Thread Tools |
#1 |
Supermodder
360 & PS3 have equal power?
#2 |
Stuck in the Mud
This has been known for a while, I think other developers have commented on it. Each console might be better in particular areas, but when you add it all up, they're about equal.
__________________
Intel i7 920 @ Stock | 6GB Corsair DDR3| Gigabyte GA-EX58-UD5 WD640 AALS | POV 8800GT | Lian-Li PC65 | Enermax 600W SLI | Dell 2408WFP |
#3 |
I pwn all your storage
The only thing that PS3 had going for it really was the exclusive titles, but with MGS4 rumoured to be hitting 360 and 360 having a fair few big hitters under its belt which will never leave it seems like Sony are getting in trouble.
#4 |
Richard Swinburne
bit-tech Staff
It's entirely true. The PS3 has 256meg XDR rambus based memory and 256meg GDDR3. Despite the fact that the RSX can talk to the GDDR3 as well as XDR, being different speeds and memory sets means that using them both for texture memory is going to be exceptionally difficult to code for and it will fill the inter-buses with graphics IO rather than game IO. Even though Sony has made it easier to code for in C++ etc
I think we'll see a more massive extrapolation of the PS3s power in the next 2-5 years like Square has done with final fantasy, or the guys who made resident evils did with the cube. Moreso than the 360 which is "easier" despite the fact it's still a multicore/unified shader that's "new". It's still got pc-esq components. I think this guy is right on the money with his opinions. |
#5 |
Modder
Althrough the Xbox 360 games are way better
__________________
HoUcK ![]() - P4 1.5Ghz - 768MB SDRAM - 256MB NVIDIA SPARKLE GEFORCE 6200 - |
#6 | |
DUR HUR
The xbox 360 on the other hand is meant to be very easy to work with, Gears of War was originally meant to be an xbox title and it took them only a month or two to completely convert (not port) the game as it stood for the 360. |
#7 |
^_^
So if they're generally almost equal in power, it's up to the consumer to decide whether or not it's worth paying the extra cash for the PS3 exclusive titles (and risking buying into the [not yet standard] Blu-Ray phenomenon).
I will end up getting one at some point (2nd hand, no doubt), for the exclusive titles I'll inevitably want to play. imo though, they seriously need to stop all this BS hype - ok, so the vast majority of the public are idiots, and will believe anything you tell them, but surely they're gonna be pretty p**sed when they find out their hard-earned cash has essentially bought them a 360 equivelent, with a BR drive...even moreso if BR ends up redundant. The PS3 will still sell in massive numbers - but that's not surprising when you consider the crap they feed Joe Public. |
#8 |
Multimodder
I thought this had been known for quite a while now, hell the PS3 is such a bitch to program for that the Assassins Creed devs have come out and said that the AI is gonna be alot better on the 360.
__________________
Hello there! |
| TheSaladMan |
| View Public Profile |
| Find More Posts by TheSaladMan |
#9 |
Multimodder
Yeah, this news has been known a while, read a pretty damning report on the PS3 version of Oblivion on IGN, you should check it out, I read it with a kind of half grimace, half smirk (must have looked pretty weird!). The interview starts with a standard "We've been porting this game for ages already..." then the IGN guy starts asking the standard q's;
What new content is there? A new 20hr quest. Will this be available on the x360? Yes How have you improved the graphics? They are the same as the 360, with some new shaders and the middle distance is now smoother. How have you used the hard drive? The same as the 360. Will you be able to download content? Not at the moment as we don't know how this will work! Are you using the tilt function? No. Will the PSP have any conectivity? No, sorry. This piece of news lead me to finally purchase a 360 2 weeks ago. |
#10 |
Hypermodder
As far as I know the designs for the major hardware parts were finalized at about the same time were they not ? I think we can assume that both would try and get away with as much power/heat as possible and using the same generation of technology, that isn't likely to differ too much, hideously expensive, almost impossible to leverage anywhere near the theoretical power of cell processors (so say, for example Epic megagames I believe) aside
__________________
Athlon 64 X2 3800+ @ 250x10 (1.475v) | EVGA GTX 260 55nm SSC | A8N-SLI Premium | 2x(4GB) Corsair Twinx2048-PC3200C2 | Asus Xonar DX | Antec truepower 550w | Akasa Eclipse-62 DDC12VPlus1, DD TDX, 3/8 tygon r3603 tubing, PA120.2, DD double floppy bay res |
| Bladestorm |
| Find More Posts by Bladestorm |
#11 | |
Richard Swinburne
bit-tech Staff
#12 |
DUR HUR
What it all really comes down to in the end is the quantity of high quality games, Sony are in a bit of trouble here though because I've heard they havn't got that much support from developers, who'd much rather program for a easier machine, like the 360.
All this stuff about "ooo look at these fancy cell processors" doesn't mean anything if you've not got decent games to use them, the only use videos like riggs linked to is for developers, and I really doubt they're gonna be swayed by some buzzword bull****. |
#13 |
Madeira's banana is the best!!!
people will buy the ps3 anyway.
"it it is expensive it is good because quality is not cheap" but this is funny anyway.
__________________
RENEGADE X CONTEST! <---- CLICK if you want to win a free Command & Conquer 4 beta key! |
#14 | |
Richard Swinburne
bit-tech Staff
#15 |
Ultramodder
I'm not suprised he's glad E3 is over. Almost every developer is glad that's done with. Especially him, since Too Human got slammed last E3 because it was choppy and hard to play. He said the final product will be NOTHING like the E3 demo. Too Human is -THE- game I am looking forward to for 360, though.
__________________
Abit AB9 Pro, Intel Core 2 Duo E6400 CPU, 2GB Corsair DDR2 6400, nVidia 8800GT, Seagate 160 GB HDD. |
| Neogumbercules |
| Find More Posts by Neogumbercules |
#16 |
Holder of the sacred iron
Its not how big your bus is, its how you use it. Or so my virtual girlfriend says.
In all seriousness though did anyone actually think the ps3 would be so many times more powerful than the 360? The ps3 after all was not all that powerful. Just when you code and develop specifically for it you can utilize the platform specific advantages.
__________________
..:: Recent Projects ::..
Picture Frame PC / Adding VGA to lcd / Razr Charge Cable Internal USB WiFi / Zune TV Output / Project XodusAMP Integrated AC Inverter / Project IDEpod / Project iPod HDD Reader |
| Warrior_Rocker |
| Find More Posts by Warrior_Rocker |
#17 | |
DUR HUR
They can't really conquor europe and america without some big name western developers signing exclusives (like Rockstar, GTA games are always a big pull for customers), after all, the majority westerners wouldn't buy a JRPG unless it has Squaresoft on it, and many other japanese games never see the light of day over here. But like many people have said, it will sell out just because it's called the PS3. |
#18 | ||
Supermodder
Yes, I've been looking at too many Wikipedia articles of late.
__________________
It sure took me a long time to realize I hadn't changed my forum settings since returning from Canadia-land. |
| Thread Tools | |
