RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 7th Nov 2006, 13:41   #1
WilHarris
Just another nobody
WilHarris's Avatar
WilHarris is on a distinguished road
Bioware integrating PhysX into new engine
http://www.bit-tech.net/news/2006/11...to_new_engine/
WilHarris is offline   Reply With Quote
Old 7th Nov 2006, 13:51   #2
M4RTIN
Ultramodder
M4RTIN's Avatar
M4RTIN will become famous soon enough
still not an argument for buying an overpriced physx card. still not enough support for it atall
infact, interesting point, a big physx game was graw, i had a look around for info on both splinter cell double agent and ranbow six vegas and neither use the physx card. if that isnt a backwards pedal i dont know what is, similar to the very same publisher and starforce
M4RTIN is offline   Reply With Quote
Old 7th Nov 2006, 14:44   #3
Bladestorm
Hypermodder
Bladestorm is on a distinguished road
I wouldn't have thought that RPG fans were the group most likely to go bananas over a physics card ? And I doubt they will implement anything that really effects gameplay in any way since they would alienate too many players .. so .. still not really seeing the point to be honest.
So, lets see to date we have to the best of my knowledge :
Cell Whatsit demo : runs without a PhysX card, just lose the cloth and more advanced water effects (which don't effect the gameplay anyhow) albeit it hammers processors a bit.
GRAW : better looking explosions, effects but lower frame rate due to increased graphical need.
CoH/CoV : objects in the environment get knocked about, leaves get blown off trees etc .. none of which actually requires a PhysX card (I can run the "ultimate" mode that says it highly reccommends PhysX without topping out my CPU)
Is that it ?
__________________
Athlon 64 X2 3800+ @ 250x10 (1.475v) | EVGA GTX 260 55nm SSC | A8N-SLI Premium | 2x(4GB) Corsair Twinx2048-PC3200C2 | Asus Xonar DX | Antec truepower 550w | Akasa Eclipse-62 DDC12VPlus1, DD TDX, 3/8 tygon r3603 tubing, PA120.2, DD double floppy bay res
Bladestorm is offline   Reply With Quote
Old 7th Nov 2006, 15:17   #4
Tyinsar
6 screens / 1 card
Tyinsar's Avatar
Tyinsar is on a distinguished road
So, Bastila forgot to get dressed before going out?
Are you one of those Guild Wars players who creates female elementalists just to watch them dance (without "armour")?
P.S. I too would not have picked RPG games to push this but why not?
A dedicated PPU makes more sense then trying to get an already taxed GPU to do more but the cost ... Just put the load on my quad core (when I can afford that).
__________________
It's not about how life treats you, it's about how you treat life.
Last edited by Tyinsar; 7th Nov 2006 at 21:01. Reason: I guess Bastila Shan only has one "l" in her name
Tyinsar is offline   Reply With Quote
Old 7th Nov 2006, 15:58   #5
oasked
Stuck in the Mud
oasked's Avatar
oasked has a spectacular aura aboutoasked has a spectacular aura about
AGEIA should be trying to get some kind of licensing going on, because as I see it all physics is going to be put on a CPU core or several soon.
Unfortunately I only have one CPU core.
__________________
Intel i7 920 @ Stock | 6GB Corsair DDR3| Gigabyte GA-EX58-UD5
WD640 AALS | POV 8800GT | Lian-Li PC65 | Enermax 600W SLI | Dell 2408WFP
oasked is offline   Reply With Quote
Old 7th Nov 2006, 16:21   #6
Veles
DUR HUR
Veles's Avatar
Veles will become famous soon enoughVeles will become famous soon enough
It always was on the CPU untill the PhysX card. I think using one core in a multi core system is much better than having to buy an extra add in card.
The takeup for the PhysX card is awful really, there is only really one big game where it makes any difference (GRAW).
A PPU isn't needed, at lease not a dedicated PPU, using one of your cores as a PPU is a much better idea IMO. Yeah it requires people to buy a multi-core processor, but I'd much rather buy a kentsfield than a single core and a PhysX card, since a multi core CPU does more than just make GRAW look prettier.
__________________
Veles on: Xbox Live (My Halo stats), Steam Community, Twitter
Originally Posted by Fod View Post
spam gangsters might as well tap into all those machines for their zombie networks.
Veles is offline   Reply With Quote
Old 7th Nov 2006, 16:54   #7
DXR_13KE
Madeira's banana is the best!!!
DXR_13KE's Avatar
DXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to behold
Isnt AGEA dead yet?
PhysX cards are as usefull as "killer NIC" these days and in the multiple core future of computers.
__________________
Renegade X - 0.40 Release! <---- CLICK!
DXR_13KE is online now   Reply With Quote
Old 7th Nov 2006, 17:21   #8
sandys
Hypermodder
sandys is on a distinguished road
but surely thats the point to add in more effects and calculate the physics that the CPU couldn't handle alone? The game itself is interesting, I think CF:R could be good when released if this early tech demo is anything to go by, it will live and die by how good it is to play without a Physx card though
CGRAW : better looking explosions, effects but lower frame rate due to increased graphical need.
