as well add on £200ish and buy one of those lurvley 24" Dells (although you do need a bit more umph to play games at that resolution )
__________________
Veles on: Xbox Live (My Halo stats), Steam Community, Twitter
Originally Posted by Fod View Post
spam gangsters might as well tap into all those machines for their zombie networks.
Veles is offline   Reply With Quote
Old 7th Jul 2006, 15:51   #8
Da Dego
Brett Thomas
Da Dego's Avatar
Da Dego is on a distinguished road
That's the problem...You can't just spend another 200 quid to go up a monitor without going up a graphics card, too. One of the difficulties I found in my last upgrade...I still use a good old philips 15" LCD from back in 2000. Works great, nice color...but only 1024x768 resolution. Spend too much on the card, no purpose because the monitor can't display it. But buy a new monitor, need a bigger/better card. Ugh.
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo
Da Dego is offline   Reply With Quote
Old 7th Jul 2006, 21:15   #9
choupolo
Minimodder
choupolo is on a distinguished road
I was looking for just a monitor like this. 1680x1050 is ideal for my needs (ie not having to go overboard on graphics cards) and the component should be good to hook up a 360 (although I'm still not sure how it will look).
My other option is to go for a Viewsonic 2025wm without the component and extra inch, and just use the 360 via VGA. It is a hundred odd pounds less after all. HDCP might be a problem in the long run however...
choupolo is offline   Reply With Quote
Old 8th Jul 2006, 10:07   #10
Firehed
Why not? I own a domain to match.
Firehed's Avatar
Firehed has a spectacular aura aboutFirehed has a spectacular aura aboutFirehed has a spectacular aura about
It's 1080p on desktop LCDs, but that's true of anything in it's size range. Notebooks are just unfair that way.
I've found that a 6800GT copes moderately well with this resolution, while I really needed my 7900GT to move to the 1920x1200 of the 24" screens comfortably. As the card is reasonably priced and fairly popular, it'll be an excellent counterpart for the 20/21" screens and should have no problems coping with the 1680x1050. Depends on the game of course, though I find myself working in 2d mode mostly nowadays so it hardly matters.
Good news in that sense is that you only need to change monitors... like... never, whereas you need a new GPU for the latest games every six months now.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net
40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8
MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD
Firehed is offline   Reply With Quote
Old 8th Jul 2006, 20:45   #11
Oclocker
I Mod, Therefore I Own
Oclocker's Avatar
Oclocker is on a distinguished road
This is a monitor that seems way overpriced for something that is hardly any better than a 17" 93 quid tft in that its only got a few pixels more height - and when large web pages are wearing out the scroll wheel an extra 200 approx pixels comes in handy - I think PCs and widescreens are mismatched for general pc use. Films may benefit but most PC work don't get a benefit ..
__________________
e-mail njc123@gmail.com
msn same
Oclocker is offline   Reply With Quote
Old 8th Jul 2006, 22:36   #12
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Have you used a widescreen monitor in Photoshop? I've personally found massive gains in that area, along with the benefits in gaming, too.
Old 9th Jul 2006, 00:55   #13
Oclocker
Oclocker's Avatar
Well mrs uses Photoshop more than I and she has the widest of widescreens (30" dell)..
/pedantic on
But images like the one on the right are more height oriented..
/pedantic off
of course web browsers can do the 90 degree flip
__________________
msn same
Old 9th Jul 2006, 04:14   #14
zoot2boot
Multimodder
zoot2boot is on a distinguished road
think half the reason samsung monitors often have ugly bases is because they do include the extra adjustability of the screen. it's all very well to make a slim little stand if all it's going to be doing is tilting but when it's rotating, tilting, moving up and down, pivoting etc. there's just no getting away from physics. people 'd get cranky if their swish new monitor was falling on its face the whole time.
zoot2boot is offline   Reply With Quote
Old 9th Jul 2006, 10:50   #15
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
My point is that Dell manages to do it without any issues, so why can't Samsung?
