Reply
Thread Tools View Mode
Old 17th Jul 2007, 02:31   #181
B[x]
Supermodder
B[x] has yet to learn the way of the Dremel
That's some pretty innovative work. Very nice.
B[x] is offline   Reply With Quote
Old 17th Jul 2007, 02:46   #182
MoRBiD
Multimodder
MoRBiD's Avatar
MoRBiD has yet to learn the way of the Dremel
looks good man... keep it up. why not make a different design ther then the straight bar design?
Just a suggestion...
__________________
DiBRoM
MoRBiD is offline   Reply With Quote
Old 17th Jul 2007, 13:21   #183
Franklin
Supermodder
Franklin's Avatar
Franklin has yet to learn the way of the Dremel
No, I will leave it like this and that's because they have to match with the outtakes on top of the case.
__________________
Sponsored by: AC.Ryan Sapphire Freezinghardware
Franklin is offline   Reply With Quote
Old 17th Jul 2007, 19:41   #184
Franklin
Supermodder
Franklin's Avatar
It's summer in the Netherlands but last few weeks I,ve only seen rain. But not the last days I can work outside again, much easier working on the sidepanel outside. No molds this time just some glass. Put on some moldingwax and clean it with a cloth. Ready for some polyester action. Put some resin on the glass first
Put on the first layer and use a roller to smoothen it.
The fiber glass on this picture is a special fabric that is for the surface. The endresult will be very smooth. This was the first layer. After this I added 5 more layers of the normal fiber glass.
The result was just as smooth as I wanted it to be. Does not need much work to finish the surface later on for a paintjob. Made two big holes with my Dremel for the air intakes.
And with the intakes in place.
More close ups.
The intakes and the sidepanel wil be glued together and I will use some bondo between the panel and the intakes.
__________________
Old 17th Jul 2007, 20:05   #185
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!
wow looks really good
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
The_Beast is offline   Reply With Quote
Old 17th Jul 2007, 20:51   #186
Dean MF
PC Freak!
Dean MF's Avatar
Dean MF has yet to learn the way of the Dremel
I agree! Excellent Work!!
__________________
My PC:
ECS KA3MVP Extreme Motherboard : AMD Athlon 64 X2 Dual Core 6000+ : 4 x 512mb DDRII 667mhz RAM : Radeon X1950 PRO GPU : 320 gig SATA2, 120 gig SATA2, 80 gig IDE : Raidmax Volcano 620W PSU : LG 18x DVD Writer with Lightscribe
Dean MF is offline   Reply With Quote
Old 22nd Jul 2007, 22:02   #187
Franklin
Supermodder
Franklin's Avatar
Everything is going smoothly at the moment. I can't show you much new stuff, but that doesn't mean I did not do much. I finished the second and third "fingerguard" for the outtakes for instance. A lot of work but you know what it looks like. Also opened the airintakes so I can start working on the acrylic pieces that will be mounted in there.
I also did some work on the acrylic that will lead the air from the radiator to the outtakes on top of the case.
The acrylic ( with the tape still on ) had to be cut at the top so the lid will fit over.
There is still some tape on the clear acrylic, but that will be removed ofcourse. When removed it will be possible to see through the airduct into the top of the case.
That's not what I want, because I want to use that space to hide cables and some other stuff. So in order to make it almost impossible to look into the case and see the cables I will cover the duct with some black mesh.
Bending the mesh first to fit the tube.
Looks good. It's almost ready to be cut in the same shape as the acrylic.
Next thing I can show you is my design of the logo.
The logo will not be flat but 3-dimensional and I think I will also add some lighting from behind.
__________________
Old 22nd Jul 2007, 22:32   #188
Cyprio
G5 Supermodder
Cyprio's Avatar
Cyprio has yet to learn the way of the Dremel
Amazing work with fibreglass!
I know what you mean about the rain recently - same in London, its been non-stop. At least it helps with the wet sanding!
Cyprio is offline   Reply With Quote
Old 23rd Jul 2007, 01:47   #189
dacust
What's a Dremel?
dacust's Avatar
dacust has yet to learn the way of the Dremel
Well I've never posted in your thread as I've never found anything to add to what other people were saying. But, I figured that I would at least tell you I've been watching it since I joined bit-tech in March. I always look forward to your next trick.
I especially like that you've started with a basically rectangular box and made it extremely unique. And that everything that is unique is actually functional and not just tacked on. Definitely a first class job! Can't wait to see more!
__________________
-dan
My programs don't have bugs, they just develop random features.
WaterPlant worklog - in progress - Bit-Tech article - WaterPlant site - Home Page - PowerPlant PC - Designing
Don't worry about your english. This is an international forum. That's what makes it great. If I don't understand, I'll ask. Just MOD ON!
dacust is offline   Reply With Quote
Old 23rd Jul 2007, 09:02   #190
jegerjon
Supermodder
jegerjon's Avatar
jegerjon has yet to learn the way of the Dremel
wow! brilliant work. I like your fibreglass work, I would like to do something in that later on, so I'll be watching this to the end Keep going, your working hard.
