RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 11th Sep 2006, 20:31   #1
Da Dego
Brett Thomas
Da Dego's Avatar
Da Dego is on a distinguished road
Could you soon insure your iTunes?
http://www.bit-tech.net/news/2006/09...e_your_iTunes/
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo
Da Dego is offline   Reply With Quote
Old 11th Sep 2006, 23:01   #2
mattthegamer463
Mod Master
mattthegamer463's Avatar
mattthegamer463 is on a distinguished road
Sounds good to me. Loosing registration codes is part of the reason I always get a CD or DVD of software, that way I won't loose it nearly as easily and its also easy to put onto more than one computer.
__________________
Latest Work: Boombox Build
Project PCB- Complete Digital Picture Frame 2.0- Complete
RumbleMouse - Complete Latest Project: TestPC- Complete
Lian-Li PC7: C2D E6600, XFX 8800GTS 640MB, Corsair 2GB PC6400, 320GB Seagate Barracuda, EVGA 680i SLi, OCZ 850W
mattthegamer463 is offline   Reply With Quote
Old 11th Sep 2006, 23:34   #3
Firehed
Why not? I own a domain to match.
Firehed's Avatar
Firehed has a spectacular aura aboutFirehed has a spectacular aura aboutFirehed has a spectacular aura about
Registration codes? Bah.
erm...
That's because I stick to free software, of course But I've always hated the concept of download-to-own software for that reason, except for stores that are designed well enough to either a) have two different executables, one trial and one registered, or b) have your reg codes stored with your account data so you can get them back. Though part of my plan with re-casing and re-labeling all of my movies and software and whatnot is to put the serial keys and reg codes right in the DB that the covers are printed from, that way they're right on the case. As long as I don't lose the DB file, I'm fine.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net
40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8
MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD
Firehed is offline   Reply With Quote
Old 11th Sep 2006, 23:54   #4
yahooadam
Ultra csavarkulcs
Banned
yahooadam's Avatar
yahooadam is on a distinguished road
i thought itunes worked more on the steam kind of principal
bah, knew there was a good reason to hate itunes
yahooadam is offline   Reply With Quote
Old 12th Sep 2006, 03:11   #5
Firehed
Firehed's Avatar
afaik, all of the digital music stores are 'buy once and back it up'. iTunes even tells you to make a backup copy after you finish the purchase (or it does on my freebies anyways)
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
