Go Back   bit-tech.net Forums > Recreation > Gaming
Closed Thread
Thread Tools
Old 11th Aug 2006, 10:26   #1
nicotine
Multimodder
nicotine has yet to learn the way of the Dremel
Screenshots in Need for Speed Underground 2
Does anyone know if there is ingame capability to take screen shots in this game or will I have to turn to third-party apps such as Fraps and such.
nicotine is offline
Old 11th Aug 2006, 12:35   #2
imkeller
Multimodder
imkeller has yet to learn the way of the Dremel
Try the Print Screen button
__________________
Intel Q6600 @ 3Ghz | Nvidia 8800GTS G92 512mb @ 752Mhz | 250Gb HDD w/ 32mb cache | 4GB (2 x 2GB) Corsair XMS2 RAM | 20" Samsung SyncMaster 2032BW | DVDRW | Coolermaster Centurion 5 Case
imkeller is offline
Old 11th Aug 2006, 15:20   #3
nicotine
Multimodder
Yeah I did, if they are saving screens I don't know where they're saving them at.
nicotine is offline
Old 11th Aug 2006, 19:12   #4
fev
Industry Fallout
fev's Avatar
fev has yet to learn the way of the Dremelfev has yet to learn the way of the Dremelfev has yet to learn the way of the Dremelfev has yet to learn the way of the Dremel
to your clipboard....
__________________
I know what I'm doing, do you?
Follow me on Twitter..go on
fev is offline
Old 11th Aug 2006, 19:15   #5
Glider
/dev/null
Glider's Avatar
Glider has yet to learn the way of the DremelGlider has yet to learn the way of the DremelGlider has yet to learn the way of the Dremel
Press print screen, open paint/photochop and paste... You'll see that the image is there...
__________________
There Are 10 Types Of People, Those Who Know Binary and Those Who Don't
Glider is offline
Old 11th Aug 2006, 20:36   #6
nicotine
Multimodder
Yeah I know that, but I'm looking for a game supported screenshot generation feature.
<--extremely lazy.
nicotine is offline
Old 11th Aug 2006, 20:47   #7
Tim S
Padded Up
Tim S's Avatar
Tim S - it's over 9000!!!!!!!!1!1!1!!!Tim S - it's over 9000!!!!!!!!1!1!1!!!Tim S - it's over 9000!!!!!!!!1!1!1!!!Tim S - it's over 9000!!!!!!!!1!1!1!!!Tim S - it's over 9000!!!!!!!!1!1!1!!!Tim S - it's over 9000!!!!!!!!1!1!1!!!Tim S - it's over 9000!!!!!!!!1!1!1!!!Tim S - it's over 9000!!!!!!!!1!1!1!!!Tim S - it's over 9000!!!!!!!!1!1!1!!!Tim S - it's over 9000!!!!!!!!1!1!1!!!Tim S - it's over 9000!!!!!!!!1!1!1!!!
www.fraps.com - that has a screenshot facility (jpg, png, bmp)
__________________
Global Technical Marketing Manager @ ASUS
ASUS on Facebook | Tech in Style | Republic of Gamers
ASUS Tech Support | Global Tech Support Helplines
Tim S is offline
Old 12th Aug 2006, 00:06   #8
dragontail
5bet Bluffer
dragontail's Avatar
dragontail has yet to learn the way of the Dremeldragontail has yet to learn the way of the Dremeldragontail has yet to learn the way of the Dremeldragontail has yet to learn the way of the Dremeldragontail has yet to learn the way of the Dremeldragontail has yet to learn the way of the Dremel
I second that, it displays youre FPS and can take movies too...
__________________
Project COMTAR
Acoustic Guitar, meet Mini-ITX
dragontail is offline
Old 17th Aug 2006, 18:07   #9
[1N0V471V]
Multimodder
[1N0V471V] has yet to learn the way of the Dremel
You are seriously too lazy to press print screen, open paint, paste the screen from the clipboard and save the file?
WOW
__________________
Intel Core 2 Duo E6400 @ 3.6GHz - Abit AW9D-Max
2x1GB Muskin Redline XP2 PC8000 - EVGA 8800GTS 640MB
Corsair HX-620 - Lian Li V1100 - 250GB Seagate Barracuda SATA
Dell 2007WFP - Danger Den TDX Universal Top - Windows XP Professional
Dell E1505 - 2GHz Core 2 Duo T7200 - 1GB DDR533
ATI Radeon X1400 - 15.4" WSXGA+ with TrueLife
60GB Samsung SATA 5400RM HDD - DVD+/-RW
[1N0V471V] is offline
Old 17th Aug 2006, 19:03   #10
Spacecowboy92
Gettin' Lazy
Spacecowboy92's Avatar
Spacecowboy92 has yet to learn the way of the Dremel
Well you would have to close the game every time you want to save or view what you've got.
