#1 |
Just another nobody
Cooler Master X-Craft USB
#2 |
Multimodder
No SATA? no buy.
__________________
Hello there! |
| TheSaladMan |
| View Public Profile |
| Find More Posts by TheSaladMan |
#3 |
Madeira's banana is the best!!!
nice...... something usefull to do with PATA HDs once SATA becomes the standard.
__________________
Renegade X - 0.40 Release! <---- CLICK! |
#4 |
Et arma et verba vulnerant
Surely the way forward with these boxes is eSATA and port multipliers?
__________________
[AMD A64 2800+ + Zalman 7700][MSI K8N Neo Platinum][1GB Corsair PC3200][Leadtek Geforce 6600GT][Seagate Barracuda 7200.7 80GB + Maxtor Diamond Max Plus10 200GB + Maxtor Diamond Max16 120GB][Plextor PX-716 DVD-RW + 2x Plextor Premium 52x32x52 CD-RW + 16x Samsung DVD][Coolermaster ATC-201 BXT][Antec TruePower 430][Dell 2405FPW + Mitsubishi Diamond Pro 2070u][Logitech MX1000][Matias Tactile Pro][Griffin Technology PowerMate Black] Email Me |
#5 | |
DUR HUR
#6 | |
__________________
#7 |
Alignment: Sarcastic Good
[niggling]I've only got one IDE connector for optical drives on mine, all permanent storage is SATA[/niggling]
Looks alright I suppose, the hub and backup software is a nice touch but I'll stick with the illuminated IcyBox I already have |
| DarkReaper |
| Find More Posts by DarkReaper |
#8 | |
Can't mod my way out of a paper bag
__________________
Notice: If we see you flaming we will assume you are on fire and take appropriate measures
- The Bit-Tech Fire Brigade. |
#9 | |
Modder
<rant> Think about it, you probably have a printed and a scanner, both of which take up a USB port, both of which are only in use a fraction of the time and both of which are plugged into the mains; wouldn't they be the perfect place for, say, a four port hub... It's not as if they take up a lot of space, or cost a lot of money, I've got a four port passive model that I keep with my laptop, it's 2.5in long and 3/4in high, adding one of those and the power circuits can't be much more work than adding one of those useless "PictBridge" connectors that every printer seems to be sporting. </rant>
__________________
A voice of reason... mainly ignored... Deviant Art Gallery Tyan Tiger K8W, dual AMD Opteron 240, 3Gb Ram. Dual core, the old fashioned way! Last edited by Zayfod; 15th Oct 2006 at 23:15. Reason: consistancy |
#10 | |
Why not? I own a domain to match.
But I'm just bitter. As a fairly early adopter of SATA, all of my drives in the last... three years or so are SATA, and certainly everything with a decent amount of storage. It was all fine until two months ago or so, since the school network really makes my fileserver useless.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net 40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8 MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD |
#11 | |
What's a Dremel?
The problems I find with most external drive enclosures is that they often look and feel cheap, have sharp edges on the inside making installation painful, and the worst of them all is that they don't connect reliably. Too often, I've had to re-plug the USB or Firewire cable to get the computer to recognize the drive, it's pretty annoying. One test that these enclosures should go through is a count of how many successful connections it makes out of five tries on each of ten different computers. |
#12 |
Master of the unfinished.
I've used an external HD caddy for about 3-4 yrs now. For a couple of years it was one of those original IcyBox enclosures that were illuminated on 3 sides with a 200GB Western Digital drive inside. Unfortunately I found that WD drives ran a little hot and burn't out after a while, switched to Seagate & the new styled IcyBox and going strong after a year.
Never had any problem with getting the laptop/pc to find the drive JeffDM. 100% successful connections here out of proberly something close to 200-300 times i've hooked it up.
__________________
Intel Core2Quad Q6600 @ 3.0GHz, Abit Fatal1ty F-I90HD (uATX), 4GB Corsair XMS2-6400C4,
Sapphire HD4870 Vapour-X 1GB, Hiper 580W Type R, 4.1TB of Seagate Storage, Antec 300 + Lian-Li V300 (Lian-Li to be modded shortly). |
#13 | |
What's a Dremel?
there are 3 different versions availableof the X-Craft, PATA, SATA and Firewire connection.
__________________
http://www.madshrimps.be |
#14 |
What's a Dremel?
i have a Vantec Nexstar3 that supports eSATA and even comes with a bracket to convert an internal SATA port to eSATA. Only caveats are that if you want to hot plug the drive you need a chipset that will support it and it dosent have any ventilation to speak of and my 400GB Hitachi gets warm if i leave on for long periods. the case works great if your plan is to use it for transferring data and backups, but I would not recommend it for 24/7 operation.
http://www.vantec.com.tw/_en/01_prod...&sid=60&id=120 |
| masteroffm |
| Find More Posts by masteroffm |
| Thread Tools | |
