Thread Tools | View Mode |
#221 |
Supermodder
@Jipa, the name for the case is carbon li. So the outside is Lian Li. The inside is real carbon. So if you think it’s going over a bit. I understand that.
![]() @Computerking, thanks.
__________________
Carbon Li 100% ready and going to Computex 08 with Point of View. Project Extreme Lian Li 100% ready Project Extreme Lian Li II Top Secret |
#222 |
Multimodder
ic that sucks that thier making green pcb 8800gtx those dont look anyware as nice as the black ones so i don tknow why they bother making them
#223 |
Minimodder
I just read this thread and this mod looks awesome!
#224 |
Supermodder
Today I continue with the side panels. First drill some little holes.
![]() And that’s fit. ![]() ![]() To protect the airbrush also a side panel on that side. ![]() And that’s fits also. ![]() On both side a panel for the symmetry. ![]() ![]() See you soon
__________________
Carbon Li 100% ready and going to Computex 08 with Point of View. Project Extreme Lian Li 100% ready Project Extreme Lian Li II Top Secret Last edited by Ediejo; 2nd Sep 2007 at 10:21. |
#225 |
Banned
Looks cool.
#226 |
Supermodder
And there is the second update from today. Continue with the double bottom.
![]() ![]() Next thing the reset and on off switch. ![]() ![]() ![]() But it’s fit. ![]() ![]() Also at the front it looks well ![]() And the tubing. ![]() Where that tape for is, you see it later. ![]() See you soon.
__________________
Carbon Li 100% ready and going to Computex 08 with Point of View. Project Extreme Lian Li 100% ready Project Extreme Lian Li II Top Secret Last edited by Ediejo; 2nd Sep 2007 at 10:22. |
#227 |
Banned
Very nice work so far!
#228 |
Licenced idiot.
Is that a Proxxxon you're using to drill? Freehand-drilling the end of a acryl with a "dremel" damn you have a steady hand and some nerves
__________________
Abit IP35 - E6750 - 8800GT 1024 MB - 2 GB 800 MHz - enough HDDs - 750 W Silverstone - CM Storm Sniper Asus P5Q-VM - Q9450 - 4 GB - 400 W Silverstone - Fortress FT01 |
#229 |
Supermodder
The tape is for marking the bottom of the plexi.
![]() Than mark the holes. ![]() After that it’s drill time. ![]() Than place the plexi back and drill the plexi from the other side. ![]() ![]() It was hard but it’s fit. ![]() The place for the pump. It will be free from the cd-rom. ![]() Some glue work to do. ![]() Also for the front. ![]() ![]() That’s dry tomorrow. ![]() And marking the hole for the power and s-ata cables. ![]() ![]() @Jipa, yes that’s a proxxon. See you tomorrow.
__________________
#230 |
Supermodder
This morning mounting the pump.
![]() This is the place for the pump. ![]() ![]() Sometimes you need luck, ore…… ![]() ![]() When i place the cover there is enough space for the tubes and cables. ![]() ![]() See you later today.
__________________
#231 |
Sierra my delta, bravo!
Pump looks ugly compared to the rest of the case. :/
#232 | |
Supermodder
__________________
#233 |
Supermodder
I think you wont be able to see them anyway.
#234 |
Supermodder
And there am I again.
The last time that I put in the main board to mark some things. ![]() All the led’s from the cover plate do it now. ![]() Nvidia say al the time two is better than one. ![]() Corsair can now say four is better than two. ![]() ![]() ![]() ![]() The tings what I will do today. The holes for the power cables. ![]() And this connector needs some more space. ![]() When I finishing this today it will be great. Than tomorrow place the harddisken and fill up the water cooling See you later.
__________________
Carbon Li 100% ready and going to Computex 08 with Point of View. Project Extreme Lian Li 100% ready Project Extreme Lian Li II Top Secret Last edited by Ediejo; 2nd Sep 2007 at 10:23. |
#235 |
What's a Dremel?
Looks very impressive, nice detailwork! Keep up the good work.
#236 |
Supermodder
The last update for today.
I keep the cables for the main board on there place with tie raps. ![]() ![]() That Nvidia logo is boring me because it’s standing upside down. ![]() That’s better. ![]() Corsair sends a couple of pci-e cables. I will use them. ![]() I place them here. ![]() Short cables are left. ![]() ![]() That’s all for today. ![]() The led’s in the bottom are standing loose, because I must take them out tomorrow. For the water cooling. ![]() And an mp4 from the cdrom. See you soon.
__________________
Carbon Li 100% ready and going to Computex 08 with Point of View. Project Extreme Lian Li 100% ready Project Extreme Lian Li II Top Secret Last edited by Ediejo; 2nd Sep 2007 at 10:24. |
#237 |
Don't mind me.
coming along very nicely
very clean and unclutterd
__________________
Of all the things I have lost, I miss my mind the most.
#238 |
Multimodder
damn that is looking nice
__________________
Project: (insert name here) -The mod no one cares about (even me) |
#239 |
Multimodder
There is some sick modding going on in this thread!
Keep on keeping on.. |
#240 |
Supermodder
Ready for the Cebit.
1 led say do it by your self. ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom Next photo’s are from the Cebit.
__________________
Carbon Li 100% ready and going to Computex 08 with Point of View. Project Extreme Lian Li 100% ready Project Extreme Lian Li II Top Secret Last edited by Ediejo; 2nd Sep 2007 at 10:25. |
| Tags |
case mod ![]() |
| Thread Tools | |
| View Mode | |