Old 9th Jul 2006, 11:50   #16
Oclocker
Oclocker's Avatar
Ahh Dell that minded me ..
Take the two 20" dells - one is 1680 by 1080 (IIRC)
other is 1600 by 1200 so extra 105600 pixels - admitedly not a lot, but having used both resolutions for intensive PC use (not gaming I admit) - I am convinced "widescreen" is popular because so many users have their first experience of hi-res displays using one and are comparing say 1280 by 1024 to 1680 by 1080, So therefore think 4:3 is Carp & WS is miles better - I wonder if someone was given both to try (after using a 17" display) which would be preferred, the one which does play films better or the one with extra desktop real estate?
Anyway drivers could easily be tweaked to display 1600 by 900 on a 4:3 display so say power DVD can auto switch a film into true widescreen rather than the 16:10.29/16/10 that WS tfts are in reality.
__________________
msn same
Old 9th Jul 2006, 12:45   #17
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
As mentioned in the review, 1680x1050 isn't my personal preference and I prefer using a 1920x1200 screen. However, with the costs associated with a 1920x1200 screen (better graphics card(s) if you want to game at native, increased cost of the screen) are often not very attractive. If you want to game at widescreen without breaking the bank, 1680x1050 is a nice compromise to make, IMO. I see it as an upgrade from a 1280x1024 monitor, not a replacement for a 1600x1200 monitor - the replacement for 1600x1200 is 1920x1200.
I find Photoshop much easier to use on a widescreen monitor because, even with all of the toolbars down the sides, there is still a decent area in the middle of the screen where you can work. With a 4:3 (or 5:4) monitor, I find myself not being able to work on the same image at the same zoom with the toolbars open and I end up with lots of dead space.
Old 9th Jul 2006, 15:10   #18
Noni
Supermodder
Noni is on a distinguished road
This is a great monitor and the extra inch apparently adds a nice size.
Noni is offline   Reply With Quote
Old 10th Jul 2006, 06:14   #19
Drexial
Supermodder
Drexial is on a distinguished road
i own this one, i chose it over the viewsonic 20.1 inch wide screen of the same resolution. one of the reason that the speakers are built in is ecause of the video inputs. if you hook up a DVD player or a camcorder or somthing, you wouldnt get any sound through the monitor. the fac that it has picture in picture is interesting. but a feature that will probly go unused. the rotation is amazing on this for PDF files, you can get a page and a half on there no problem.
the one defect in this, im hoping it has been resolved already, havent heard any complaints since it first came out. but there was a red line that would srout up about 2-5 weeks into using it. i bought one of the early models and it hapened tto me, so i brought it back for a new one, its alittle early to tell if its going to be an issue again.
as far as price goes, the samsung monitors usualy go for $300 for a 17" monitor, this one is sider and a smig taller and $500, but with alot better spcs and more options. if you really feel you need the extra desk top space (virtualy) then its amazing. i got it for video/audio work, and it doesnt do so bad for immersive gaming either. its not so much a better monitor stratigicly for gaming, but it will get you into the game more. i didnt have an NEC to compare it to, but i definetly liked it better than the viewsonic.
Drexial is offline   Reply With Quote
Old 10th Jul 2006, 07:12   #20
timmehtimmeh
Multimodder
timmehtimmeh is on a distinguished road
I don't see the point in "upgrading" to a 1650x1050 from a 19" 1280x1024 display - it's not a big enough jump in screen estate and doesn't warrant the extra cash for the display. For the same money you could just buy a second 19" for sub £200 and run 2 displays at 2560x1024.
Fair enough if your running a CRT or 17" and below tft's at 1024*768 and you fancy an upgrade. Else just wait for a 1920x1200 display to become cheaper or buy a Dell 2407.
On the topic of speakers on a display - keep them seperate please.
timmehtimmeh is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
