RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Closed Thread
Thread Tools
Old 1st Sep 2006, 13:11   #1
Garside
Supermodder
Garside is on a distinguished road
No way to switch off Vista startup music
http://www.bit-tech.net/news/2006/09...startup_music/
Garside is offline
Old 1st Sep 2006, 13:17   #2
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
NOOOOOOOOOOOES!! Stop making Windows for idiots and telling me how to a) use my pc and b) "use it as a method to tell if my speakers are plugged in/turned on". I an not that retarded, thank you.
Time for the registry hacks to start methinks.
The Xbox and PS one's are fine since a) it's only ever at home, not everyone in your office every-single-morning you listen to 50 startup sounds or b) Xbox/PS take 3 seconds to boot and you can change the Xbox one if you edit the firmware iirc and I generally ad-block my TV til the game starts.
Windows sounds are OFF, all of them, forever. Don't hog my resources more than you need to, thank you.
Bindibadgi is offline
Old 1st Sep 2006, 13:20   #3
Kaboom22
Multimodder
Kaboom22 is on a distinguished road
I wouldn't want to be in a large room full of PC's with monitor speakers connected...
Doub't it will be long before someone figures out how to mod it though.
Kaboom22 is offline
Old 1st Sep 2006, 13:24   #4
ElThomsono
Mod Master
ElThomsono's Avatar
ElThomsono will become famous soon enough
Another day at the microsoft support call centre:
Microsoft: Hello, how may I direct your call?
Customer: Hi, uh, how do I turn off that startup sound?
Microsoft: You can't.
Customer: WTF? Can I change it?
Microsoft: No, and a registry hack's a breech of the EULA.
Ex-Customer: I'm buying a Mac.
*Click*
__________________
If it's broken, I can fix it. But that's ******.
ElThomsono is offline
Old 1st Sep 2006, 13:44   #5
AlexB
Web Nerd and WC Addict
AlexB's Avatar
AlexB will become famous soon enough
"1. A spiritual side of the branding experience. A short, brief, positive confirmation that your machine is now conscious and ready to react. You can turn on your Vista machine, go eat some cereal, while your machine is cold booting and then this gentle sound will come out telling you that you can log in. You won’t need to wait for your machine to startup, he says.
How long does a vista PC take to boot??
__________________
Whenever I smell asphalt, I think of Maureen. That's the last sensation I had before I blacked out; that thick smell of asphalt. She said she'd fix my bike. Free. No strings attached. I shoulda've known then that things were never that simple. Yeah, when I think of Maureen, I think of two things: Asphalt, and trouble.
AlexB is offline
Old 1st Sep 2006, 13:46   #6
Garside
Supermodder
Good question
Garside is offline
Old 1st Sep 2006, 13:48   #7
Tile
Banned
Tile is on a distinguished road
Now this is stupid. I wonder if the folks at MS think correctly. I don't want to pay $400 for an OS that annoys me with nasty sounds and have no posibility to turn them off.
Tile is offline
Old 1st Sep 2006, 13:49   #8
Paradigm Shifter
Lethargic
Paradigm Shifter's Avatar
Paradigm Shifter will become famous soon enough
*Click*
Hang on - don't Macs have a startup sound you can't disable as well? All the Macs in my lab do...
Anyway, you can't turn the sound off? Well that's just bloody stupid. Pardon my French.
__________________
Core i7 920 D0 @ 3.8GHz | 6GB Corsair 1600MHz | Gigabyte EX58-UD5 | XFX 4870X2 2GB | 4TB | WUXGA
Paradigm Shifter is offline
Old 1st Sep 2006, 13:58   #9
Tile
Banned
I think that on the pirated copyes of Vista someone will add an option for disabling the startup sound. I say this because in Romania the piracy rate among average PC users is very high.
Tile is offline
Old 1st Sep 2006, 14:01   #10
specofdust
Banned
specofdust's Avatar
specofdust has a spectacular aura aboutspecofdust has a spectacular aura about
Does anyone seriously think this won't be hacked out of Vista within days?
Ok it might require some reg hacking or a program download, but it's not going to be hard and I'm quite sure it'll be possible.
specofdust is offline
Old 1st Sep 2006, 14:04   #11
Matkubicki
Supermodder
Matkubicki is on a distinguished road
The main problem i have with windows sounds is that they always come out unbareably loud and distorted from my 5.1 speakers. Which, since they are shared with the media centre tend to be turned up pretty high. If this is in the final version it will put me off till its fixed.
