#1 |
Pewlius Caesar
bit-tech Staff
MSI K9N SLI Platinum
__________________
#2 | ||
Multimodder
Also I was under the impression that the current AM2 memory controller didn't support ddr2 800 at 1T command rate. Have mobo makers gotten around this or have I read it wrong? Wouldn't be the first time
#3 | |
Pewlius Caesar
bit-tech Staff
__________________
#4 |
Richard Swinburne
bit-tech Staff
As far as Im aware all the ALC88x's have Dolby Live and Virtual Surround, the "M" versions have extra stuff because they are Master studio version like the 882M. But the 880, 882 and I can only guess the 888 has it. I cant remember now, it has been a while since I installed the software and tested the board, but I was certain it was a standard software feature however the Realtek site states that the 883D has Dolby Live support and 883DTS is DTS. It seems strange to go BACKWARDS with support seeing as the 880 and 882 did it as standard: you had Live, Virtual Surround IIx, Dolby Headphone etc. Ill have to check this one.
EDIT: Even the 888 now has Dolby Live as an extra. The whole point of HD was that it had Dolby support for a home theatre, not just high def media decoding into multichannel. It seems Realtek have pulled support as standard and made it an extra that people pay for, which sucks. I love Dolby Live and Virtual Surround IIx ![]() As for Xover cable: sure, and having two ethernet ports are great for that but most home routers are still 10-100 Fast Ethernet so as long as you have one Gigabit port that should be fine. If you have a Gigabit router then Id assume youd just plug in your laptop into that so as it can share with everyone in your house and have net access. For sharing data though, Gigabit is a must. Ive got a 4 user NAS box with 10-100 support connected to a 10-100 router and it struggles sometimes.
__________________
#5 | |
What's a Dremel?
Page 5
Interesting article. I liked the 2 summaries at the end. Gave me some useful info. Oh and the board layout shot was really nice too. Keep it up. Last edited by g-freak; 26th Jul 2006 at 19:30. |
#6 |
Richard Swinburne
bit-tech Staff
Apparently it is a word, just not the one I was looking to use.
#7 | ||
Multimodder
As for DDLive support that was my understanding (some versions of the codec support it some don't) |
#8 |
Richard Swinburne
bit-tech Staff
The ECS KA3 MVP we reviewed recently has 1 Gigabit, 1 fast ethernet. The 10/100 chips are still cheaper and are PCI based.
#9 |
Multimodder
For me as long as there's 1 gigabit that's the main thing. I guess the gigabit chips will get cheaper to a point where there's not much point to going for 10/100 over gigabit. Plus with performance chipsets from nvidia you're pretty much gauranteed gigabit given that the gigabit mac is included in the chipset.
#10 |
Richard Swinburne
bit-tech Staff
We checked out the ALC883 and it appears the Dolby options have been removed
![]() ![]() We changed the article to reflect this accordingly. |
#11 |
Multimodder
Was just wandering is the dolby digital live functionality built into some realtek codecs software or hardware based? My guess is software to minimise costs.
#12 |
Multimodder
Bindibadgi,
I know it's a bit cheeky but noone seems to have any info for me for the following thread Onboard SATA & eSATA compatibility I assume it's info most people here haven't come across so was wandering if you or anyone from bit-tech had any insight? |
#13 | |
Richard Swinburne
bit-tech Staff
#14 |
Multimodder
I guess as long as the overhead is small enough it doesn't matter either way.
#15 | |
Multimodder
Current AM2 IMC doesn't officially support ddr2 800 at 1T command rate It seems that some mobo manufacturers have gotten round this problem although not yet for when all four dimm slots are populated with ddr2 800. According to the article above the command rate doesn't have much real world performance impact with the current memory controller but thought I'd mention it. |
| Thread Tools | |
