Scratch Build – In Progress [MOD] Projekt "CRAZY BLOBZ" - up: 18/10/2007
Discussion in 'Project Logs' started by alonso_bistro, 16 Oct 2006.
  1. alonso_bistro
    alonso_bistro I'm just looking
    19 Feb 2004
    [​IMG][PROJEKT "CRAZY BLOBZ"] // ...A.Bistro
    This mod is made in collaboration with Nokytech.net and Crucial
    thanks to them
    Pix now clickable....
    [Le setup]
    Mobo: Asrock K8NF4G
    CPU: AMD 64 3200+ socket 754
    Ram: CRUCIAL Ballistix Tracer PC4000 2x1 giga
    Vidéo: ATI X1600pro PCI-E
    HDD: Barracuda 120 gigas
    DVD RW SONY dw-Q520a - slim
    The PSU will come soon, i'll use a shuttle one.
    [Watercooling]
    Pumpstation 1A-COOLING
    Waterblock CPU: XX-Flow Innovatek
    radiator: Bix
    Fan: for the next up :)
    Tubing: Innovatek orange fluo (thanks Osiris) ;)
    The pumstation and the rad were in ghettho status :)
    After a p12::fred00 sanding they looks better. They 'll be
    black painted.
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    The waterblock need more sanding, he look good now.
    The start object is the same than in my previous mod ("40")
    (follow the link in my sign)
    mod "40"
    The rack display VARTA, the box (next pic) is steady on the
    bottom
    I'm planning on making something different but in the same spirit.
    This time the baby will be watercooled. Not an easy thing to do regarding
    the mensurations of the box.
    [size of the box]
    height : 42 cm
    width (top and bottom): 24 cm
    width (middle) : 29 cm
    depth : 15 cm (nearly a CD DRIVE)
    [accesories..]
    I will use all the mess i'll can find in my workshop..plexi, alu, and of
    course mesh , under all her forms. :)
    I've some leds in stock.
    [tools]
    Dremel multipro, drill, sander, jig-saw, arms, beers....
    [Le principe...]
    The pumpstation will be on a little tablet made from smoked brown plexi.
    The plexi is a little damaged but it wont be really seen.
    The pumpsation will stick out from the top of the box.
    The radiator will be on the bottom with a fan over it, the airflow will be from the inside to
    the outside.
    The fact that the box is totally in mesh will help for the functioning......i hope.
    Tablet for the pumpstation:p
  2. alonso_bistro
    19 Feb 2004
    Dremel cut on the top
    and on the back
    a senfu will be added on the front. The senfu will check the CPU temp
    [For the feets...]
    For the feets I've saw the 2 verticals tubes
    Of course they wont stay like that :)
    [The thing "idontknowthename" use for the brackets PCI..]
    The "idontknowthename" has been retrieve from an old case
  3. alonso_bistro
    19 Feb 2004
    [For the DVD RW...]
    I decided to run for a slim dvd rw
    The little adaptator fixing is strengthened with double face
    Cut for the dvd and lucky me .. the dvd thickness is just 2 lines on the mesh :D
    fast fixing for testing.
    [A first black painting, just to add some happyness and color...]
    [Camouflage of the pumpstation]
    This part made from mesh will be on the top of the case, on the pumpstation.
    [Support for the tube IN]
    Realise with smoked plexi and with "anotherIdontknowthename", used to avoid the door to hurt the
    wall :) . Whith a led indahass, will look good.
  4. alonso_bistro
    19 Feb 2004
    [a bunch of deco]
    [Blobz...]
    hour H of the beginning of the Blobz's invasion......
    They arrived from everywhere !!.. some of them have eyes ..
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [End of episode 1]
    thanks for reading or at least for scrolling, sorry for my still stange english.
    rendez-vous for the next update...
    something strange is happening.....
    to be continued......
  5. huren
    huren What's a Dremel?
    14 Aug 2004
    Great start, im looking foward to seeing this unfold.
  6. Darkened
    Darkened Minimodder
    28 Feb 2004
    Great to see that you're at it again :thumb:
    Ok, now, go mod!
    Janne
  7. BiG Kahuna
    BiG Kahuna What's a Dremel?
    14 Aug 2004
    Great too see you back alonso! really looking forward to see will this mod turn out :thumb:
  8. DeltaFX
    DeltaFX What's a Dremel?
    4 Aug 2006
    Fais gaffe, t'as plein de bestioles bizarres collées à ton pc.....
    Nice job.
  9. alonso_bistro
    19 Feb 2004
    m'en parle pas, j'en ai plein les cheveux :D
    thanks
  10. Zzubbione
    Zzubbione What's a Dremel?
    31 Jul 2005
    wow! one more time, a nice project here!
    happy to see another of your mod, mate! ;)
    et quand c'est que tu postes çà sur nos bô forum franchouillards, hein??? ^^'
  11. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Fantastic the Blobz :hehe:
    Maybe you can paint them with uv-coloros......... :rock:
    :clap:
  12. rachit
    rachit What's a Dremel?
    5 Jan 2004
    sympa
    tu vas encore nous réaliser un beau mod :)
    ;) bonne chance
  13. Heero195
    Heero195 What's a Dremel?
    12 Jun 2006
    Really amazing work. But have you thought of using a slot loading CD drive instead, it would be a lot less cumbersome.
  14. alonso_bistro
    19 Feb 2004
    yes my first desire was to run for a slot in but , like an idiot I thought it was a little difficult to find, and it is not so difficult.... :wallbash: too late.
    @Darkened : orange addict are here :D
    thanks
  15. Darkened
    Darkened Minimodder
    28 Feb 2004
    You can't go wrong with orange!
    Though with my next mod I might be doing something completely different :hehe:
    I've been meaning to ask, what's happening with Alpha Orange lately, Is it dead in the water or do you still have plans for it?
    Hopefully you'll have time to update soon, you know I'll be waiting for that.
    Janne
  16. alonso_bistro
    19 Feb 2004
    Alpha is still alive...
    the water is in ...but temporarly, my real setup will be in the blobzs :)
    front page in [HARD]ocp :rock:
  17. Darkened
    Darkened Minimodder
    28 Feb 2004
    And not without a good reason, it still looks great after these years and that, I think, says a lot about your modding.
    But now since you can move your main rig into the blobz, will you be re-opening the archives on Alpha? I'd really love to see that :thumb:
    Janne
  18. G-gnome
    G-gnome Peter Dickison
    8 May 2003
    I love your mods: really outstanding! Bright, fun and great workmanship.
    Looking forward to seeing how this one turns out.:)
  19. alonso_bistro
    19 Feb 2004
    wow! thanks you
    @darkened: humm not sure, i don't like to re-open old project and honnestly all this orange start to bored me :D
  20. Fatboy
    Fatboy Bored
    8 Oct 2001
    Serious modding talent there dude.
    Not one of these ' i moddded a coolermaster/lianli/etc' mods