How about just deleting the sound file, bet that'd fix it!
Matkubicki is offline
Old 1st Sep 2006, 14:07   #12
Flibblebot
Free from artificial flavourings
Flibblebot's Avatar
Flibblebot has a spectacular aura aboutFlibblebot has a spectacular aura aboutFlibblebot has a spectacular aura about
Well, unless the sound file is hard-coded into one of the kernel files, couldn't you just replace the sound file with a blank one?
__________________
My uber-system: 66Mhz 486DX2, 8Mb RAM, 20Mb hard drive, 256 colour VGA adaptor (goes all the way up to 800x600!), keyboard AND serial mouse
Flibblebot is offline
Old 1st Sep 2006, 14:10   #13
specofdust
Banned
specofdust's Avatar
I sense an "Allyourbasearebelongtous.mp3" startup sound file coming on
Old 1st Sep 2006, 14:24   #14
_Kat_
Minimodder
_Kat_ is on a distinguished road
I don't see how this is a problem since it's only a matter of weeks before someone comes up with some sort of hack to disable the start-up sound/music.
_Kat_ is offline
Old 1st Sep 2006, 14:26   #15
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
But don't you just find it on a level of arrogence that only Sony seems to achieve that they decided this for you?
Old 1st Sep 2006, 14:31   #16
Krikkit
Don't panic!
Krikkit's Avatar
Krikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to beholdKrikkit is a splendid one to behold
Well said Bindi (although I don't subscribe to your fanatical regime of Sony-hatred ). What a bloody ridiculous idea.
We aren't children, don't treat us that way. If I want my PC to be silent, it damn-well will be until I tell it otherwise, not Microsoft.
__________________
|E8400 @ 4.4GHz|WC: 2*120.1 GT's, MCP350, Storm G5|4GB Dominators|DFI LT X48-T2R|8800GT|74GB Raptor|Chieftec BA01|OCZ ModXStream 600W|Dell 2208WFP|
The Good, The Bad, The Ugly, The LOL!!1!!1!, The Zlad!, The Kempness, The Braaaaaains...
Krikkit is online now
Old 1st Sep 2006, 14:38   #17
FIBRE+
Ultramodder
FIBRE+'s Avatar
FIBRE+ is on a distinguished road
Five letter word, starts with a C ends with an S and women get very offended by it. Are they just trying to pee people off?, bacause theres another reason to put put people off buying it.
With regards to people saying it will be hacked, yer i'm sure it will but TBH it shouldn't have to be
__________________
++ASUS SLI Premium | X2 3800 @ 2.6ghz | XP-120 | 2GB Mushkin | 8800 GT | XFI Music | Seagate 320GB \ Samsung F1 1TB | 520W Corsair HX | 23" Dell S2309W ++
++Zotac 9300 Mini ITX | Intel E5200 | Scythe Shuriken | 2GB Corsair | 8600 GTS (Passive) | WD Black 2.5" 320GB \ Samsung F2 Eco 1TB | Corsair VX 450W | 42" Panasonic Viera++
Canon 400D | Sigma 17-70mm f/2.8-4.5 | Canon 75-300mm f/4.0-5.6 | Sandisk Extreme III 4GB++My Ebay++
FIBRE+ is offline
Old 1st Sep 2006, 14:38   #18
Dezza
Minimodder
Dezza is on a distinguished road
__________________
Portfolio
Dezza is offline
Old 1st Sep 2006, 14:45   #19
Stompy
Ultramodder
Stompy is on a distinguished road
Anyone got a recording of the sound in question?
__________________
PC (Now out of use): Athlon 64 3000+ Winny | Asus A8N-SLI | 1024mb OCZ Premier | 6600GT 128mb | 160GB WD | NEC 3520 DVDRW | Coolermaster Centurion 530 | Hiper Type-R 480w
Laptop: Dell Studio XPS 13 | Core 2 Duo P8600 2.4ghz | 4gb Ram | GeForce 9500M 256mb | 320gb 7200rpm | DVDRW | 13.3" LED WXGA
Stompy is offline
Old 1st Sep 2006, 14:52   #20
hitman012
What is a Dremel!?
Moderator
hitman012 has a spectacular aura abouthitman012 has a spectacular aura abouthitman012 has a spectacular aura about
Note it's not really the startup sound, but the sound that plays before the login screen when the Windows logo with the aura fades in. Ah well... someone will find a way to get rid of it.
__________________
"Nothing is more practical than a good theory"
- Kurt Lewin
hitman012 is offline
Closed Thread
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
