Thread Tools | View Mode |
#1 |
Multimodder
Project: Beyond The Grave [It Has Been Done!] [18th June 2007]
Hi and welcome to my new worklog.
This is my 2nd real build, and it will be made in red acrylic and brushed aluminium, just as my last project Temple Of NOD. Main objective of this case is to act a a fileserver, and it also needs to be relatively quiet. My old Chieftec Scorpio is quite full, and needs a replacement that looks cool, and that isn't as noisy. The case will be able to house 12 HDDs, and a lot of 120mm fans to try to keep the noise at a minimum. The name and some/most/all art are from the anime series GunGrave. It's an excellent show, and it's theme fits in nicely into my color scheme. The case will be 52cm deep, 33.6cm wide, and 37,.6cm high. I actually started the planning and some purchasing a while ago. To be exact, almost a year ago This project hasn't really been #1 priority, anyways, let's start it up. Navigation for the lazy: Update #01 [HD-cages 01] [2006-12-03] Update #02 [HD-cages 02] [2006-12-19] Update #03 [HD-cages completed] [2006-12-24] Update #04 [Corners] [2007-01-14] Update #05 [Disassembly 01] [2007-03-10] Update #06 [Disassembly 02] [2007-03-31] Update #07 [Assembly & Acrylic] [2007-04-07] Update #08 [Front 01] [2007-04-22] Update #09 [Front 02] [2007-05-02] Update #10 [Hmm] [2007-05-03] Update #11 [Front Completed] [2007-05-06] Update #12 [Top Completed] [2007-05-13] Update #13 [Stuff] [2007-05-20] Update #14 [More Stuff] [2007-05-26] Update #15 [The End Is Nigh] [2007-06-03] Update #16 [Final Touch Before...] [2007-06-14] Update #17 [It Has Been Done!] [2007-06-18] A few schematics that I actually spent time making beforehand: This is the front: ![]() * The darkest part is supposed to be a cross that is fitted about 1.5cm from the real front, and on that cross there will be 21 small parts of 1mm alu. * The 2nd darkest part is the real front which will be made of 3mm dark red acrylic, and have 4x120mm holes for fans. * The white parts will be 2mm alu. Back: ![]() * Not much to write... 2x120mm... Left side: ![]() * Text and pic engraved, 1mm alu at upper right corner. Right side: ![]() * 1, 2 & 3 mm alu on top of 3mm red acrylic. See-through on upper part. Top: ![]() * Same stuff as seen before, 1mm alu on top of 3mm acrylic. That's all for the schematics, time for some real pics... This is what I purchased nearly a year ago, two (excuse me, no hard feelings) really ugly cases. Why, WHY would I buy something as hideous as this? Well, I can't be arsed to make something to hold the 12HDDs in a good way, and even if I could be arsed, it would never turn out as good as these, same with the I/O and PCI cover at the back. Now go wai damn cases... Yesh yesh, let's make a start with the mainboard part: And the back: Temporary test to see if they fit together. This part with the mainboard, the PCI cards and slots and the I/O shield is always the most tricky part -_- There will be more... Stay tuned
#2 |
Multimodder
OK for starters im subscribing to this project due to the gr8 work with the temple of nod,
very intresting designs from your planning will be watching for more hopefully you will be able to exceed yourself. Good Luck.
__________________
This was another public service announcement from the people at Evil Inc. Have A Bad Day Til We Say Otherwise..... ![]() AMD Athlon64 3200+ (939) (CPU), Giga-byte GA-K8N Pro-SLI (MB), 1GB OCZ DDR3200 (RAM), Giga-Byte Geforce 3D1 Dual Core 6600GT PCI-E (GFX), 1x 120GB Maxtor IDE (HDD), 1x 320GB Western Digital IDE (HDD), Hiper Type R Modular 580W (PSU) Project: Evil Inc. Project: REAPER |
#3 |
Multimodder
Hiya, thanks, I hope so as well =D
A little less show, a little more user-friendly and hopefully a better weight and size than both my current fulltower and the temple... |
#4 |
Multimodder
really cool man i hope it turn out great (i loved the series).
keep up the good work. |
#5 |
a.k.a KazeModz
oh nice a Gungrave theme, great anime. ^^ I will keep close watch on this one, keep it up
__________________
Current Rig: RubyRED
• Lian-Li A05B • (2) Swiftech 220 Radiators • (2) D5 Variable Pumps • (2) Res • and a whole lot of modding • Retired Rig: Project F.E.A.R. • TT Lanbox Lite • Swiftech H2O-120 • Q6600 G0 OC@3.6ghz • 2900XT • 4gb SuperTalent Memory • |
#6 |
Grease Monkey Undergraduate..
Great-Name!!
__________________
Black Narcissus Soylent Green CopperHead PERFORMANCE-PCs Sidewinder Computer Systems |
#7 |
Sierra my delta, bravo!
Highly detailed and though-out sketches you have there! Do you think this will be comparable to Temple of Nod?
#8 |
I *am* a Dremel
Your last mod was cool and i hope the gungrave theme works out cool.
__________________
4 Men went to mow, Went to mow a meadow, 4 Men went to mow, Went to mow a meadow, ![]() ![]()
#9 | |
Multimodder
I made the schematics in scale 1:3, scanned them into my facsimile at work which mailed them home to me, and then I printed them to use them as somewhat accurate guidelines. Is there any easier way of doing it if you don't want to sketch in the comp? >< Comparable, I dunno, in some aspects it will be better, and in some it wont
#10 |
Multimodder
Looking real good.. Good luck..
#11 |
Hypermodder
WOW!!! Nice cuts!
#12 |
Multimodder
man au did you do the cut because they are stunning?
keep up the good work |
#13 | |
Multimodder
Thanks, will try to do the HDD stuff thingies next weekend.
#14 |
Multimodder
What a thing. Its awsome. you rock
__________________
Sorry for my bad English and typos... |
#15 |
mmm, yep
AWESOME! I love the layout and design. Can't wait to see more progress.
__________________
Finished:~~~~~~~~~~~~~~~~~In Progress: Project Phoenix (Lian Li PC-101B Orange Case Mod)
The "Secret of the Ooze" Modded Tt MatrixVX Modded Cooler Master Cavalier 3 My First Case Mod |
#17 |
Multimodder
Sorry for the absense of updates. I've been held back by not having the necessary materials that I needed, and having some layout problems that needed to be sorted. I'll work on the HD-cage area and the internals of the front tomorrow, and I'll hopefully update with pics saturday/sunday.
#18 |
Multimodder
I spent about 10 hrs yesterday building.
I didn't complete as much as I hoped to, but I also had to do some sketching and planning as well. I started by threading the MB plate, and It ended up almost perfect. Much better than in my last project. Some of the 6mm holes are for fitting 5mm LEDs that will (hopefully) backlight the MB, which should make it glow around the edges from the left view, and hopefully it will make the skull glow nice as well from the right view. The CD will be mounted from below so I don't have to waste time on building mounting-brackets. (I'm not gonna use this CD BTW, 1994 - Why do I keep this ****? ) This is going to be the top and bottom of the HD-cage. No plain rectangular design here. ![]() Some filing & sanding later: This will be one half of a support for the front part of the case, as well as a mounting for the HD-cage. This'll be all for this time, next weekend I should be finishing the other supports and the HD-cage mounting. Last edited by Edvuld; 22nd Apr 2007 at 02:21. |
#19 |
Ultramodder
You are ridiculous. I wish I had the skills to do that with aluminum
#20 | |
Multimodder
| Thread Tools | |
| View Mode | |
