#1 |
Pewlius Caesar
bit-tech Staff
PSU preview palooza
__________________
#2 |
Supermodder
too messy/weird/goingaroundobstacles for me, the fps booster that is.
__________________
ibm thinkpad x40 |
| fartonmyear |
| View Public Profile |
| Find More Posts by fartonmyear |
#3 |
When did I get a custom title!?!
the booster has a very specific market such as small form factor pcs that want to run sli and it does the job well.
__________________
Sn45g game server mod My Electronics Site![]() Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit |
#4 |
Ginger Nut
Basically, there's only a description of one proper PSU..
I look forward to a full review when it comes.
__________________
Kirk, Spock, McCoy, and Ensign Ricky are beaming down to the planet. Guess who's not coming back. |
#5 |
Ultra csavarkulcs
Banned Join Date: Mar 2006
the fsb booster seems a bit weird, there's no pci bracket or anything ? to get the power into the case - seems like a pretty weird decision, but at least it works, personally i don't like that solution
the cables coming out the back of the psu usually aren't seen, and you can still do a good job at hiding them with them like that Last edited by yahooadam; 13th Aug 2006 at 21:02. |
#6 | |
Bwahahahahaha
Not that I need one, but if I were, I'd be removing the entire front bezel/lights if possible. Looks hideous I'd definitely prefer to have it mounted a little further back, un-seen behind a bezel. Could mod a custom grille and mount a fan into the case bezel if needed... Though I'd imagine one could find a 5.25" HDD top-mount cooler for it too ![]() Also, thinking about it .. the Hyper seems a bit funny in design. Surely it'd be a better idea to see right-angled connectors in with it, as an option? Even if it was a bit more to buy, it'd make it all the more compatible.
#7 |
Supermodder
The Hiper Type R II PSU looks intersteting. But I am kinda 50/50 happy with the PSU connections be right under the PSU. I hope this PSU is quit like the past Type R.
__________________
Project Log: Knight Rider CWC |
#8 |
The Froggy Poster
Though having the connections on the bottom/top of the PSU like that might be good for accessibility, it makes wire management a living hell
__________________
Desky E8400 @ 4.0 1.42v; P5K-E WiFi; 4x1 Kingmax Mars 1066 @ 1129 CAS 5; 2x [TOO CHEAP TO SPONSOR] 4850 @ 675/1050; Enermax Liberty; WCing in a CM690 |
#9 | |
Pewlius Caesar
bit-tech Staff
__________________
#10 |
Can't mod my way out of a paper bag
Depends on your case. On mine I have a 12x13 Mobo, so there isn't a ton or room between the PSU and the 5.25" bays and both have cables coming out the back competing for space. I think when i go quad SLi I'm going to take a hard look at that Type R.
__________________
Notice: If we see you flaming we will assume you are on fire and take appropriate measures
- The Bit-Tech Fire Brigade. |
#11 |
Richard Swinburne
bit-tech Staff
*******s copying my idea about using audio leads like that! ARGH! I used an 8 pin plug for an ethernet connector but my soldering skills werent good enough 2 years ago to do my PSU at the time!
/patent/patent/patent/patent/patent/patent/patent/patent/patent/patent |
#12 |
The Froggy Poster
The only real "advantage" it has is for tweakers who are always in their CASE. For those of us running a test bench, this thing also eats up a lot of room. I mean i have a whole lotta room behind the PSU, but not much beside it - there's opticals and HDDs and watery bits there...
__________________
#13 |
Ahhh Jimlad
Erm, the pins are located in the PSU, unlike the older hyper.. where the pins were in the plugs.
Surely thats an electric shock risk, should someone find their fingers probing around the PSU while its turned on ? |
#14 | |
Ultra csavarkulcs
good spot, althought it may not be too harmful, as its 12v, and not that high a wattage ... actually ... hmm i dunno |
#15 | |
Why not? I own a domain to match.
I'll assume the final one includes some sort of plastic cover for those. It wouldn't make sense to even have it that way unless the female connectors were shorter than the male ones, which would make for less bulky connectors on the outside.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net 40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8 MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD |
#16 |
Multimodder
i always leave my pc on and pluged in when i work on it. less risk of a harmful static discharge that way. doubt a computer power supply could deliver much more than a burn.
#17 |
The Froggy Poster
They don't mean static discharge.
In the Hiper units, the +12V, +5V, +3.3V and GND pins are exposed within the DIN connectors. If you're like me, a guy who feels around for the plug before plugging something in, there's a good chance that you'll stick a finger in and connect those poinst through the skin. Now, one, you will shut the system down - you hope, and two, considering closed quarters, you'll likely jerk your hand back and slice it open on the edge of the optical rack. Get the picture?
__________________
#18 | |
Ultra csavarkulcs
a proper earthing strap is a much better idea |
#19 | |
What is a Dremel!?
Moderator
Skin has a pretty high resistance - unless you're poking around inside your computer with really sweaty hands, the shock won't be much more substantial than you'd get from a 9V battery (the poles in the sockets seem a similar distance apart) and the resistance would be too high to allow enough current flow to burn.
They do have safety standards for these things... Quote:
__________________
"Nothing is more practical than a good theory" - Kurt Lewin |
#20 |
Supermodder
Most likely, Hiper are taking the "if you don't like the plugs on the bottom, buy the older model" approach. Which is fair enough.
| Thread Tools | |
