RSS
Reply
Thread Tools View Mode
Old 1st Aug 2006, 12:06   #1
Kumo
Hypermodder
Kumo's Avatar
Kumo is on a distinguished road
Project: KNS-01 01-Nov
Well many of you know about my rack project (if not, go here ). I'm doing it to keep my computers tidy and clean. This is the first machine on my network (KNS-01) and the first one for the rack.
A jump between some post on Bit-tech.net forums, like this or this i was inspired and decided to make a new case for my Shuttle system.
I have a LAN party close in time and with my LAN Raider project on hold (here ) while i get more parts and ideas, a new case was needed. In add, this case will give me enought space for liquid cooling components and others.
By the reasons i've said, i have other projects on hold, so i took these hex bases borrowed for this project. I fixed both with screws, cutted, filed and sanded until they matched perfectly. Then i began to make an alu frame.
This is the back of the case. The small hole is for ventilation and the big one to pass the shuttle chasis thru. I'm going to use wood (MDF) only in front and back and it will be properly covered when finished.
The inside face of back and front, with the angles to support the structure and the chasis. The frontside will has holes also, for buttons and others, but i'll make they later.
8 of those 8x8mm ALU square bars wil be the chasis of the upper structure.
A teaser of the case. HDs will be in the botton, in a removable plate for easy access. The shuttle chasis in the middle and WC comps in the sides. I have to decide some things, like the location of the DVD (maybe a slim type unit) and others.
Glueing the bars as previous step to make the holes precisely. It will be strong for LAN parties
More pics soon. As i've said, this is the first case for my rack project and the shape isn't very common, but i've already thought how i'm going to put that thing on the rack... surprise.
Kumo is offline   Reply With Quote
Old 1st Aug 2006, 13:08   #2
iwhy
What's a Dremel?
iwhy is on a distinguished road
Oh realy nice work with Al profiles.
And of course I like that hexagonal shape is something unconventional
iwhy is offline   Reply With Quote
Old 1st Aug 2006, 13:14   #3
Kumo
Hypermodder
Kumo's Avatar
the problem with alu is heat... dremel, heating alu, burning fingers, summer.... I need air conditioned at home jajaja
Old 1st Aug 2006, 13:23   #4
iwhy
What's a Dremel?
I cutting it by hacksaw in clamp, but cut isn't realy clean a ovell.
But you could use this blade
Primary used for cutting wood but I think with Aluminium it could work withou heating.
Old 1st Aug 2006, 15:48   #5
Kumo
Hypermodder
Kumo's Avatar
It looks like a blade for straight cuts on wood. For alu the tooth need to be smaller, IMO
Thanks anyway. Maybe i'll try the hacksaw. Sometimes i cut it with the jigsaw, but to get a good cut is not always easy.
Old 2nd Aug 2006, 22:38   #6
Kumo
Hypermodder
Kumo's Avatar
My idea of glueing the bars first, didn't work so i've changed the plans.
I've traced lines in the middle of each profile...
...and then i matched it with the lines in the steel angles. They were fixed with clamps to make the first set of holes.
The case is pretty strong and still left more screwing work.
A preview:
More things soon.
Old 7th Aug 2006, 21:15   #7
Kumo
Hypermodder
Kumo's Avatar
More updates.
After making the second set of holes the chasis/case (outter shell) is rock solid.
Supports for the shuttle chasis.
After align the profiles with the frame, i glued they with araldit epoxi, that is very strong.
Watching this forum, cats love mods... is a fact.
Get the shuttle chasis there is not easy. I had to cut and sand some sides, because (disapointing) the chasis is larger at the back. I have to paint the chasis well before put it inside the case.
The back of the case. You can see my current setup to cool the CPU and GPU. I'll redo it better when the case will be finished. A handle to pull out the case would be nice.
At the front, holes to secure the chasis. The front needs work...
Some details in the front. Black in the top, the Imon inside reciver module. At the botton...
...My spider logo. i'm re-using it, maybe by the last time. Isn't still glued, but fit perfectly. Once the front will be covered, you only could see the the inner circle and the spider.
Behind the spider i'll put one of my MDVA's lite unit. I hope to achive a nice effect.
Comments and ideas are welcome.
More soon!
Old 7th Aug 2006, 23:10   #8
Klekkus
Hypermodder
Klekkus's Avatar
Klekkus is on a distinguished road
Looks like a very good start! KUTGW
Klekkus is offline   Reply With Quote
Old 8th Aug 2006, 00:17   #9
hydro_electric_655
Dremelly Dude
hydro_electric_655's Avatar
hydro_electric_655 is on a distinguished road
I like the idea And make a recessed handle so its seemless. That is my new idea for cases seemless.
hydro_electric_655 is offline   Reply With Quote
Old 8th Aug 2006, 06:35   #10
Kumo
Hypermodder
Kumo's Avatar
Thanks.
KUTGW??
