Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Crysis minimum specs released
__________________
#2 |
Ultramodder
Wow pretty hardcore, I just make the minimum requirements. Lets face it when a manufacturer tells you the minimum they really do mean the MINIMUM! Time for an upgrade I think!
__________________
3Ghz P4E, asus P4C800E-deluxe, 2GB OCZ (2x1024), Sapphire HD 3850, SB audigy 2 zs Last edited by ChromeX; 26th Jul 2006 at 00:32. |
#3 |
Geoff Richards
Moderator
Considering the game is 6+ months away, plenty of time for prices to tumble
#4 |
Multimodder
I'm below the recommended specs in a couple of areas. Not by much though (7800 GT, 1GB RAM, A64 3700+). I'll probably upgrade in a couple of months.
#5 |
Multimodder
with my p4 3ghz 2gigs of ram and my 850xt I think I will be quite
comfortable but for the follow up to crysis I'm sure to need an over haul! can't wait!!! |
#6 |
Supermodder
got minimum.. ouch.. This game will rock though
#7 |
Mod Master
For the first time ever my PC has been beaten by the minimum requirements. Like, FEAR came close, but this has butchered my PC. Mine would crash during the installer if I tried to play this game. Good thing I'm doing a full overhaul in January, then I can play!
__________________
Latest Work: Boombox Build Project PCB- Complete Digital Picture Frame 2.0- Complete RumbleMouse - Complete Latest Project: TestPC- Complete Lian-Li PC7: C2D E6600, XFX 8800GTS 640MB, Corsair 2GB PC6400, 320GB Seagate Barracuda, EVGA 680i SLi, OCZ 850W |
| mattthegamer463 |
| View Public Profile |
| Find More Posts by mattthegamer463 |
#8 |
Multimodder
I don't think we can call this quite "official" as of yet. From what I've heard, Crysis-Online is a Crytek Endorsed Fansite. And the post was a "educated guess" from an admin on that site. Ie. Not from a Crysis developer.
Looks like the website is down due to traffic, which would go in line with the idea that it's a fansite. Doesn't mean the specs aren't accurate though. Only time will tell ![]() Aggies |
#9 |
Ultramodder
Wow is this the first game that recommends Dual core? This should be optimized hard core for multi threading.
| Cheap Mod Wannabe |
| Find More Posts by Cheap Mod Wannabe |
#10 |
Multimodder
I'd imagine that the second core would be used for the physics processing, for the fancy effects seen in the videos.
Apart from my video card, my PC is just over the recommended spec. However, i'd imagine that 2Gb ram/X2 3800/whatever the top gfx card is at the time will play it fine & dandy.
__________________
http://www.anandtech.com/myanandtech.html?member=76821 "I am standing in the sky on the roof of a glass and steel office tower in Rotterdam. There are twenty-one floors of air between me and the concrete pavement below. I am about to do what i do best. I am about to jump." - Jackie Chan |
#11 |
Hasselhoff™ Inside
wow, its kinda depressing when the minimum requirments for a game reads like the spec for your best rig (sig rig in my case).
#12 |
Hypermodder
Recommended Specs:
* CPU: Dual-core processor (Athlon X2/Pentium D/Core 2 Duo); NO * GPU: NVIDIA GeForce 7800 GTX / ATI Radeon X1800XT (SM3.0) or directX10 equivalent; NO * RAM: 1.5GB; YES * HDD: 6GB; YES * Internet: 512k+ (128k+ upstream); YES * Optical Drive: DVD; SURE * Software: DirectX 10 with Windows Vista MAYBE Sadly my rig doesn't quit match the high specs...BUT I think I might have upgradind to Conroe by releas (If I dont get a macbook) This game will be a killer
#13 |
Multimodder
Anyone notice the site that is linked is down???
__________________
AMD Sempron 64 3400+ | Asus K8N-E | PDP 1GB PC3200 Memory | ATi Radeon 9700 Pro | SB Audigy 2 Value Seagate 250GB HD 7200.10 Lite On 16x DVD Burner | Antec 430 Watt PSU | Lian Li PC-7 A Plus case |
| Kasrkin Guard |
| Find More Posts by Kasrkin Guard |
#14 |
Hypermodder
Hoping it'll work on the slight overclocked 2.13Ghz Pentium M I'm using for a media/gaming machine... The rest of the specs are alright - although the 7900 GPU is close.
Got to think though in a living room gaming environment, the screen is only 1280x768 (or 1280x800, I forget)... So it's not to harsh on the GPU anyway.
__________________
Jimmy Carr - "It's easier to get forgiveness than permission" |
#15 |
I pwn all your storage
I want to know WHEN DX10 cards are out and WHICH cards they are!
#16 |
Tyrannosaurus Alan !
* CPU: Dual-core processor (Athlon X2/Pentium D/Core 2 Duo); Kerching
* GPU: NVIDIA GeForce 7800 GTX / ATI Radeon X1800XT (SM3.0) or directX10 equivalent; Kerching * RAM: 1.5GB; Soon to be 2gb for me * HDD: 6GB; Yesh * Internet: 512k+ (128k+ upstream); Yesh, suck on 10mbit/384kkbit ![]() * Optical Drive: DVD; Well duh * Software: DirectX 10 with Windows Vista Probably On the borderline for reccomended, so I'm reasonably happy
__________________
{Macbook Pro + Dell 2407 WFP - Canon 3000V + Canon 350D + BG-E3 + Sigma 10-20mm + 50mm f1.8 + kit 28-90mm EF - Rolleiflex 2.8 TLR}
*Flickr ~Flickriver ^ My Behance Art Folio |
#18 |
sensational.
Athlon XP 2500+ @ 2ghz
ASUS A7n8x deluxe Radeon 9800 Pro 2x 256mb DDR RAM Can you feel the power of my rig??? No, not really, I can JUST about play Battlefield on LOWEST settings, overclocked, *sigh*.
__________________
█▓▒▒▓█▓▒▒▓█▓▒▒▓█▓▒▒▓ Originally Posted by Greeneyedguy advice to all u masturbators... its a good idea to keep a pringles can with the bottom cut out next to u so u can put it over ur wang when ur parents come and tell em u were enjoyong some delicious low-fat potato chips... |
#19 |
Mube Codder
No, the specs don't suprise me at all. In fact I don't even bother looking at today's bleeding edge games as their specs have always been miles above the level of my 4.5 year old AthlonXP 1900 and GF4. Still can't wait for the game to arrive though!
__________________
Play my game: Shyguy's Cave of Death! If you dont have the time to check your spelling and grammar, you dont have the time to post! -Liquid K9 |
#20 | |
Pewlius Caesar
bit-tech Staff
__________________
| Thread Tools | |
