Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 17th Nov 2006, 13:50   #1
Monkey
Multimodder
Monkey has yet to learn the way of the Dremel
Safe To Delete InstallShield Installation Information Folder ?
In C:\Program Files theres a hidden folder called InstallShield Installation Information, inside this folder is a load of folders that are { loads of letters and numbers here }. Is it ok/safe to delete the main folder its self or the sub folders as the items in this folder are takeing up around 600mb.
Monkey is offline   Reply With Quote
Old 17th Nov 2006, 14:25   #2
Arthur2Sheds
Jackson
Arthur2Sheds's Avatar
Arthur2Sheds has yet to learn the way of the Dremel
I wouldn't touch it.
Arthur2Sheds is offline   Reply With Quote
Old 17th Nov 2006, 14:52   #3
Ryszvaldo
Banned
Ryszvaldo's Avatar
Ryszvaldo has yet to learn the way of the Dremel
If you are talking about the InstallShield folder that is located in C:\Program Files\Common Files, then this can be deleted safely. The next time you install a piece of software that uses the InstallShield process rather than the Microsoft Installer (msi), then the folder will be re-created. This often becomes corrupt as a folder and it is routine to delete it in these situations. We do it in work every day, several times a day with loads of customers using our older software.
Ryszvaldo is offline   Reply With Quote
Old 17th Nov 2006, 14:54   #4
Sp!
Ultramodder
Sp! is a hoopy frood who really knows where their towel is.Sp! is a hoopy frood who really knows where their towel is.Sp! is a hoopy frood who really knows where their towel is.Sp! is a hoopy frood who really knows where their towel is.Sp! is a hoopy frood who really knows where their towel is.Sp! is a hoopy frood who really knows where their towel is.Sp! is a hoopy frood who really knows where their towel is.Sp! is a hoopy frood who really knows where their towel is.Sp! is a hoopy frood who really knows where their towel is.Sp! is a hoopy frood who really knows where their towel is.Sp! is a hoopy frood who really knows where their towel is.
If your deperate to free up 600mb I'd lookat the bigger picture, do you need a bigger disk?
you could try renaming it see if anything stops working and then delete it at a later date, but you'll probably find it's in use and it won't let you anyway.
Sp! is offline   Reply With Quote
Old 17th Nov 2006, 14:59   #5
Ryszvaldo
Banned
Ryszvaldo's Avatar
It is only used during installation of software - normally older items as most new software uses msi as it is free and you have to pay for the InstallShield license.
Old 17th Nov 2006, 14:59   #6
Arthur2Sheds
Jackson
He's not.
It's a hidden folder located in C:\Program Files\InstallShield Installation Information. It contains the information needed to uninstall several programs. While it can balloon in size and contain some folders that are no longer needed, deleting the entire folder is only asking for a headache.
I agree with Sp! - look into getting a bigger drive. 600MB is nothing to fret about these days.
Old 18th Nov 2006, 11:50   #7
Monkey
Multimodder
I dont need the space badly, i was just curious as to wether i could be deleted like the files in the temp folder can. 600mb aint that much i know but i have a 15gb partition that has only the OS on it.
All i needed to really know was can i delete and seen as the answer is no then i'll leave be.
Thanks for the replys.
Old 18th Nov 2006, 17:00   #8
simon w
Ultramodder
simon w has yet to learn the way of the Dremel
Rename the folder to InstallShield_old. If something breaks, change the name back otherwise delete it.
__________________
Sensible people know 'free' [broadband] is boll*cks. - Neil Armstrong, Product director @ PlusNet
simon w is offline   Reply With Quote
Reply
Tags
windows
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