Maybe i'll put a pair of handles at the front like in rack units and one at the back to pull the shuttle, but i'm not going to put handles to carry the case really, because i cand find any nice heavy duty handle here, only the common ones.
To carry the case to LAN, maybe i'll order a custom bag... to my girlfriend, she's a genious with the sewing machine.
One thing i forget, no paint this time. I want to cover the case with vinyl, so i'm making a design with Gimp.
Old 8th Aug 2006, 09:50   #11
John_Edward
Minimodder
John_Edward is on a distinguished road
Originally Posted by Kumo
KUTGW??
Keep Up The Good Work, i think.
And this really looks good
Are you going to put the water cooling inside the case, it looks like there would be enough space ?
Looking forward for this :]
You cat is cute btw :3
John_Edward is offline   Reply With Quote
Old 8th Aug 2006, 10:39   #12
Kumo
Hypermodder
Kumo's Avatar
Yes, the WC will be inside the case. The negative point is that a 240 rad doesn't fit inside, but the temps are ok with de Black Ice 120.
Old 8th Aug 2006, 10:50   #13
Klekkus
Hypermodder
Klekkus's Avatar
Yes
Old 19th Aug 2006, 11:45   #14
Kumo
Hypermodder
Kumo's Avatar
Sorry for the lack of updates. I've been busy with the project. But at last some news.
Yesterday i bought some new gear for the case and new items for the armory
Hinges, vinyl, etc... And my copy of your favorite delta sander.
Come on with the work.
I leave it when i was fixing the MDVA. So i resume it there.
The MDVA full unit front bezel used as template for hole drilling.
The front. As i previosuly mentioned, when the front will be finished, only the circle will be visible.
And the back. The MDVA only uses de 5V line, so less wires to solder, and less mess.
ALU profiles to make a variety of pieces. I'm using a lot of profiles in this project.
Edges to support the sides. Are fixed with araldit epoxy. Recently i've discovered the Araldit expoxy for metals that is even stronger.
The base of the case is made of steel. I hope the steel will be present only there, if not i going to need a truck to move it. To bend the plate without the required tools, i dremeled a channel first.
The base in place. The top plate should be like that but in alu, if i can find 1mm alu plates anywhere.
Old 19th Aug 2006, 12:40   #15
Kumo
Hypermodder
Kumo's Avatar
The main reason of the lack of updates is because i've changed the design a little. I want a removable HD tray. But in the former desing it wasn't possible. So i began remakin the back pannel small hole
Catch the diference?? I reconstruted the hole with wood, araldit and putty.
This is the idea of the docking bay.
The plate for the bay has being glued in place with araldit.
I've also did a stand for the hd tray
Triying to save some weight in every place.
The stand is fixed with screws to the base.
Profiles added to drive the tray thru.
This is the HD tray. It's a hacked shuttle tray with a lot of work. I had to reconstruc one side because it has a hole for wiring pass in other project, added profiles, cutted vent holes, added stands off from a Zalman block, etc... In the pic with dummy HDs
This is the idea... And the last pic for today. But before a little preview....
Preview 1:
My girlfriend is making a Lan party hex bag for the case.... more to come.
Preview 2:
Some final scheme designs. I made they with Gimp. Each image are 2 faces of the hex sides. The top and botton will match they more or less.
Design 1
Design 2
Design 3
No paint this time. I want to cover the case with vinyl. The "grey" part is metallic finish vinyl.
Comments are welcome.
More soon.
Old 19th Aug 2006, 15:05   #16
CC-R
What's a Dremel?
CC-R is on a distinguished road
Design 2
CC-R is offline   Reply With Quote
Old 19th Aug 2006, 15:19   #17
axscpu
Multimodder
axscpu is on a distinguished road
I like the design Nº2 looks great, althou if you use aluminum sheets for the side panels you won't need the metal vinyl......
__________________
Akira: Asus m2npv-vm, a64x2 5600, khx6400d2llk2/2gn, X-fi
Nami: Asus p5n32-e sli, c2q6600, twin2X2048-8500c5d, Geforce 8800gtx
Sakura: Asus p5b-vm, c2d 6600, twin2X4096-6400dhx, Radeon 2900xt
axscpu is offline   Reply With Quote
Old 19th Aug 2006, 15:40   #18
Kumo
Hypermodder
Kumo's Avatar
To uniform al colors igoing to use the metallic vinyl. Remember that the base is made of steel. In add to polish all the case is not easy.
Old 19th Aug 2006, 19:08   #19
JAxen
Multimodder
JAxen's Avatar
JAxen is on a distinguished road
Dayumn.. Why didnt I think of this for
KUTGW ;D
__________________
http://www.zeitgeistmovie.com/
A must-see movie! Gets you thinking, seeing things thru another perspective for sure.
"When the power of love overcomes the love of power, the world will know peace."
JAxen is offline   Reply With Quote
Old 20th Aug 2006, 23:45   #20
Kumo
Hypermodder
Kumo's Avatar
I did a little test with the MDVA and the spider etch.
What do you think?
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