__________________
Spacecowboy92 is offline
Old 17th Aug 2006, 19:15   #11
fev
Industry Fallout
fev's Avatar
close?
you mean alt-tab surely?
__________________
fev is offline
Old 17th Aug 2006, 19:36   #12
woof82
Mod Master
woof82's Avatar
woof82 can run Crysiswoof82 can run Crysiswoof82 can run Crysiswoof82 can run Crysiswoof82 can run Crysiswoof82 can run Crysiswoof82 can run Crysiswoof82 can run Crysiswoof82 can run Crysiswoof82 can run Crysiswoof82 can run Crysis
Alt - tab with a program as clunky as NFSU2 would take ages. Unless you happen to have 4gigs of ram.
__________________
woof82 is offline
Old 17th Aug 2006, 19:49   #13
fev
Industry Fallout
fev's Avatar
512mb of RAM, works fine... this is getting silly
__________________
fev is offline
Old 17th Aug 2006, 19:54   #14
Jokkocze
Hypermodder
Jokkocze's Avatar
Jokkocze has yet to learn the way of the Dremel
Yupp, Works fine with 512mb ram >_>
__________________
Main rig: Intel C2D E8400 @ 3.91ghz | 6GB Corsair Dominator | EVGA GTX 280 SSC | ASUS P5E | 1x150gb Raptor & 3tb storage | 550w Corsair PSU | 2x Samsung T220
HTPC: Intel C2D E8400 | 2GB Corsair XMS | XFX 8800GT 512mb (Passive) | ASUS P5Q-VM | 4x1.5TB | 550w Corsair PSU | Sony 46V4500
Jokkocze is offline
Old 17th Aug 2006, 20:44   #15
riggs
^_^
riggs's Avatar
riggs can run Crysisriggs can run Crysisriggs can run Crysisriggs can run Crysisriggs can run Crysisriggs can run Crysisriggs can run Crysisriggs can run Crysisriggs can run Crysisriggs can run Crysisriggs can run Crysis
WOW
For just capturing a few screenshots it'd be ok, but if he/she's wanting to capture a large amount, then the 'alt-tab paste' idea would be too time consuming. It'd be like giving a photographer multiple rolls of film, with x1 exposure on each.
Like others have suggested, try FRAPS - I've only ever used it for capturing video, but it does a damn fine job.
__________________
Bally Jerry pranged his kite right in the how's your father. Hairy blighter, dicky-birdied, feathered back on his Sammy, took a waspy, flipped over on his Betty Harper's and caught his can in the Bertie!
PSN ID: buster2006
riggs is offline
Old 18th Aug 2006, 01:22   #16
eek
CAMRA ***.
eek has yet to learn the way of the Dremeleek has yet to learn the way of the Dremel
Not needed this for a while so not sure how things have move on, but I always used to use Hypersnap. I always found it really good and easy to use
eek is offline
Old 19th Aug 2006, 07:06   #17
Pookeyhead
It's big, and it's clever.
Pookeyhead's Avatar
Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.
Pointless thread... you've got your reply. Use FRAPS... it's generally acknowledged amongst the gaming community to be the defacto app for screengrabs, game vid creation, and FPS benchmarking. It automatically applies hot keys for each function, and runs leanly with little system overhead.
.... or you could press Prt Scr and paste it into PS.
Google Hypercam 2 as well... that will basically make a vid of whatever is on your desktop.. useful for making training vids within windows.
If non of those three methods satisfy your needs, then your needs are excessive, or your far too lazy
__________________
MAIN RIG |Intel i7 3960X @ 4.7GHz ¦¦ Asus Rampage IV Extreme ¦¦ 16Gb Mushkin DDR3 2133 ¦¦ 512GB Samsung 830 SSD ¦¦ 4TB of HDD Storage ¦¦ 4GB EVGA GTX670 Superclocked SLI ¦¦ Corsair 650D ¦¦ Eizo ColorEdge CG303W & Dell 2007FP ¦¦ Logitech Z623
EARTH| Celeron E3200 ¦¦ Gigabyte G31M-ES2L ¦¦ LSI SAS8704EM2 ¦¦ 3TB RAID5 ¦¦ Headless - VNC administered
MOON | Thecus N3200pro 3TB RAID5
Pookeyhead is offline
Old 7th Nov 2006, 15:39   #18
crusader_DX
What's a Dremel?
crusader_DX has yet to learn the way of the Dremel
you should try ACA capture PRo,,,, with it you can capture anything, both images and videos, shown in your screen....of cause,,, including the images when you play need for speed......
crusader_DX is offline
Old 22nd Nov 2006, 07:26   #19
Samurai75007
Multimodder
Samurai75007's Avatar
Samurai75007 has yet to learn the way of the Dremel
Xfire also offers an in game screen capture.
Samurai75007 is offline
Old 22nd Nov 2006, 16:49   #20
nicotine
Multimodder
Thank you for bumping my thread from July.
Could a mod please close this?
nicotine is offline
Closed Thread
Tags
pc
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
