Reply
Thread Tools View Mode
Old 24th Feb 2007, 22:28   #61
Damouse
Thats no moon!
Damouse's Avatar
Damouse has yet to learn the way of the Dremel
more more more!
suscribed in a heartbeat
__________________
Dummm.
Damouse is offline   Reply With Quote
Old 1st Mar 2007, 19:20   #62
Franklin
Supermodder
Franklin's Avatar
Franklin has yet to learn the way of the Dremel
I started working on the acrylic with my new machine, it was a cheap thing but it is good enough for what I will need to do with it. I made some holes in the acrylic for the radiators.
Because the acrylic isn't wide enough to cover the whole case I had to use two pieces. Here you can see one piece for the first radiator.
and the two pieces. On the left side it is hard to see, because I already removed the tape from the acrylic. You can also see I started closing the frame at the back of the case.
On the left side you can see where the first radiator will be mounted. The other one will be placed on the right side.
Franklin is offline   Reply With Quote
Old 1st Mar 2007, 20:05   #63
Faried112
Modder
Faried112 has yet to learn the way of the Dremel
Nice, can you make some photo's a little further away. I think this case will be huge, keep on going
Edit: 5 Stars for you
Faried112 is offline   Reply With Quote
Old 1st Mar 2007, 21:48   #64
Duste
Sierra my delta, bravo!
Duste has yet to learn the way of the Dremel
Very clean cut there dude, nice work!
Duste is offline   Reply With Quote
Old 2nd Mar 2007, 08:43   #65
brinkz0r
Hypermodder
brinkz0r's Avatar
brinkz0r has yet to learn the way of the Dremel
Every cut Franklin makes is clean, the perfectionism is always there
__________________
My casemodding company: Brink of Modding
My latest casemod: miXture
Custom reservoirs and more: Phase 2 Casemodding
brinkz0r is offline   Reply With Quote
Old 2nd Mar 2007, 10:12   #66
jokkos
Belgian beer modder
jokkos's Avatar
jokkos has yet to learn the way of the Dremeljokkos has yet to learn the way of the Dremel
okay, after seeing the rad cut in the case, I'm starting to see how big it'll become. wow.
__________________
Der_Meister: 100% completed, again... project log here.
jokkos is offline   Reply With Quote
Old 2nd Mar 2007, 16:53   #67
Franklin
Supermodder
Franklin's Avatar
Yes it's big, but I will need every inch. When you watercool a computer you always have a problem. If you use air from the case for the radiator the air is already a bit warm, and if you suck in air you get the warm air from the radiator in your case. Only solution is to bring the radiator outside the case, but that doesn't look good to my opinion. So my solution is to seperate the airflows with airducts.
Old 4th Mar 2007, 15:26   #68
Franklin
Supermodder
Franklin's Avatar
Today I started working on the box for the harddisks. I will use an old watercoolingblock for the harddisks and also a normal fan.
First I needed to create piece of acrylic to mount the fan. I want it to fit in the front. I think it fits great.
Just taped the box together to see if everything fits.
I placed the dempers beside the box to get an idea what it will look like.
Old 4th Mar 2007, 15:31   #69
Duste
That looks so nuts with the bloody dempers there.
Old 4th Mar 2007, 15:35   #70
Bas van der Werff
Multimodder
Bas van der Werff's Avatar
Bas van der Werff has yet to learn the way of the Dremel
I followed your Alumaxx and i loved it can't wait how this is going to work out.
That HD box looks fantastic
__________________
Radical Fusion update [9th June 07]
If you're putting more blood into you're project than sweat, double check that you're holding the tool correctly.
Bas van der Werff is offline   Reply With Quote
Old 4th Mar 2007, 15:36   #71
ottzen
Minimodder
ottzen has yet to learn the way of the Dremel
Yeah, and imo the good kind of nuts
Really sweet, Franklin! Love it
//ottzen
__________________
Finally!! --Intel E6320 w/ Sonic Tower | Gigabyte GA-965P-DS3 Rev.3.3 | 2GB G.Skill F2-6400PHU1-2GBHZ | Gigabyte 8600GTS Silent | Samsung HD080HJ (80GB) + Barracuda 7200.7 (200 GB) | all warm and cosy in a Stacker 830 w/ Noiseblocker 120ies
ottzen is offline   Reply With Quote
Old 4th Mar 2007, 16:00   #72
culley
Hypermodder
culley's Avatar
culley has yet to learn the way of the Dremel
I am interested in this cant wait to see how it looks when you put it together what will you be using to stick it together??
__________________
[Intel Core i5-2500k | Gigabyte P67A-UD4 | Corsair XMS3 4GB | 1GB Sapphire HD 6850 | 3TB HDD | Hiper 540W PSU]
[Ubuntu Home File Server]
[CompTIA A+ Certified][Cisco CCNA Certified]
culley is offline   Reply With Quote
Old 4th Mar 2007, 16:48   #73
Franklin
Supermodder
Franklin's Avatar
I'll have to wait for some materials before I can work on this box any further. I want to add a lot of details to this harddisk box. It will pobably take me 4 weeks to finish it i guess. For the acrylic I will use some special glue and some aluminium will also keep it together.
Old 6th Mar 2007, 18:47   #74
Franklin
Supermodder
Franklin's Avatar
The first aluminium 'ring' that will be placed over the box is ready. I'll need 4 of these aluminium parts to mount the shocks. The shocks will be mounted between two of these rings.
the front view.
and from a slight angle
It took me about 4 hours to produce this ring, so that means I have about 12 hours of work for the other 3 rings.
__________________
Sponsored by: AC.Ryan Sapphire Freezinghardware
Old 6th Mar 2007, 18:58   #75
ottzen
Minimodder
Looks good though! And the first one is always the hardest and the following times you'll be quicker
With good music and a nice, cool beer work always goes down in a gulp...or two
//ottzen
__________________
Old 6th Mar 2007, 18:58   #76
P.P InDaHouse
Minimodder
P.P InDaHouse has yet to learn the way of the Dremel
you have good ideas, congratulations, that looks nice
P.P InDaHouse is offline   Reply With Quote
Old 6th Mar 2007, 19:22   #77
guysy1110
Multimodder
guysy1110 has yet to learn the way of the Dremel
hot stuff man. good work. i like the progress a lot !
guysy1110 is offline   Reply With Quote
Old 9th Mar 2007, 21:53   #78
Franklin
Supermodder
Franklin's Avatar
Just a small update. The second aluminium ring is ready. I expect to finish the last two rings this weekend so I can start working on the details of the box. The shocks will be mounted between two aluminium rings, that's what the bumbs on the side of the rings are for.
__________________
Old 10th Mar 2007, 15:59   #79
Franklin
Supermodder
Franklin's Avatar
All the rings are ready, I only will have to clean them, sand the edges and driil the holes to mount the schocks. The shocks will be mounted like this.
It is time to add some details to the box.
__________________
Old 10th Mar 2007, 16:28   #80
Duste
One question, how is that fan mounted? I can't see any screw, but I can see that it's a very tight fit with the acrylic - is that all that's holding it?
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
