RSS
Reply
Thread Tools View Mode
Old 1st Sep 2006, 21:29   #1
GoTaLL
Supermodder
GoTaLL is on a distinguished road
Skull case..
Hi again ..
now im in the middle of the dreamhack winter rush to get stuff done..
this is a case that been sponsored by Gtek.se
its a berzerk case and perfect for lan events cause it got a handle ..
well im in my Painting period of my life "again".
its a black case .. i just lovem black..
it looks really cool really.
ok start of painting,, looks like my son would have made it.. but i hopefully can make something out of it.. :P
clearcoating.. and then some more..
second time clearcoating .. starts to look sweet i think
__________________
And do visit my site for a few more cases
www.customengraver.se
GoTaLL is offline   Reply With Quote
Old 1st Sep 2006, 21:39   #2
LuitvD
Supermodder
LuitvD is on a distinguished road
white on black is always nice
Good luck on this one looking good already
__________________
Main rig: Asus KFN4-DRE, AMD Opteron 2210 1.8GHz, 4GB Reg. ECC RAM, XFX GeForce 7900GT 256MB
inside a yet to be shown mod
HTPC: AMD Athlon XP 2800+ 2.09GHz, 1GB Corsair ValueRam 400MHz, Asus EN6200/TD passive 256MB
inside
Philips PC930 (on-hold)
LuitvD is offline   Reply With Quote
Old 1st Sep 2006, 22:35   #3
cire9753
Supermodder
cire9753 is on a distinguished road
not really my thing but i can appreciate the skill it took
cire9753 is offline   Reply With Quote
Old 1st Sep 2006, 22:55   #4
GoTaLL
Supermodder
kinda ruff still but will try detailing tomorrow..
__________________
Old 2nd Sep 2006, 07:30   #5
ZenX
How are you gentlemen?
ZenX's Avatar
ZenX is on a distinguished road
Cool airbrushing skillzors
__________________
Can't think of anything to put here..
ZenX is offline   Reply With Quote
Old 2nd Sep 2006, 07:38   #6
ssR
Carbon God
ssR's Avatar
ssR is on a distinguished road
that skull looks pretty good
__________________
Galleries: My DeviantArt || My PhotoLight
Gear: A620 || 50D+BG-E2N || Canon EF 17-40 F/4L USM || Canon EF 50mm F/1.8 II || Canon EF 85mm F/1.8 USM || Canon EF 100mm F/2.8 Macro USM ||Canon 70-200 F/4L IS USM || Sigma 10-20mm F/4-5.6 EX DC HSM || Manfrotto 055xprob with 804RC2 head || Canon Speedlite 430EX II
ssR is offline   Reply With Quote
Old 2nd Sep 2006, 09:48   #7
modsquad
Grease Monkey Undergraduate..
modsquad's Avatar
modsquad is on a distinguished road
X-cellent paint-fella:
@ssR: pretty good, no-better than that..
modsquad is offline   Reply With Quote
Old 2nd Sep 2006, 09:53   #8
GoTaLL
Supermodder
ok some more done this morning..
like this it looked last night
and this is how it looks now .. i dont know if i should do something more on the actuall skull tho but that we will see..
well the whole case will have the same theme..
__________________
Old 2nd Sep 2006, 11:34   #9
GoTaLL
Supermodder
ok now for the fun part of this project ,,
Yesterday when i came hom i found my son sitting at my place holding the airbrush and was working on the case i had put up for work ...
tis is the case with the skull i was a bit afraid what he had did but at a closer look it wasnt that bad .. it was the other way around it was sweet ..
pic 3 is what my son did .. after that i keept going on that cause he didnt know what to do .. the real fun part is .. hes 10 years old.. never hold anm airbrush ..
last night i rigged up and old airbrush set for him ..
__________________
Old 2nd Sep 2006, 12:11   #10
ssR
Carbon God
ssR's Avatar
i guess the airbrushing skills runs in his blood. skull looks MUCH better now, i wanna see more. keep it up!
__________________
Old 4th Sep 2006, 07:14   #11
GoTaLL
Supermodder
yeah but im impressed by the thing he did just on freehand and when i ask him normally when doing something for an event he says "ugly i can do better" and well ....
__________________
Old 4th Sep 2006, 08:39   #12
Muon
Multimodder
Muon's Avatar
Muon is on a distinguished road
we need pics of it now ^^
__________________
The Numbers Are Real.
4 8 15 16 23 42
LCD HDTV > New Monitor > Next Mod o_O
Coming Soon.
Muon is offline   Reply With Quote
Old 4th Sep 2006, 11:45   #13
GoTaLL
Supermodder
the first pic is the 3 pic that is what he had done when i got home .. then i continued.. the first where its only white used..
__________________
Old 4th Sep 2006, 19:08   #14
BlueBerryBoy
What's a Dremel?
BlueBerryBoy is on a distinguished road
snyggt
tanslation: nice
pitty the holes for a fan are there
BlueBerryBoy is offline   Reply With Quote
Old 4th Sep 2006, 23:47   #15
hydro_electric_655
Dremelly Dude
hydro_electric_655's Avatar
hydro_electric_655 is on a distinguished road
Looks nice . Very nice.
__________________
You can fix it or, you can fix it until it's broken! I'll stick with the latter!
Xp Barton 2800+, Asus A7N8X Deluxe, Ati Radeon 9800XT, WD 160GB IDE, WD 120GB SATA Xaser 3, Sony Optical Drives
My lightswitch knows binary 0101010101010 off on off on off on off on off on off on off
hydro_electric_655 is offline   Reply With Quote
Old 5th Sep 2006, 09:13   #16
GoTaLL
Supermodder
ok have continued some on it .. made somekind of "frame around the skull thing.
bigger picture
http://www.customengraver.se/bigimag...e/DSC_7429.JPG
there is a handle on the top and remade that partually with some paint so it matches up.
bigger picture
http://www.customengraver.se/bigimag...e/DSC_7436.JPG
and the front .. you wil have cd/dvd maybe a floppy or fan controller so i dont wanna put time to paint the things that will be removed so i just did a small skull at tha bottom of the front ..
bigger picture
http://www.customengraver.se/bigimag...e/DSC_7445.JPG
and something like this it looks now.
just something small on the others ide and it will be done ..
__________________
Old 5th Sep 2006, 09:20   #17
sunnyg
Multimodder
sunnyg is on a distinguished road
that looks really good. what airbrush and paint did you use?
sunnyg is offline   Reply With Quote
Old 5th Sep 2006, 09:25   #18
GoTaLL
Supermodder
well im no pro on airbrushing but im trying, im using something that is called "vallejo" water based, and im using a evolution airbrush.
if anyone remember the master "Boris Vallejo", if you dont try search for some of his art ..
__________________
Old 8th Sep 2006, 08:19   #19
GoTaLL
Supermodder
Morning .. well i did finnish this case .. and the end result om very pleased with .. and so is my son..
check the final pics out..
the skull side .. the dept really came thru..
the front .. just to keep it up with the skull side .,
the handle ..
the other side .. there are 2 fan holes and a window so not mych space to play with so its just the same pattern on this side .. but it looks really cool ..
__________________
Old 8th Sep 2006, 08:48   #20
yahooadam
Ultra csavarkulcs
Banned
yahooadam's Avatar
yahooadam is on a distinguished road
wow that does look pretty good, you have teh 1337 airbrushing skilz
yahooadam is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
