Reply
Thread Tools View Mode
Old 1st Apr 2007, 15:27   #101
DeKemp
BEER.
DeKemp's Avatar
DeKemp has yet to learn the way of the Dremel
Great job, .
__________________
_____________________
Intel Core 2 Duo E6600 2.7Ghz, Geforce7900GT 580/1380Mhz.
Unbreakable Casemod In Progress Dutch.
CASEJUNKIES.COM
DeKemp is offline   Reply With Quote
Old 1st Apr 2007, 16:38   #102
Franklin
Supermodder
Franklin's Avatar
Franklin has yet to learn the way of the Dremel
Camera is working again, so here is the image from the hood over the frame. It needs lots of work, sanding, need to cut out some areas for the airducts and for some other things. When this all is finished it will be painted. The fibreglass at the bottom sticks out, but that will be removed so no problem at all.
Franklin is offline   Reply With Quote
Old 1st Apr 2007, 19:53   #103
wbdog206
Supermodder
wbdog206's Avatar
wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.
going to a slick mod when done!
__________________
Of all the things I have lost,
I miss my mind the most.
wbdog206 is offline   Reply With Quote
Old 1st Apr 2007, 20:22   #104
Franklin
Supermodder
Franklin's Avatar
This week I will be working on two other pieces of fibre glass that wil be mounted in this big hood. An image will make it more clear I think. The areas that are marked in black will be removed from the fibreglass.
The part in the left corner will be made this week and will also be fibreglass.
In the end it will look something like this.
In the openings I will place some acrylic, just like in the sketch some pages ago.
Old 5th Apr 2007, 19:57   #105
Franklin
Supermodder
Franklin's Avatar
The only place I can cut the polyester is outside in the garden because cutting or filing it creates an enormous dustcloud. I have to wear a mask and after work I just have to take a shower to remove all the white dust.
First mark the area that I'll have to cut away with my Dremel. The openings for the fibreglass airduct will be cut later on, after finishing these parts.
I didn't know if it was hard to cut the fibreglass so I took some distance from the marking. In fact it was easy to cut, but to be on the safe side I don't cut on the marking.
This is the model for the fibreglass part that I will create this weekend.
Keep the model in place, ofcourse this will also be fibreglass, but just to see what it will look like.
I had to draw an ellips. Need one half of this ellips to mark the lower opening for the airducts.
Old 5th Apr 2007, 20:34   #106
vortex46
What's a Dremel?
vortex46 has yet to learn the way of the Dremel
wow,very cool project,keep it up
vortex46 is offline   Reply With Quote
Old 6th Apr 2007, 16:05   #107
Mino
Ganzerli Mino
Mino's Avatar
Mino has yet to learn the way of the Dremel
What the hell! I've missed this worklog, but now I'm subscribed! Good work with the fiberglass, and the ideas for the airduct are stunning! I was searching for the plastic frame corner here in Italy, but nobody have seen before something like that, I'll order them at your same shop...
Anyway, I'm so curious about the dust filter, it's a new idea and I love to learn form you!
__________________
ItaliaModding.it Staff - Italia Modding Club Member
My project ::: Project AralT3 - Project UltraViolet - Impossible Modding
Mino is offline   Reply With Quote
Old 6th Apr 2007, 17:02   #108
marauder16
Multimodder
marauder16's Avatar
marauder16 has yet to learn the way of the Dremel
wow, this is some really great stuff, where do you get such ideas, amazing, keep it up
__________________
my past project, (P180) UV flame - last update 10/23/2008... - project finished
- was planning: U2-UFO Extended CYO, dual loop - but I couldn't call it mod but "assembly" so I decided not to make a project.
marauder16 is offline   Reply With Quote
Old 8th Apr 2007, 13:52   #109
Franklin
Supermodder
Franklin's Avatar
Ready to make two more fibreglass parts. I need two of these parts for the right side and the left side of the case.
The parts came of pretty well. Only need to cut of some material at the edges. I leave some material at these edges for mounting it to the big fibreglass part I made earlier.
With an ordinary Dremel I cut away all the stuff that isn't needed. Quite a dusty job. I wear a mask and work outside.
Later on I will draw the ellipses on the parts and cut them out.
