Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 15th Nov 2006, 17:31   #1
Anzu
What's a Dremel?
Anzu has yet to learn the way of the Dremel
Need a good gaming headset
I have look everywhere and cant find a comparison between different headsets currently available, is there any you recommend?
It does ideally need to have a mic aswell.
Thanks
Anzu is offline   Reply With Quote
Old 15th Nov 2006, 19:41   #2
Hiren
mind control
Hiren's Avatar
Hiren has yet to learn the way of the DremelHiren has yet to learn the way of the DremelHiren has yet to learn the way of the DremelHiren has yet to learn the way of the DremelHiren has yet to learn the way of the DremelHiren has yet to learn the way of the Dremel
Similar thread here. Should give you some ideas.
__________________
Twitter | Last.fm | DeviantArt | GiffGaff
Hiren is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
