Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 24th Jul 2006, 06:07   #1
CaseyBlackburn
Network Techie
CaseyBlackburn's Avatar
CaseyBlackburn has yet to learn the way of the Dremel
PHP: Combine Multiple Image with GD?
Alright guys, I am in a little bit of a bind. I need to combine 5 images into one, but I can't just make them together, because one of them is dynamic, but in the end they need to be one image. I decided that the GD Library is what I need for this, but I don't know how to call multiple images into the script for it.
Here is my current code, which currently only loads 1 of the 5 images, and it is the one that needs to be dynamic:
PHP Code:
<?php
header
("Content-type: image/png");
$im=imagecreatefrompng("http://miniprofile.xfire.com/bg/bg/type/1/blackburnperson.png");
imagepng($im);
imagedestroy($im);
I want the end result to be one image that looks like this:
TOP TOP TOP TOP TOP TOP TOP TOP
LEFT CENTER CENTER RIGHT RIGHT
BOTTOM BOTTOM BOTTOM BOTTOM
In other words, very much like: This
__________________
Casey Blackburn
My art - CaseyBlackburn @ dA
Get Firefox - Take Back The Web
CaseyBlackburn is offline   Reply With Quote
Old 24th Jul 2006, 09:47   #2
ST8
Supermodder
ST8's Avatar
ST8 has yet to learn the way of the Dremel
Look at the imagecopy function for merging multiple images, i use it to dynamically add copyright to my images when hotlinked
__________________
DeviantART
Bleh
ST8 is offline   Reply With Quote
Old 24th Jul 2006, 12:00   #3
Bogomip
... Yo Momma
Bogomip's Avatar
Bogomip - it's over 9000!!!!!!!!1!1!1!!!Bogomip - it's over 9000!!!!!!!!1!1!1!!!Bogomip - it's over 9000!!!!!!!!1!1!1!!!Bogomip - it's over 9000!!!!!!!!1!1!1!!!Bogomip - it's over 9000!!!!!!!!1!1!1!!!Bogomip - it's over 9000!!!!!!!!1!1!1!!!Bogomip - it's over 9000!!!!!!!!1!1!1!!!Bogomip - it's over 9000!!!!!!!!1!1!1!!!Bogomip - it's over 9000!!!!!!!!1!1!1!!!Bogomip - it's over 9000!!!!!!!!1!1!1!!!Bogomip - it's over 9000!!!!!!!!1!1!1!!!
Yeah, the imagecopy function is what you need, though I had some difficulty using only that - for some reason. The imagecopyresampled function seemed to work better - also try looking at imagecopymerge.
I used them functions to create http://www.sweeto.org/site/vs.php - the code looks fairly simple, though took me a while from what i remember
edit: thats 3 images merged into one by the way - 2 pictures have their transparency altered and two are .png's and one is a gif iirc.
Bogomip is offline   Reply With Quote
Old 24th Jul 2006, 14:57   #4
CaseyBlackburn
Network Techie
Mind posting your code Bogomip so I can get an idea of how it is done?
EDIT:I have offically gotten it to work, below is my code
PHP Code:
header
$src = array ("http://img164.imageshack.us/img164/5175/toprb3.jpg","http://img123.imageshack.us/img123/9056/leftij4.jpg","http://miniprofile.xfire.com/bg/bg/type/1/blackburnperson.png""http://img67.imageshack.us/img67/4786/rightnt1.jpg","http://img123.imageshack.us/img123/4891/bottomtp5.jpg");
$imgBuf = array ();
foreach (
$src as $link)
   switch(
substr ($link,strrpos ($link,".")+1))
       case
'png':
$iTmp imagecreatefrompng($link);
           break;
       case
'gif':
$iTmp imagecreatefromgif($link);
           break;
       case
'jpeg':
       case
'jpg':
$iTmp imagecreatefromjpeg($link);
           break;
array_push ($imgBuf,$iTmp);
$iOut imagecreatetruecolor ("450","131") ;
imagecopy ($iOut,$imgBuf[0],0,0,0,0,imagesx($imgBuf[0]),imagesy($imgBuf[0]));
imagedestroy ($imgBuf[0]);
imagecopy ($iOut,$imgBuf[1],0,54,0,0,imagesx($imgBuf[1]),imagesy($imgBuf[1]));
imagedestroy ($imgBuf[1]);
imagecopy ($iOut,$imgBuf[2],15,54,0,0,imagesx($imgBuf[2]),imagesy($imgBuf[2]));
imagedestroy ($imgBuf[2]);
imagecopy ($iOut,$imgBuf[3],292,54,0,0,imagesx($imgBuf[3]),imagesy($imgBuf[3]));
imagedestroy ($imgBuf[3]);
imagecopy ($iOut,$imgBuf[4],0,117,0,0,imagesx($imgBuf[4]),imagesy($imgBuf[4]));
imagedestroy ($imgBuf[4]);
imagepng($iOut);
__________________
Casey Blackburn
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