Old 8th Apr 2007, 19:08   #110
elbarto241
Multimodder
elbarto241 has yet to learn the way of the Dremel
damn that is a lot of dust.
the fiberglass is coming out swEEt. keep it coming ^_^
elbarto241 is offline   Reply With Quote
Old 10th Apr 2007, 14:11   #111
mario_cell
Multimodder
mario_cell's Avatar
mario_cell has yet to learn the way of the Dremel
Wow, I think this mod will be horrible AWSOME
__________________
There are 10 types of people in the world.
Those who understand binary and those who don't.
Project DARK CRYSTAL
mario_cell is offline   Reply With Quote
Old 11th Apr 2007, 09:56   #112
Neji
Multimodder
Neji's Avatar
Neji has yet to learn the way of the Dremel
Hehe 'horrible awesome'.....I like it and I agree!
Neji is offline   Reply With Quote
Old 11th Apr 2007, 21:43   #113
Franklin
Supermodder
Franklin's Avatar
I bought a cheapass electrical sanding machine, because I have to smoothen te surface from the lit. By hand it would take me ages. I'm glad I bought it, because it saves me lots of time.
The top of the case is almost ready, the sides will be done next days. Ofcourse I wear a mask while working on it. I almost look like a snowman after sanding
When all the sides have been sanded I will use a special kind of bondo to fill up every little hole and wetsand it afterwards. To be able to cut of the small airducts straight my dad made something for me. Now I can saw it and all the airducts will be the same size.
Worked great. Now I can mark the lit. This has to be cut of for the airducts.
The holes look a bit big, but when the airducts are placed it already looks a bit better.
and that's not all, I will also create some sort of fingergard from acrylic. Looks fantastic, but you will have to wait for that.
Old 11th Apr 2007, 22:33   #114
gvblake22
mmm, yep
gvblake22's Avatar
gvblake22 has yet to learn the way of the Dremel
I agree with an earlier poster, this project is more revolutionary than evolutionary! Awesome work, thanks for all the great updates!!!
__________________
::: Phoenix ::: Secret of the Ooze ::: Blue Flame ::: Cavalier 3 ::: First Mod :::
gvblake22 is offline   Reply With Quote
Old 12th Apr 2007, 15:13   #115
Mino
Ganzerli Mino
Mino's Avatar
Every time that my mailbox have a mail from bit-tech I hope that is an alert for your thread... It look so amazing , I'm so interested in fiberglass working, and I hope to learn something for you!
__________________
Old 12th Apr 2007, 17:21   #116
derbaum
Multimodder
derbaum has yet to learn the way of the Dremel
fellows listen to your dads . rumors told me, sometimes they know some tricks.
i´ll keep an eye on your project. workin with fibrestuff really attracts me.
__________________
my case: carbon-fever!
- pure carbon madness
my blog: botchjob.wordpress.com
crafty & electronics stuff - english content too!
derbaum is offline   Reply With Quote
Old 16th Apr 2007, 21:18   #117
Franklin
Supermodder
Franklin's Avatar
I cut some holes in the lit for the airducts with my fake Dremel.
I numbered the holes and the airducts, it's all handwork so there all the ducts are slightly different and fit only perfectly in the hole with the same number.
After three days of bondoing and sanding the lit is almost smooth. I will need to wetsand the lit one more time.
I want to glue the airducts to the lit and want to use some UHU 2 components glue for this job. On the UHU website it says
Metals, glass, porcelain, ceramic, wood, marble, stone, concrete, Duroplast®, glass fibre reinforced synthetics, rigid PVC, rubber, rigid foam plastics such as Styropor®. Not suitable for sticking large areas of glass.
So I think it will work, but to be sure I will try it on some leftovers first.
Old 17th Apr 2007, 01:24   #118
B[x]
Supermodder
B[x] has yet to learn the way of the Dremel
I'm curious - when viewing the vents from the front, how circular do the openings appear?
I've been following this build since its inception and have got to say that you've got quite the imagination. Keep up the good work.
B[x] is offline   Reply With Quote
Old 17th Apr 2007, 18:37   #119
ThomasM
Modder
ThomasM has yet to learn the way of the Dremel
ohh man, it is verry verry cool.
i want more
__________________
Projekt: Water Cycler
Projekt: Mädler Casecon (Black BOX) (4 Engines in Case)
ThomasM is offline   Reply With Quote
Old 17th Apr 2007, 18:55   #120
derbaum
Multimodder
on the place i worked for some time we just glued everything with the resin used for laminating.
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
