Thread Tools |
#1 |
Brett Thomas
Seagate quietly makes drives quieter
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo |
#2 |
Uninformed Opinionist
It's a real shame that they dont mark them any different... something like 7200.9.2 would have been perfect.
#3 | ||
Mod Master
__________________
<+DougEdey> you getting PGR4 mitmit? <mitmit> not me, Geoff is probably wanking like a lepper at the thought of it though |
#4 |
Ecky thump
Moderator
Barracuda 7200.9 may remain the same, but I bet the model number, ST3160212A or whatever, changes or their spec sheets are going to be nonsense. And most proper stores show model numbers.
Code:
Physical: (Current ST3160212A, ST3160212AS)
Height (inches/mm): 1.028/26.1
Width (inches/mm): 4.00/101.6
Depth (inches/mm): 5.78/146.99
Weight (lb/g): 1.28/580
__________________
Nobody's perfect. But being a Yorkshireman is as close as you can get. Last edited by cpemma; 9th Aug 2006 at 19:32. |
#5 | |
7-2 offsuit
Umm, I could be a complete retard here, but isn't 580g just "slightly more" (80g more) than 500 grams (500g)?
__________________
| dragontail |
| View Public Profile |
| Find More Posts by dragontail |
#6 |
Lethargic
80g is 16% - not really 'slight', but I'll concede the point.
![]() As great as this sounds, I still think I'll steer clear. Maybe I've been unlucky with Seagate, but three out of three of their drives have died on me within six months. OK, they were replaced, but that isn't the point. And they weren't all the same drives in the same location, either - two desktop drives, one PATA, one SATA and one laptop drive...
__________________
Core i7 920 D0 @ 3.8GHz | 6GB Corsair 1600MHz | Gigabyte EX58-UD5 | XFX 4870X2 2GB | 4TB | WUXGA |
#7 | |
LANCandy
#8 |
What is a Dremel!?
Moderator
It's closer to 600 grams than 500, so it should have been "slightly less than 600 grams". Just pedantry
![]() And it's nice to see them making the drives quieter, but I wish they'd make them faster as well (or make the improvements to to the better 7200.10s). Then again, in a quiet office system or similar, performance isn't a huge issue.
__________________
"Nothing is more practical than a good theory" - Kurt Lewin |
#9 |
Banned
To be honest, anything below 250 is pretty much useless for price concious RAID users. 250's and 300's are at the best £/GB mark last time I checked, depending on the individual drives. Still, good news, but Seagate needed to lower the size of their drives, I bought one and had to stick it in a floppy bay because the internal 3.5's were all too short for the drive to actually fit in, which was pretty poor I thought.
| specofdust |
| Find More Posts by specofdust |
#10 | |
Brett Thomas
![]() As for your second point, Seagate has not passed on any new model number for the change, though I see what you mean and think they probably would have some difference.
__________________
#11 | |
Ecky thump
Moderator
I mean, 6mm off 26mm, that's a major redesign, not just tinkering with an existing product line.
__________________
Nobody's perfect. But being a Yorkshireman is as close as you can get. |
#12 | |
Brett Thomas
__________________
#13 | |
Richard Swinburne
bit-tech Staff
/votes Cpemma for QC department at Seagate. |
#14 | ||
6 screens / 1 card
__________________
It's not about how life treats you, it's about how you treat life. Last edited by Tyinsar; 9th Aug 2006 at 23:50. |
#15 |
Minimodder
I have one of each here (both 80GB models SATA). Yes, the model series numbers have not changed - they are both 7200.9 series drives, however the specific model numbers per drive have changed. In the case of these two 80GB models, the bigger, older model is: ST3808110AS, the slimmer, newer model is ST380811AS. There is quite a big difference between the two, and if you are buying one in a b&m store, then it is very obvious which is which. If you are buying online you will need to check exact model numbers. Note, the '0' has been dropped for the newer models, not added (at least on the 80GB version. The newer versions have actually been in production, and in retail stores, for a month or so now.
I admire Seagate for their lack of marketing hoopla. They differentiate with numbers, and us enthusiasts can pick and choose as we please. Congrats S/G. |
#16 |
Madeira's banana is the best!!!
arent disk sizes standardized? the height on these ones is smaller.....
nice and quiet disks, just what the doctor ordered.
__________________
RENEGADE X CONTEST! <---- CLICK if you want to win a free Command & Conquer 4 beta key! |
#17 | |
Banned
![]() As for disks being a standard size, that's what I always thouht, untill I got the seagate that wouldn't fit in my 3.5" drive bays. I had 5 other drives in other bays at the time, and they all fitted, so to find a disk that didn't fit was extremely odd. |
| specofdust |
| Thread Tools | |
