#1 |
Pewlius Caesar
bit-tech Staff
First Look: Abit AW9D-MAX
__________________
#2 |
I pwn all your storage
Looks like you can't wait for a review sample Tim.
#3 |
BSc... finally
I like the color scheme... and the performance of course. I'd really like to switch to Conroe but I ain't got the money right now.
Any advices which board to buy then? I'd love to keep my gfx card to save some money... and yea it's AGP.
__________________
"The most merciful thing in the world, I think, is the inability of the human mind to correlate all its contents. We live on a placid island of ignorance in the midst of black seas of infinity, and it was not meant that we should voyage far." Blame it on Cheaps! [now a social group]
#4 | |
Pewlius Caesar
bit-tech Staff
__________________
#5 |
Banned
Well, I'm seriously considering my current(junk) setup, and this thing looks encouraging. Can't wait for a review, here's hoping it's stable and clocky. If so, I just found my next mobo
| specofdust |
| View Public Profile |
| Find More Posts by specofdust |
#6 |
ITS OVER 8000!
i wish abit learned to put more PCI slots in instead of express x 1 slots...
on that board, you cant have a dual GPU set-up and then an X-FI and a TV tuner..... silly. |
#7 |
Banned
No! We need a move to PCI-E, PCI is crappy and incredibly limited, the sooner we get rid of it the better.
| specofdust |
#8 |
Lethargic
Well, until some soundcard manufacturers start trying to make PCI-E soundcards, rather than saying, "It's too hard", a single PCI slot that is lost if you go dual graphics seems like a pretty bad oversight - at least in slot positioning.
All-in-all, though, that looks quite a nice board - if it's already outperforming Bad Axe in its pre-prod state, when the final BIOS is released, it might have tightened up some more. ![]() I guess I'm a bit torn about this - potential for being an overclockers dream, lots of space round the CPU, passively cooled... just the PCI slot and the odd emptiness of the back panel (more USB ports would have been nice - possibly even a 4-pin or 6-pin firewire port...)
__________________
Core i7 920 D0 @ 3.8GHz | 6GB Corsair 1600MHz | Gigabyte EX58-UD5 | XFX 4870X2 2GB | 4TB | WUXGA |
#9 |
Banned
The thing does look like it has a couple of USB headers below the southbridge, and a firewire port to the left of, and behind the two PCI-E 1x slots, but that may be something else.
I'm really excited about this board, if it's everything Tim seems to think it's going to be, it looks perfect for a reliable conroe setup. |
| specofdust |
#10 | |
Pewlius Caesar
bit-tech Staff
__________________
#11 |
I feel your presents.
IMO, the layout of the PCI/PCI-e slots is crap. If this board is aimed at overclockers, surely they must realise that you're going to have an sli setup and with most of them taking up two slots, you're left (only just) with one PCI-e x 1 slot. Wowee. They could easily have stuck another PCI or PCI-e slot on at the bottom to accomodate an existing sound card. I know I wouldn't put up with onboard sound, knowing that it's still inferior to 'proper' sound cards.
Apart from that niggle, it's looking good.
__________________
MSI X58M - i7 920 4Ghz - 6GB Corsair - GTX260 648/2520 ::: Vote for bit-tech T - theevilelephant - "it sounded like bouncing around on a pogo stick, screaming in chinese while occasionally throwing a cat at a door." |
#12 |
Banned
Actually, this is something that's starting to bug me tim, why are all PCI/PCI-E layouts utter s***e? Manu's always make slots that obscure each other if filled, or obscure USB or some other connectors. I know space is limited, but couldn't they just give us fewer usable slots(say 4 usable slots) instead of trying to give us 6 that are so crammed together that 2-3 is the best we can ever use? It used to be that with a good mobo you could get your graphics card in there, and then basicly everyone had more PCI slots then they'd ever need, but it seems like these days that every type of slot is some hyper-rare commodity, and even in the most expensive mobo's we're starving for lack of the things once we stick a couple of cards in there.
Why must this be the case? |
| specofdust |
#13 | |
ITS OVER 8000!
most top end PCs use at least 1 PCI slot, and also, why bother putting it next to the PCI-E x16, when dual slot coolers on the big GPU's are now the norm. you cant get anything in to the PCI slot if your using X18/19 crossfire... |
#14 | |
Richard Swinburne
bit-tech Staff
Also, PCIe slots take far smaller and fewer traces to wire unlike PCI and PCI slots all generally have to be routed together because they all sit on the same bus. Since they originate from the southbridge this is often in the bottom-most part of a mobo and there needs to be a minimum 2 slot gap for SLI/CF so you're already 3 slots down out of a potential 5 or 6. Epox was one of the only mobo manufacturers to implement 6 PCI slots back in AGP/PCI days, most others included 5 and space for other connectors which is still the case so you're left NOW with just space for 2 at most considering everyone has to offer firewire, HD sound, 10 million USB ports, extra SATA etc I hope that reads ok, Ive been looking at a PC too long today already to have the energy to re-read it right now. |
#15 |
Or a 7900GTX
![]() Bindi, the trouble is that, looking at the board, abit could easily have fitted another pci or pci-e slot under the existing pci slot. It's a choice of either sli or pci sound card. I know there's single slot gpu's, but to reiterate that abit are aiming for overclockers, no self-respecting mhz-whore is going to have anything less than double slot gpus in sli.
__________________
MSI X58M - i7 920 4Ghz - 6GB Corsair - GTX260 648/2520 ::: Vote for bit-tech T - theevilelephant - "it sounded like bouncing around on a pogo stick, screaming in chinese while occasionally throwing a cat at a door." Last edited by kenco_uk; 1st Sep 2006 at 15:14. |
#16 |
Richard Swinburne
bit-tech Staff
Well it also comes down to mobo noise as well, if you pack too much in you get more noise and less stability.
#17 |
Pewlius Caesar
bit-tech Staff
Mankz, if we lived in the years of legacy, technology would never move forwards. For example, if we were still using socket 478, we wouldn't have something like Core 2 Duo - the same is true about Socket A. Don't get me wrong, I understand your point of view and Abit is marketing the AW9D-MAX as an overclocker's board. If you want a combination of overclockability and expansion, DFI's boards are probably a safer bet.
There would be a second PCI slot if Abit had chosen not to include AudioMAX along with the second SATA controller. However, Abit wanted to go that way with its sound solution, as the company believes it is slightly higher quality than an embedded solution. I agree with that sentiment during my time using Abit products - there tends to be less interference, but it is not completely gone. It's horses for courses in that respect. IMO, anyone who is really serious about having a fast system would be watercooling the two video cards they've installed.
__________________
#18 |
Multimodder
At least its nice and sexy black as opposed to bright neon colors.
#19 |
Agreed, for a mobo, it's teh sex!
__________________
#20 |
The Froggy Poster
Nevermind what it can do, what i'm interested in is if this board will be worth something like the Abit of Past, or if it'll just come out with 10,000 forum issues...
__________________
Desky E8400 @ 4.0 1.42v; P5K-E WiFi; 4x1 Kingmax Mars 1066 @ 1129 CAS 5; 2x [TOO CHEAP TO SPONSOR] 4850 @ 675/1050; Enermax Liberty; WCing in a CM690 |
| Thread Tools | |
