Thread Tools |
#1 |
Just another nobody
Corsair HX620 & Cooler Master iGreen
#2 |
Hypermodder
That corsair PSU looks very sleek, but I don't really like the flat cables.
#3 |
KEEP IT CLEAN!
More Brands of PSU, some people i.e. me will probably get confused and buy a rubbish powersupply
But, with this kinda look into things, i know i can rely on a brand known for RAM
__________________
The Rig: i7 920 D0, Gigabyte EX58-UD5, 12GB DDR3 1600mhz, BFG GTX295, Samsung 64gb SSD, WD 640gb Black, Samsung F2 Eco 1TB, Dell 3007WFP, Windows 7 RC.
The Netbook: Samsung NC10 Black, Intel Atom, 2gb DDR2 Last edited by samkiller42; 10th Sep 2006 at 12:38. Reason: Bad spelling |
#4 | |
6 screens / 1 card
I like the idea of the Coolermaster but if the up front price negates any later cost savings, why bother? But if it was modular and black like the Corsair...
__________________
It's not about how life treats you, it's about how you treat life. |
#5 |
Can't mod my way out of a paper bag
I dunno, sounds like my ultra X2 with modular cables. Probably a good PSU, but not really worth the price
__________________
Notice: If we see you flaming we will assume you are on fire and take appropriate measures
- The Bit-Tech Fire Brigade. |
#6 |
Gazing at the stars
How do you think the supplies would cope if the same system was overclocked (cpu and gfx)?
__________________
Saving for a new desktop and laptop (Ooooh! Is that Windows Mobile 7 and Android 2 around the corner?) |
#7 |
What's a Dremel?
We found that the Coolermaster had quite a fluctuating current through the molex connectors whilst under heavy load, with the voltage running up and down between 12.20 and 12.10. Happily, even at 12.10 the devices are still getting enough current to function well.
Voltage is not current. You didn't measure current, or at least didn't report it, so how did you know for sure that it was fluctuating? Acceptable voltage tolerances for most computer electronics are generally +/-5% or so, so those measured differences are negligible for all intents and purposes. |
#8 |
Supermodder
Hi,
Wil probably has me down as the spelling nazi by now, but what's a "chassy"? I thought it was "chassis" even in America. Phil |
| Phil Rhodes |
| View Public Profile |
| Find More Posts by Phil Rhodes |
#9 |
I have a dremel.
I like the flat cables - unique and definately a benefit to those wanting to route cables well. I think enthusiasts who build up their systems with stock components will plump for the Corsair. But I think modders would steer clear - I for one would get confused as to which wire I'd cut. Good to see Corsair branching out though...
#10 |
Hardware Nut
Me wants a Corsair PSU..
__________________
|i7 920||EVGA Classified E760||6GB Ballistix Tracer 1600||3x XFX 4890CF||X-Fi Fatality||4x WD Black 1TB RAID 10||Revolution 1050w||Corsair Obsidian 800D| |E8400 @ 4.00 w/ NH-U12P||GA-EP45-UD3P||8GB G.Skill @ 445MHz 5-4-4-12||4870 512MB||X-Fi XM||WD Green 1TB||Tagan BZ 700w||Antec P182 Gunmetal| In Progress||Current Rig -- If I helped you, please give me rep!
#11 |
What's a Dremel?
those things look awesome (the cosair one)
for my next build I'll be looking their way if I was building now I'd probably go with the cheaper 530 watt one or whatever it is |
#12 |
conflagration.
I like the flat cable idea, and the modular one too, time too look into that over the trusty seasonic.
#13 |
Ultramodder
my view is that if the rails dont drop below their reported value then they should be fine. Like 12.27 dropping to 12.10 is still above 12.00 and that's good.
#14 |
What's a Dremel?
These flat cables look sweet and more flexible than the regular sleeve ones. I believe Seasonic actually OEM the unit for Corsair and it's based on their new M12 design as well.
#15 |
Resident EI
Flat power cables are nothing new; Ultra has been using them for quite some time now on their X-Finity series of PSU's as well as on their X2-Connect Modular PSU's. Ultra provides a lifetime warranty when you register the PSU; standard warranty is 3 yrs. Bit-tech should get one of these to campare with the Corsair.
#16 | |
What's a Dremel?
http://www.jonnyguru.com/PSU/X2-550W/X2-550W.html http://www.jonnyguru.com/PSU/HX620W/ |
#17 |
What's a Dremel?
I'm definitely interested in the coolermaster, i've learned in the past that you get what you pay for so money tends to be liberally spent on psu's around my house. I'm a fan of the modular cable system and the flat cables are an even better idea in my opinion.
| Retrograde |
| Find More Posts by Retrograde |
#18 |
Supermodder
meh, I'm looking for a new psu but both of thoes look wimpy
Now heres a REAL psu http://www.jonnyguru.com/PSU/ST75ZF/
#19 | |
What's a Dremel?
Looks wimpy because it's a better and cleaner design? ST75ZF is a good unit, but based on JonnyGuru's review, it's less efficient, physically longer, non-modular, and generates more heat than the Corsair unit. Why do you want that?
| Thread Tools | |
