Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Sony to fix PS3 upscaling issues
__________________
#2 |
my supersonic radar will help me!
this is why you never buy 1st gen gear
#3 |
What you Looking at Fool!
Doesnt bother me unless its not fixed by the time its launched in Europe.
![]() Alos I have not HD TV so still not a problem
__________________
| mikeuk2004 |
| View Public Profile |
| Find More Posts by mikeuk2004 |
#4 |
Can't mod my way out of a paper bag
So basically it's your fault for owning an early HDTV?
__________________
Notice: If we see you flaming we will assume you are on fire and take appropriate measures
- The Bit-Tech Fire Brigade. |
#5 | |
Hypermodder
They have basically said it's the consumers fault for buying a HDTV that does not accept a 720p input. Now if this wasn't bad enough, Sony themselves manufactured such hardware! It's almost like "I suppose we'll have to fix this then..." If I was a Sony consumer I'd disgusted with the arrogant and petulant attitude. rupbert |
#6 |
Ultramodder
I think you're taking it out of context. He was just pointing out that it wasn't the PS3 that couldn't display HD properly, it was the TVs that didn't support the resolutions the PS3 requires.
__________________
Abit AB9 Pro, Intel Core 2 Duo E6400 CPU, 2GB Corsair DDR2 6400, nVidia 8800GT, Seagate 160 GB HDD. |
| Neogumbercules |
| Find More Posts by Neogumbercules |
#7 | |
Madeira's banana is the best!!!
It should use any HD resolution that is used the majority of tv sets, if not in all tv sets.
__________________
Renegade X - 0.40 Release! <---- CLICK! |
#8 |
Ultramodder
The majority of HD tv sets use 720p. Very few only support 1080i. You're right, it should have worked with all HD resolutions out of the box. Fortunately they are now working on a patch to let it upscale and downscale correctly.
__________________
| Neogumbercules |
#9 |
Supermodder
This is quite legitimately not Sony's problem. Upscaling is a quite separate function to rendering a 3D scene. To use an analogy, it's rather like expecting your car to go and pick your groceries because it got you to the store.
It could be argued that it's the problem of the people who wrote the games to support only one output resolution. Phil |
| Phil Rhodes |
| Find More Posts by Phil Rhodes |
#10 |
hmmmm....
Well I guess most of the bugs will have been ironed out by launch, and a few revisions before I can afford one.
Considering it only affects some games suggests that it is the developers fault not Sony's.
__________________
Fight my Brute
The quantum limit of reality might be scaled up because we're all holograms. Obviously. Once more we see that sufficiently advanced physics is indistinguishable from getting really stoned. From here |
| Thread Tools | |
