RSS
Reply
Thread Tools View Mode
Old 24th Dec 2006, 00:31   #101
Snakez
Multimodder
Snakez's Avatar
Snakez is on a distinguished road
Originally Posted by Duste
Any more progress on the case?
The company where i work on the chromingjob is closed for christmas & newyear. So can't work on it till 2nd of januari
But i hope to have chromingjob finished around 15th of januari.
So for now gathering all supplies needed , and when i have the parts back home it will go fast. Have to make up for the lost time then
Hope to get my order from ACryan in soon , that way i can start doing some little things in advance .
__________________
www.snakez-modding.nl
Snakez is offline   Reply With Quote
Old 24th Dec 2006, 00:35   #102
Duste
Sierra my delta, bravo!
Duste is on a distinguished road
Ah, no worries! I'll be waiting; at least I'll be uncapped by then.
Duste is offline   Reply With Quote
Old 9th Jan 2007, 08:39   #103
Snakez
Multimodder
Snakez's Avatar
Finnaly got the package i was waiting for.
Not all is there yet what ACryan is sending me, but is a start.
And now i can continue
Thnx for sponsoring me ACryan
The chromingjob should be done in a week orso.
Then finally i can start working more on this project
__________________
Old 9th Jan 2007, 08:53   #104
Mother-Goose
Tories ftw!
Mother-Goose's Avatar
Mother-Goose is on a distinguished road
Thats a hell of alot of free stuff :P Im intrigued as I am doing a stacker build (non modded i hasten to add) soon
__________________
Goose
Q6600, Striker Extreme, 4GB 6400C4 Dominator DHX, Raptor X, 2x400GB spinpoints, BFG 8800GTX OC, Stacker 830 Evo, HX620, Nova T 500, Freezer 7 Pro
Mother-Goose is offline   Reply With Quote
Old 9th Jan 2007, 18:18   #105
Snakez
Multimodder
Snakez's Avatar
Did do a few small things today.
First attach the coolers to the rad.
Put the power on.
Then lets work on Corsair's Dominator coolingunit.
Made a blue uvplexi cover for it.
Let's see the effect when we put some uvlight on it
Thats it for today , more to come tommorow.
__________________
Old 9th Jan 2007, 21:26   #106
Darkened
Oh, the monstrosity...
Darkened's Avatar
Darkened is on a distinguished road
All the parts are looking really good and I think the case will blow our minds when it's chromed.
A request for when the case parts arrive from the chrome factory, could you put up a tad bigger pictures, say 640x480 or even 800x600 for us to see that chrome better
Also, you're used to using leds in your mods, how do you wire them, one at a time or say 3 in series with smaller resistor? I guess 4 would be also possible with 0 or 1 ohm resistor, but it would be a bit dimmer though. If you could answer that, since I'm looking into using leds for my Orange Monster, now I still need a place to order them from (could you include that for me also), thanks in advance.
Then a quick tip, I saw that you de-riveted the case with your dremel, don't actually know how that works, but I've used a normal cordless drill with say 6-10mm drillbit (depending on the size of the rivet) with success. Just saying, give it a try, you might be surprised
Keep up the fantastic work.
Janne
__________________
I have spread my dreams under your feet, tread softly because you tread on my dreams.
Project: Orange Monster
Project: Phantom Black
Project: Red October
Darkened is offline   Reply With Quote
Old 9th Jan 2007, 21:48   #107
Snakez
Multimodder
Snakez's Avatar
Janne
Thnx for the compliments I will put some bigger pics for you. Tomorrow i pick up the chrome parts :P The leds all get their own wire and own resistor ,think thats the best. I always order them at www.ledsee.com . It's a Belgian guy living in China. The price is very good there.
And i will sureley try with a cordless drill nexttime , it's a f**ked up job to get them all out with a , thnx for the tip.
__________________
Old 9th Jan 2007, 23:16   #108
Darkened
Darkened's Avatar
Thanks a lot for the info.
So if I'm not wrong, these are the right kind "10x 5mm UV 200mcd, Low nm"? And is that price right, 10 pcs for about 1,5€, cause if it is, that's damn cheap
Also, for wiring the leds one by one, is there a reason for that (easier to replace maybe?) cause at least I'd think that putting them in series would cut down the wire clutter a lot. I might be wrong here, since I haven't worked with leds that much.
