Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Corsair Dominator Twin2X2048-8888C4DF
__________________
#2 |
Hypermodder
I assume the heatsink design is patented? Otherwise it would be nice to see this filter down to other brands. Yes it's fast, but £400+ for memory is silly money...
#3 |
Pewlius Caesar
bit-tech Staff
Corsair has filed patents 'on multiple aspects of this technology', so I would assume so.
__________________
#4 |
I pwn all your storage
Mommy, I'm scared.
But they could be used as a hair comb. On a more serious note, shame about the H__U_G_E price tag (compo prize:P) and I wouldn't mind that fan cap personally. |
#5 |
Stuck in the Mud
Wow, that price is ridiculous.
As far as I can see, the price premium over say a £150 set just isn't worth it for most people, as there is hardly any performance difference.
__________________
Intel i7 920 @ Stock | 6GB Corsair DDR3| Gigabyte GA-EX58-UD5 WD640 AALS | POV 8800GT | Lian-Li PC65 | Enermax 600W SLI | Dell 2408WFP |
#6 | |
Hypermodder
#7 |
Multimodder
It seems the real world performance to price ratio makes this an enthusiasts purchase, unless I win the lottery I don't think I will be getting some for my next rig!
Amazing timings none the less.
__________________
I wish I hadn't said that!
#8 | |
Hypermodder
#9 |
I fapped to your post!
I can hear Highlander reaching for his wallet as we speak........
__________________
Welcome to Thunderdome, B*tch XBL: atanum141 |
#10 |
Richard Swinburne
bit-tech Staff
I dont know why they didnt use an axial fan to remove dead spots from having three 40mms in a row.
#11 | |
Hypermodder
#12 |
Alignment: Sarcastic Good
Is it just me or should the game tests graphs say "fps (higher is better)" rather than "second (lower is better)"?
| DarkReaper |
| View Public Profile |
| Find More Posts by DarkReaper |
#13 |
Those fans are Axial, Axial fans blow air across their axis, which is what these fans do...
I think you mean crossflow fans? |
#14 | |
Hypermodder
#15 | |
Pewlius Caesar
bit-tech Staff
![]() updated
__________________
#16 |
Madeira's banana is the best!!!
axial:
crossflow: ![]() the bottom one i think would be better for this aplication, but it makes more noise.
__________________
Renegade X - 0.40 Release! <---- CLICK! |
#17 | |
Pewlius Caesar
bit-tech Staff
__________________
#18 | |
Airflow moves along the rotating shaft. |
#19 | |
I Mod, Therefore I Own
Look like decent modules, think the speader is overkill... DIMM's here don't get hugely hot with 2.45v running through them thats with a normal spreader and only a slight breeze from a fan over the graphics card. <edit> although the lack of case might contribute somewhat, a little airflow from the heatsink should make the extra fannage un-necessary though) </edit> BTW guys, you have a set of 6400 C3 right? Bung 2.4 (or more) volts through that and you should be able to run 3,3,3,x timings way into the 400's quite happily. Might even get to x,2,2,x at 400mhz
#20 | |
Hypermodder
| Thread Tools | |
