Thread Tools |
#1 |
Supermodder
Microsoft to launch BrowserShield
#2 |
I pwn all your storage
Surely it would be better to just completely block a page from loading. And what is defined as malicious? A pop up box? A pop under box? An auto download?
(Please can we rename is BrowzarShield?) |
#3 | ||
Can't mod my way out of a paper bag
![]() Quote:
This isn't a problem for me since I use Opera, but I have to admit that it does bug me that they are making another product aimed at people who probably shouldn't be allowed to use a computer. I'm also concerned about the false positive rate for this, especially as so many sites want flash and java plugins and who knows what all else. Also, it's a given that this will be defeated within days and may be hacked. As long as you can disable this feature it shouldn't be too bad.
__________________
Notice: If we see you flaming we will assume you are on fire and take appropriate measures
- The Bit-Tech Fire Brigade. |
#4 |
Free from artificial flavourings
So Microsoft are releasing a product to protect insecure browsers.
So who makes the browser with the highest number of insecurities...? There's the stable door. Oh dear, the horse has bolted. Oh well, better close the door anyway...
__________________
My uber-system: 66Mhz 486DX2, 8Mb RAM, 20Mb hard drive, 256 colour VGA adaptor (goes all the way up to 800x600!), keyboard AND serial mouse |
| Flibblebot |
| View Public Profile |
| Find More Posts by Flibblebot |
#5 |
Hypermodder
which therefore inproves their browser, EVERY brower is insecure if you look hard enough for the bugs / holes.
Sounds like a good idea to me.
__________________
[Gaming laptop:][Intel Cour Duo2 T7200 ] [Nvidia7900GS GO] [1920x1200 display] [2GB DDR][Creative 6.1's ]
#6 |
Mod Master
agreed rich, with IE holding what was 99% of the market it was, just as XP and other MS OS's are the key target for hackers / malware authors as they will get more results. Firefox / thunderbird have had their own critical updates yet no one seems to slag them off when they are found, they just go "hooza the bug was fixed" yet when MS does it, its like "booo another bug having to be fixed" -- why? cos everyone seems to hate them for doing the world a favour by making an OS so easy to use that anyone can -- with no real learning curve -- this is good for non geeks -- as in, those that prob wont be reading this, nor really have an idea what a forum is -- so that is all good. for those of us that are more eductated then sure, it may seem a bit silly / bad / MS oriantated but so what? we wont use it.. those that need it will.
#7 | |
Minimodder
If this new program get's implemented on the firewall level, I think it would be really good, it's not a panacaea for our problems. I don't think anything could magically solve all the problems the Internet brings with it, anything that is done is just a form of damage control, and will continue to be for the forseeable forture. |
| Laitainion |
| Find More Posts by Laitainion |
#8 |
Multimodder
An interesting idea. Don't just block the page, but "clean it" of any of the "bad" parts. Remove the offending scripts/code silently, and user has nothing to worry. I'd imagine this would only be compatable with IE though?
For what it's worth, I've currently experienced a Firefox/Flash vulnerability (both at the latest version), that somehow changes my DNS settings (redirects to another DNS server). It's rather harmless, and doesn't do any more than that, but it has the ability to crash the browser. I'm pretty sure it's a vulnerability, as my system looks totally clean. So I tool like this could always be usefull, if it works. Aggies |
#9 | |
Why not? I own a domain to match.
I'm personally a fan of just disabling scripts. Makes for better coding practices anyways.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net 40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8 MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD |
#10 |
6 screens / 1 card
Maybe I'm missing something but if this is intended to help the people who run unpatched browsers how do you get them to add this patch?
__________________
It's not about how life treats you, it's about how you treat life. |
#11 |
Ultra csavarkulcs
Banned Join Date: Mar 2006
seems like an idea, but how it works, and how well it works are going to be the big questions
also, shouldn't it be called IESheild, as its only going to work with IE - this is MS were talking about |
#12 |
Madeira's banana is the best!!!
a very good idea, for noobs, i hope they implement this in a correct way.
__________________
Renegade X - 0.40 Release! <---- CLICK! |
#13 |
Supermodder
So let me get this straight... add lots of completely unnecessary, proprietary, untested technology to your browser, thereby increasing the number of security holes by a factor of a thousand... then create a whole movement to stop people from using those features? Way to go, Microsoft.
__________________
It sure took me a long time to realize I hadn't changed my forum settings since returning from Canadia-land. |
| Thread Tools | |
