Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 15th Jul 2006, 09:44   #1
Aa-chan
AA-CHAN
Aa-chan's Avatar
Aa-chan has yet to learn the way of the Dremel
HDD for Shuttle SN25P
Recently bought an SN25P and am not sure which HDD to put in it. I've not been in the loop for quite a while and so don't really know which the top drives are at the moment.
I want something that's compatible [obviously], quiet and isn't going to melt anything. Ideal capacity is 200-250GB because I just don't need anything more than that.
Any recommendations would be helpful .
__________________
Follow AA-CHAN as he teaches in South Korea and enjoys his K-Pop fandoms up close!
Fandom and Foreigner in Korea - AA-CHAN
Follow me on Twitter!
Aa-chan is offline   Reply With Quote
Old 15th Jul 2006, 19:55   #2
Lazlow
I have a dremel.
Lazlow's Avatar
Lazlow has yet to learn the way of the Dremel
Samsung Spinpoint 250gb will do well, as it's one of the quietest drives available and also nice and quick.
__________________
Logs: Red Nineteen|Pink PC
Links: slickhouse.com|Free file upload
Lazlow is offline   Reply With Quote
Old 16th Jul 2006, 11:26   #3
Tomm
I also ride trials :¬)
Tomm's Avatar
Tomm has yet to learn the way of the Dremel
I've got a Seagate 250Gb IDE in my Shuttle, had no problems at all, it supposed to be one of the quietest
__________________
Carrot cake cheesecake
Shuttle SN85G4V2 | A64 3200+ / Apple PowerBook 12
Tomm is offline   Reply With Quote
Old 16th Jul 2006, 14:19   #4
Aa-chan
AA-CHAN
Aa-chan's Avatar
Is SATAII the same as SATA300? Just need to confirm this before I buy .
__________________
Old 17th Jul 2006, 11:40   #5
Lazlow
I have a dremel.
Lazlow's Avatar
Yes. SATAI being the first generation, or SATA150 in terms of speed. SATAII being the second generation, or SATA300 in terms of speed.
__________________
Old 18th Jul 2006, 10:48   #6
Firehed
Why not? I own a domain to match.
Firehed's Avatar
Firehed has yet to learn the way of the DremelFirehed has yet to learn the way of the DremelFirehed has yet to learn the way of the Dremel
Well technically there's more to it than that, but that's the basic idea. However, any drive with a SATA plug will connect without issue to any SATA port, obviously running at the slower of the two speeds if they're not the same (or at least it should always work that way; my fileserver has SATA 1.5Gbps ports and 3Gbps drives, and no issues).
I'd give props to Seagate too, if that's what you're considering. I just got a pair of their 320GB drives with perpendicular recording, and they're amazingly fast (they outpace my Raptors by at least 15MB/s sustained, and additionally max out the channel on read bursts). At least stateside, they can be had for $99 each right now, which is an awesome price for that capacity regardless of the speed. Haven't heard a peep from them. Only complaint was that they took about five hours to do a full format, but you've gotta expect that from a drive that size.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net
40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8
MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD
Firehed is offline   Reply With Quote
Reply
Tags
sff
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