It does add to the explosions but its pretty weak really, I do enjoy it though, more stuff everywhere, it could have done with being more realistic though, you can't expect to add more objects to render without impacting fps though, it will be the same for any other solution.
CCoH/CoV : objects in the environment get knocked about, leaves get blown off trees etc .. none of which actually requires a PhysX card (I can run the "ultimate" mode that says it highly reccommends PhysX without topping out my CPU)
In this case Physx does seem to work well increasing fps but over 35% even when running an x6800, if I was someone who played that game it would be great.
Perfomance evalution in CoV
Is that it ?
unfortunately it seem so, great waste of £150, might have felt justified if I played that MMO but hey I liked the idea I thought it had potential, which it has, just not much has shown it, ah well, I have bought worse things in the name of gaming
sandys is offline   Reply With Quote
Old 7th Nov 2006, 17:36   #9
Narvi
Minimodder
Narvi is on a distinguished road
Yeah, but if a developer like Bioware decides that PhysX is a required card to play its games, I can see the card getting rather popular. Of course, if it isn't necessary to actually play the game, you can bet that most people will just be happy to let their quad core take care of the physics.
Narvi is offline   Reply With Quote
Old 7th Nov 2006, 18:04   #10
Fozzy
Ultramodder
Fozzy's Avatar
Fozzy is on a distinguished road
I wanna see physics put on the extra cores of cpu's. I don't really want to see them on graphics cards but I wouldn't mind them all that much. If physx cards were $100 instead of $250 then they would be plausible. They should also ENHANCE performance. Instead of hindering it. I mean jesus, it doesn't do a whole lot besides dropping the frames by 2-6
Fozzy is offline   Reply With Quote
Old 7th Nov 2006, 19:04   #11
Veles
DUR HUR
Veles's Avatar
No, I see BioWare becoming VERY unpopular if they require you to spend an extra £150-£200ish on a PhysX card just to play thier game. I know people spend hundereds on upgrading graphics cards already, but it's just one game, a high spec graphics card will see alot more use than a PhysX card.
They won't make the card a requirement though, they arn't that stupid, so it just adds one game to the list thats what, 3 games long, wow.
__________________
Old 7th Nov 2006, 20:38   #12
sandys
Hypermodder
I think some people forget that when a game developer uses physx they don't necessarily mean its only going to run on the hardware card, physx is also the API ( like what directx is for graphics cards ) a physx accelerator card accelerates the physx routines in the same way a 3d graphics card does graphics routines, you can still run this stuff on your CPU and in fact the physx API seems quite well positioned for multiple processing units whether they are extra CPUs or PPUs but for physics routines a PPU is more powerful than a CPU as it specialized hardware for that task much like how a 3d accelerator can push polygons much faster than your CPU when used for its specialized task.
Old 7th Nov 2006, 20:51   #13
Veles
DUR HUR
Veles's Avatar
Yeah but it's obviously gonna have some advantages if you have a PhysX card like extra sparkley bits in your spells or whatever. I'd just prefer it if I didn't have to intall yet another program that takes up resources yet hardly ever gets used.
__________________
Old 7th Nov 2006, 21:00   #14
Tyinsar
6 screens / 1 card
Tyinsar's Avatar
Originally Posted by Veles
... I'd just prefer it if I didn't have to intall yet another program that takes up resources yet hardly ever gets used.
When not being used the only resource it should take is storage space.
__________________
Old 7th Nov 2006, 21:04   #15
Grinch123456
Multimodder
Grinch123456's Avatar
Grinch123456 is on a distinguished road
Slap the phrase "Gaming" onto it, add a heatsink or spreader, paint it some weird colors, give it some lights, add a couple chips of ram, and price it 200 more dollars than the regular version. That's what the Killer NIC and PhysX were (except the PhysX only had 1 version, the overpriced one). With multicore, all physics should be offloaded to additional CPU(s) and that's final. We're already out of PCI slots.
Grinch123456 is offline   Reply With Quote
Old 7th Nov 2006, 21:13   #16
sandys
Hypermodder
Indeed, it does give you a tray icon that takes up 2Meg but you can switch it off.
What do you need more than 3 PCI slots for?
Old 7th Nov 2006, 22:54   #17
KillaH
Multimodder
KillaH is on a distinguished road
i prefer valve's solution, you don't need to buy extra stuff and it works superb
KillaH is offline   Reply With Quote
Old 8th Nov 2006, 21:24   #18
Cthippo
Can't mod my way out of a paper bag
Cthippo's Avatar
Cthippo is on a distinguished road
Personally I think PhysX is a dead end, but I wish it wern't. I personally would rather have dedicated hardware for these sort of specialized functions (NIC, sound card, etc) than have them been on-board or shared. As the wise man once said, anything designed to do more than one thing usually doesn't do anything well. Computers are the exception to that in general, but I have noticed that the more things my system tries to do, the slower all things happen. Case in point is downloads. When I'm downloading a large file and then squirting it to the fileserver, everything on my computer slows to a crawl. One fairly monor process can draw down the entire system.
__________________
Notice: If we see you flaming we will assume you are on fire and take appropriate measures
- The Bit-Tech Fire Brigade.
Cthippo is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