Janne
__________________
Old 10th Jan 2007, 00:52   #109
flatsix02
What's a Dremel?
flatsix02 is on a distinguished road
This is going to turn out awesome, can't wait to see it finished!
I havnt worked with LED's, but i want to. Say you wire each one individually, what do you wire them to? Is there some sort of on/off switch that they all go into?
flatsix02 is offline   Reply With Quote
Old 10th Jan 2007, 03:24   #110
Duste
For a normal 3-3.2mm (or so) rivet that most cases use, it's easiest to use a 4mm drillbit to get the head off, then you can just grab pliers and pull the other end out. If you're having trouble pulling the other end out, just drill the other side a bit more, because there could be a flare there.
I was taking about my case for my mod yesterday, so it's all quite fresh in my mind. :P
Old 10th Jan 2007, 05:48   #111
thingamajig
Minimodder
thingamajig is on a distinguished road
Janne
Here is a couple of good links to an LED calculator. It will draw up a wiring schematic and tell you what size of resistor is needed.
Individual
Series/Parallel
thingamajig is offline   Reply With Quote
Old 10th Jan 2007, 08:18   #112
marauder16
Multimodder
marauder16's Avatar
marauder16 is on a distinguished road
I also just drilled through the rivet, it's very fast, and you don't have to pull anything, it just pops out
great work Snakez, it must be nice to be sponsored by ACRyan
__________________
my current project, (P180) UV flame - last update 10/23/2008... - project finished
- planning: U2-UFO Extended CYO - dual loop - new stuff to play with
marauder16 is offline   Reply With Quote
Old 10th Jan 2007, 09:04   #113
Snakez
Multimodder
Snakez's Avatar
Just picked up the chrome parts
Here is a little preview , more pics will follow later.
I love it
__________________
Old 10th Jan 2007, 09:12   #114
elliod
Multimodder
elliod is on a distinguished road
we love it , lol it really looks amazing .
keep up the good work.
__________________
sory about the english
http://s7.bitefight.com.pt/c.php?uid=23207
elliod is offline   Reply With Quote
Old 10th Jan 2007, 09:27   #115
overdosedelusion
I mostly come at night, mostly..
overdosedelusion's Avatar
overdosedelusion is on a distinguished road
sexy as!!!!!, im really pikcing up vibes of blue plexi accents around the drive bays
__________________
Lian-LI PCA71B | DFI DK X38-T2R | q6600 G0 | ATI 4870X2 | 4GB 800MHz | Enermax Galaxy | Samsung 40" 1080p | X-Fi Fatality Pro (Games) | M-Audio 24/96 |
Musical Fidelity V-Dac | Graham Slee Solo 2009 Headphone Amp | AKG K701/Audio Technica ATH-W1000 |
overdosedelusion is offline   Reply With Quote
Old 10th Jan 2007, 09:59   #116
Snakez
Multimodder
Snakez's Avatar
And some more pics.
And start rebuilding & modding the case
__________________
Old 10th Jan 2007, 10:15   #117
Mankz
ITS OVER 8000!
Mankz's Avatar
Mankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud of
wow, that chrome is beautiful....
you're gonna have to spend along time polishing it up though to get rid of all the finger prints....
__________________
Sponsored By...: HWLabs SpecialTech Feser 1
Originally Posted by DaveVader View Post
Sig'd!
Mankz is online now   Reply With Quote
Old 10th Jan 2007, 10:20   #118
Snakez
Multimodder
Snakez's Avatar
Nope , the prints come of very easy , much better then when you have them on polished allu.
__________________
Old 10th Jan 2007, 10:21   #119
Mankz
ITS OVER 8000!
Mankz's Avatar
ohh... nice...
__________________
Sig'd!
Old 10th Jan 2007, 12:01   #120
Darkened
Darkened's Avatar
Looks great, but even though fingerprints come off easily, it's still going to be a b***h to keep clean
Anyways, I think this is going to be one of the cases you can call BLING!
Janne
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
