#1 |
Brett Thomas
Sapphire ADDs DVI to IGP
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo |
#2 |
Ultramodder
thats pretty good, i want to run two monitors on mine but only have the built in 6100. be handy if i had a sapphire board
#3 |
hmmmm....
Good idea for a niffty little thing like this, alot of things dont require massive graphics, but need multiple monitors.
__________________
Fight my Brute
The quantum limit of reality might be scaled up because we're all holograms. Obviously. Once more we see that sufficiently advanced physics is indistinguishable from getting really stoned. From here |
#4 |
Supermodder
Hi,
It's nice to occasionally see something simple and effective like this - not something to rave about, but something you look at, mentally tick, and go "yep, fine." Now if only I could find a card reader to plug onto the "card reader" header on my motherboard... has anyone actually seen the hardware to make those active? Phil |
| Phil Rhodes |
| View Public Profile |
| Find More Posts by Phil Rhodes |
#5 |
I fapped to your post!
$20 is a brilliant price as it dosent add much cost to such macines, also gives much better compatibility with newer monitirs.....great idea.
__________________
Welcome to Thunderdome, B*tch XBL: atanum141 |
#6 |
Multimodder
If it takes up a x16 PCI-E Slot then why not just spent a little bit more on a low end card like a x1300 or a 7300 there's not much of a price difference. That way you get H.264 decoding aswell
__________________
Hello there! |
| TheSaladMan |
| Find More Posts by TheSaladMan |
#7 |
Holder of the sacred iron
If you work off the mindset that why dont you just spend a little more and get something fifty times better you would soon end up with a pc costing well over a grand. It is just a simple way to get a dvi port on your integrated graphics. Not only that but if you were building a small media box, it would probably work just fine, also its low profile, that means if you were building a slim case it would be handy. Mind you its not anything to rave about. But its nice to see a company make something to cater to the extreme low end users.
Good one
__________________
..:: Recent Projects ::..
Picture Frame PC / Adding VGA to lcd / Razr Charge Cable Internal USB WiFi / Zune TV Output / Project XodusAMP Integrated AC Inverter / Project IDEpod / Project iPod HDD Reader |
| Warrior_Rocker |
| Find More Posts by Warrior_Rocker |
#8 |
Madeira's banana is the best!!!
at least its better than the pci graphics card.
__________________
Renegade X - 0.40 Release! <---- CLICK! |
#9 | |
Why not? I own a domain to match.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net 40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8 MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD |
#10 | |
Minimodder
#11 |
Didnt ATI make a PCI based x1300 or something? when reviewed it showed to have decent clock speeds. Something to show for how much can be pushed out of PCI with a decent gpu to throw in it.
Edit: Yea it was the x1300 by visontek, Reviewed right here on bit-tech: > link <
__________________
Picture Frame PC / Adding VGA to lcd / Razr Charge Cable Internal USB WiFi / Zune TV Output / Project XodusAMP Integrated AC Inverter / Project IDEpod / Project iPod HDD Reader Last edited by Warrior_Rocker; 28th Sep 2006 at 06:16. |
| Warrior_Rocker |
| Thread Tools | |
