Old 2nd Aug 2006, 21:39   #1
BioSniper
I Mod, Therefore I Own
BioSniper's Avatar
BioSniper has yet to learn the way of the DremelBioSniper has yet to learn the way of the DremelBioSniper has yet to learn the way of the DremelBioSniper has yet to learn the way of the Dremel
BIOS rollback?
For some time now I've not been able to quite put my finger on my systems terrible performance in some games (PlanetSide, Dawn of war loading times etc) but the more I think about it the more I seem to believe that the bad performance started when I updated my bios to the latest and last version.
I have an NF7-S v2.0.
Can I roll back to an older bios (this would hopefully include an older sata bios) or is this action plain unsafe?
Cheers guys
__________________
Wii: 1792 1527 2926 7945 :: Xbox Live: BioSnipr :: PSN: Biosnipr :: Steam: BioSniper
Frankly this thread has become a bunch of methed up old women in a hat store.
BioSniper is offline   Reply With Quote
Old 3rd Aug 2006, 02:32   #2
riluve
Hypermodder
riluve's Avatar
riluve has yet to learn the way of the Dremel
Cheers guys
It really just boils down to the OEM/Manufacturer. If they still provide/support the older version(s) (unlikely), then it shouldn't (80-90%) be a big issue.
__________________
Sorry if I sound like a jerk. I mean I am a jerk, but I don't mean to come across as one.
http://www.riluve.com
riluve is offline   Reply With Quote
Old 3rd Aug 2006, 03:29   #3
hitman012
hitman012 has yet to learn the way of the Dremelhitman012 has yet to learn the way of the Dremelhitman012 has yet to learn the way of the Dremel
Should be fine... I've done it quite a few times. It's probably worth resetting the CMOS after the flash, though.
__________________
"Nothing is more practical than a good theory"
- Kurt Lewin
hitman012 is offline   Reply With Quote
Old 3rd Aug 2006, 04:38   #4
riluve
Hypermodder
riluve's Avatar
Oh, good call, I should have thought of that.
__________________
Old 3rd Aug 2006, 08:18   #5
BioSniper
BioSniper's Avatar
Cheers guys. Abit is nice enough to provide all the BIOS' on their site from first manufacture to last release.
The only other concern is that in the last release I believe it also updated the Silicone Image SATA/RAID BIOS also and im not too sure if the later version would either be re-flashed back to an older version or if it would be incompatable.
__________________
Old 3rd Aug 2006, 08:54   #6
airchie
Mod Master
airchie's Avatar
airchie has yet to learn the way of the Dremel
If an older version which contains an update for the SIL controller is available, flash to it as it will deffo be compatible with the bios you're flashing along with it.
__________________
Laptop:C2D P8600 2.4GHz, 4GB, 9800GTS, 120GB SSD, 15" 1680x1050, Vista64
Projects: 1.2TB Fileserver housed in a cardboard box!|Retro HTPC for my GF.
Originally Posted by astralwandrer
Being a legitimate customer of the games industry is increasingly like being in a relationship with an abusive spouse.
airchie is offline   Reply With Quote
Old 4th Aug 2006, 18:28   #7
BioSniper
BioSniper's Avatar
Well. I dont know if I should try or not and potentially kill my mobo.
List of updates: http://www.abit.com.tw/page/uk/downl...YPE=Socket%20A
I have the top one.
I believe the original one is the one dated: 2003/12/01 BIOS: nf7d21.exe BIOS ID:2.1
Anyone think that this one may work again?
__________________
Old 4th Aug 2006, 19:07   #8
scq
Hypermodder
scq's Avatar
scq has yet to learn the way of the Dremel
I have the top one.
If it does kill your mobo (unlikely), I believe A-bit provides BIOS chips for a free, or low shipping fee. I'm not sure if they still do that, but last time I checked was only about a year or so ago.
scq is offline   Reply With Quote
Old 4th Aug 2006, 21:09   #9
BioSniper
BioSniper's Avatar
Well. I flashed and it was a success. Sadly though it doesnt seem to have changed anything performance wise. *sighs* maybe its just time for a new system.
__________________
Old 4th Aug 2006, 21:57   #10
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.
Maybe so. Have you tried a 3rd party BIOS? I flashed my NF7-S with a TicTac BIOS a while ago, and it helped no end with performance (well... 5% and a much friendlier BIOS). Maybe it's just time for a good format instead?
__________________
The Good, The Bad, The Ugly, The Zlad!, The Wut?!, The Kempness
Krikkit is offline   Reply With Quote
Old 4th Aug 2006, 22:46   #11
BioSniper
BioSniper's Avatar
My install is fresh sadly so there is nothing now that I can do. Perhaps something finally gave up and died though I honestly have no idea just my performance gets worse pretty much every day with or without format and no matter what drivers I try (old or new)
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
