#1 |
Pewlius Caesar
bit-tech Staff
Inno3D GeForce 7950 GT
__________________
#2 |
Disgruntled kumquat
Random question: What were memory temps like? The 7950 GT cooler's I've seen include pads for the memory, I'd be worried about overheating with the Inno3D solution.
__________________
The intellitxt demon fell dead, Sir Tim's lance embedded in its heart. The fair land of Bit-Tech was free from its influence once more. And there was much rejoicing. |
| Techno-Dann |
| View Public Profile |
| Find More Posts by Techno-Dann |
#3 |
Pewlius Caesar
bit-tech Staff
Artifacting is usually a problem when memory overheats - the card was perfectly fine to be honest. The DRAMs were warm to the touch at best (or worst) - many 7900 GT cards had the memory running without heatsinks in excess of 1500MHz, so I don't personally see it as much of a problem. Memory heatsinks will of course help you over time but this seemed to cope well through a stress test.
__________________
#4 |
The Froggy Poster
Iss it just me, or does it appear that Inno3D (for some reason unbeknowenst to man), has drilled out two holes on the PCB just a little shy of the reference mounting holes, and done so on the cooler too?
__________________
Desky E8400 @ 4.0 1.42v; P5K-E WiFi; 4x1 Kingmax Mars 1066 @ 1129 CAS 5; 2x [TOO CHEAP TO SPONSOR] 4850 @ 675/1050; Enermax Liberty; WCing in a CM690 |
#5 |
Revelation Machine
No it's not just you, they probably just wanted the cooler to cover the entire core
__________________
Marching Into History, Marching Into War, Marching Into History To Function As A Whore "Don't Fear Citizens! TAD KNOWS HIS RAID!" |
#6 |
Modder
Hmmm it's kind of wierd that few blocks get better results on Nvidia than Ati everytime. Wonder if its all about the HW that they use...
#7 | |
Officious Bystander
__________________
Demand Naked DSL in the UK! |
#8 |
Pewlius Caesar
bit-tech Staff
I'm lost too
__________________
#9 |
Banned
Looks like a good card, but for £60 over the 1950Pro it doesn't seem worth it when the performance looks to be so close.
/me wishes the 1950 pro's would make an appearance |
| specofdust |
| Find More Posts by specofdust |
#10 |
Resident frenchie
what about noise ? The zalman cooler must be nice.
__________________
I also have a MTBF. |
#11 | ||
Pewlius Caesar
bit-tech Staff
__________________
| Thread Tools | |
