#1 |
Just another nobody
Conroe heatsink group test
#2 |
Lethargic
Quick question (I know you can't test every heatsink/fan out there...) whats the word on the Scythe Ninja? I'm quite impressed by that heatsink, even if it can be a bit of a pain to install...
And yes, that Passiv is a rather mental piece of kit...
__________________
Core i7 920 D0 @ 3.8GHz | 6GB Corsair 1600MHz | Gigabyte EX58-UD5 | XFX 4870X2 2GB | 4TB | WUXGA |
#3 |
Mube Codder
It looks like the Freezer 7 Pro is actually £17.60 from Kustom:
http://www.kustompcs.co.uk/acatalog/info_2626.html The Tuniq tower 120 cooler looks interesting aswell. I wonder how ths compares: http://www.kustompcs.co.uk/acatalog/info_2604.html
__________________
Play my game: Shyguy's Cave of Death! If you dont have the time to check your spelling and grammar, you dont have the time to post! -Liquid K9 |
#4 |
Pewlius Caesar
bit-tech Staff
I had this arrive on my desk this morning:
![]() I will be doing some Conroe overclocking with it later this month. (it's a Noctua NH-U12)
__________________
#5 |
Mube Codder
When you do the overclocking tests can you give overclocking results when using the stock cooler aswell? That way we can compare the difference between an overclocked E6400 + £30 heatsink and an overclocked E6600 with no extra heatsink. That way we can see which option gives the best bang/buck.
__________________
#6 |
Pewlius Caesar
bit-tech Staff
sure - I'll see what I can do.
__________________
#7 |
A motorbike of jealousy!
was waiting for something along these lines... Still not sure I can be arsed with watercooling. Maybee that can be a phase 2 project when i get my new pc sorted.
#8 |
Supermodder
Cant i just put DangerDen RBX (1/2") - P4 775 in there?
Do the old 775 blocks work with conroe?
__________________
Got Brains bitch... |
#9 |
Supermodder
I would love to see this same test done with some of the most popular water blocks out there using a standard set up. feed everything through the same pump, and use a black Ice GT220 rad with some good fans.
I think this is one of the better pieces you all have done lately. Thankyou it was compriensive, well thought out, and very informative/user friendly. thanks for putting 2 w/c kits in |
#10 |
Minimodder
anyone know where I can get the Akasa AK-960 in the U.S.? I know I can get the Freezer 7 over here, but damn...that thing looks enormous.
Who's the newegg (popular online retailer) equivellent in the UK?
__________________
Never underestimate the bandwidth of a station wagon full of floppies. Mac Pro (2) 2.6 GHz Woodcrests. OSX and XP installed. Intel DP965LT | Intel E6400 | 1GB A-Data DDR2-667 | CoolMax 500w PSU | XFX 7600GT | (1) Seagate 7200.9 160GB os | (1)WD 250GB | (2) Hitachi 160GB |
| rgkgraphix |
| View Public Profile |
| Find More Posts by rgkgraphix |
#11 | |
Pewlius Caesar
bit-tech Staff
__________________
#12 |
Multimodder
Some constructive feedback from my part:
While the article may be fairly well written, I think it's lacking in the "scores" department. The numbers didn't really tell me much about how it performed. Showing the scores in stars, or some other form of seeing what the "max score" was supposed to be, would be a little more helpful and intuitive. The graph at the conclusion page could probably be easier to read if it was sorted by performance, or sorted by category, such as having all the HSF's CPU temprature next to eachother. Apart from that, a well written article. By the way, any idea how the HSFs compare to a cooler such as the CNPS9500, in terms of noise and performance?
__________________
- Rexxie Sanity is a full time job. |
#13 | |
Minimodder
Is that an apartment building in Japan?
__________________
| rgkgraphix |
#14 |
I inglish is god
What's the temp rating on the Conroe?
Seems that we're entering the "Tower" era. And I still defend air against water. |
#15 |
Ultramodder
I've been torn between the Tuniq Tower 120 and the Freezer 7 Pro. Sure, the Freezer will work just find and dandy...but the Tuniq Tower is just so bad ass.
__________________
Abit AB9 Pro, Intel Core 2 Duo E6400 CPU, 2GB Corsair DDR2 6400, nVidia 8800GT, Seagate 160 GB HDD. |
| Neogumbercules |
| Find More Posts by Neogumbercules |
#16 |
Minimodder
as was said by Paradigm Shifter, know u guys can't test all the heatsink out there but i am interested on seeing how the zalman 9500 performance against the rest
__________________
unless i grip the sword i cannot protect you, while gripping the sword i cannot embrace you |
| cereal_killer |
| Find More Posts by cereal_killer |
#17 | ||
Ultra csavarkulcs
Banned Join Date: Mar 2006
i was confused by this bit
Sorry, but to me those seem to vastly contradict each other - can anyone explain how that works, or is that a typo .. |
#18 |
What's a Dremel?
Is the Freezer really better than the TT Big Typhoon? Wow I'm shocked, I thought the T Big Typhoon was far superior.
So can you guys safely say that I can overclock far better (or the same) with the Freezer Pro than the Typhoon? I just need a confirmation ![]() Also here in the U.S., the Typhoon is on sale, with free shipping. If I get the Freezer 7 Pro, with shipping it becomes more than the Typhoon. So should I get the Typhoon or the Frezer 7 pro? Last edited by Latoron; 2nd Aug 2006 at 02:28. |
#19 | |||
7-2 offsuit
Great review though. However, didn't see the Tuniq Tower 120 and the Scythe Ninja. Apparently they kick the crap out of the rest of the coolers in terms of noise/performance ratio. Ah well.
__________________
| dragontail |
| Find More Posts by dragontail |
#20 |
Supermodder
"Unlike most of the other heat sinks, it uses six separate heat pipes instead of three pipes doubled over. However, because of the design, only three of these are aligned correctly (pointing vaguely upwards) when the unit is installed in a tower case."
I never thought that gravity would affect a heat pipe that badly - is this really a big deal? |
| Thread Tools | |