__________________
Project: Alu-case - FIN: [06/02-2007]
Project: NLM - FIN: [02/11-2007]
jegerjon is offline   Reply With Quote
Old 23rd Jul 2007, 20:13   #191
Predatator295
Minimodder
Predatator295's Avatar
Predatator295 has yet to learn the way of the Dremel
Great job, I expect the new update will be full on news (sorry for my english... I'm french)
__________________
Q8500@4.5ghz+si128, CrossfireX HD4870; 4Gb corsair dominator, P5E, Zalmann GS1000, raid raptor
Predatator295 is offline   Reply With Quote
Old 25th Jul 2007, 20:05   #192
Franklin
Supermodder
Franklin's Avatar
Waiting for some materials from AC Ryan, so I had some time for brainstorming on the logo. I want a simple logo, so I'm not going to use the whole word Evolutionary, just the first three letters E, V and the O. An other thing I wanted to do is making it different from the usual logos. I took some mdf, acrylic and aluminium ( leftover from the Lian Li case from my finished casemod ) and started cutting out the letters.
The E and the V from mdf and acrylic, the O from aluminium.
The acrylic on top of the mdf.
The mdf from the E had to be carved, so it will fit over the V.
Not finished yet, the mdf will be painted and the acrylic will be sanded, but this is what it will look like.
When finished, it will be mounted on a black surface and some leds will bring some light from behind.
__________________
Old 25th Jul 2007, 20:18   #193
Dean MF
PC Freak!
Dean MF's Avatar
Thats one hot logo dude!! Cant wait to see the LED effect.
__________________
My PC:
Old 28th Jul 2007, 14:07   #194
Franklin
Supermodder
Franklin's Avatar
You will have to wait quite a long time to see the effects, because that's about one of the last things I will do. Sorry.
A while ago, I posted a sketch from the powerbutton with the activity leds. Today I started working on this thing. It will look a lot like the drawing but it will not be exactly the same.
The aluminium, a piece left from a Lian Li casemod, was already finished. I will only need to cut a hole in the big circle for the button to fit in later on. The frosted white acrylic will have to fit in the button. I wnat to light the thing up from behind, that's why I used the frosted acrylic.
It's not that easy to get the acrylic fit into the button. But now it's almost finished. The last bit I will do by sanding it.
__________________
Old 28th Jul 2007, 15:58   #195
wbdog206
Supermodder
wbdog206's Avatar
wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.
the logo and the button set are excellent.
__________________
Of all the things I have lost,
I miss my mind the most.
wbdog206 is offline   Reply With Quote
Old 28th Jul 2007, 17:05   #196
Dean MF
PC Freak!
Dean MF's Avatar
wow! The power button is amazing! Whats the size of it?
__________________
My PC:
Old 28th Jul 2007, 17:13   #197
Supra55
Banned
Supra55 has yet to learn the way of the Dremel
Nice buttons, handmade or machined?
Supra55 is offline   Reply With Quote
Old 28th Jul 2007, 17:22   #198
SPQQKY
Evil Modder
SPQQKY's Avatar
SPQQKY has yet to learn the way of the Dremel
Your extremely talented. Fantastic work.
__________________
I could be bounded in a nutshell and count myself a king of infinite space, were it not that I have bad dreams.
Core2Duo E8400 @ 4GHz - Gigabyte GA-EP45-UD3P - 4 x 2 GB G.Skill Pi Black-6400C4 - eVGA GeForce GTX 260 - Auzentech X-Plosion
1 x 250GB and 2 x 300GB Barracuda - LaCie 1TB BD - Corsair CMPSU 620HX - etc., etc.
SPQQKY is offline   Reply With Quote
Old 29th Jul 2007, 21:22   #199
Mino
Ganzerli Mino
Mino's Avatar
Mino has yet to learn the way of the Dremel
As usual, a really good mod, and a really good amount of explanation!
I'm reading your worklog to learn some techiniques to work with fiberglass, and the idea to have the center of the mould to press the fabric is fantastic!
Tnx a lot for the time that you spend with your explanation, really tnx a lot!
BTW, good progress for this project, but the power button is amazing!
On the other side, the logo imho is too protunding, but I wait to see it in place before say more...
__________________
ItaliaModding.it Staff - Italia Modding Club Member
My project ::: Project AralT3 - Project UltraViolet - Impossible Modding
Mino is offline   Reply With Quote
Old 29th Jul 2007, 22:21   #200
Cyprio
G5 Supermodder
Cyprio's Avatar
Great logo and front panel franklin - what do you use to draw out and make your cuts? They looked machined!
Or do you just have a very steady hand?
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
