#141 |
LIKE AN ANIMAL!
Reminds of those masks they're wearing at some kinda asian martial sport... Kendo? The one with the sticks... Gotta give google a go.
![]() // edit: Here we go: (hands up for Wiki) // edit 2: Taking a 2nd look and I got an idea: What about a transversal piece of acryl like the perpendicular one seen on the mask. Can you understand what I mean... if I were you I wouldn't.
__________________
The most merciful thing in the world, I think, is the inability of the human mind to correlate all its contents. We live on a placid island of ignorance in the midst of black seas of infinity, and it was not meant that we should voyage far. ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn Iä! Iä! Cthulhu fhtagn!
#142 | |
Supermodder
I turned your pic over 90 degrees and gave the part a green color.
#143 |
LIKE AN ANIMAL!
YOU GOT ME! I'm happy now.
![]() Yea, that's exactly what I meant. Glad I could "help".
__________________
#144 |
Supermodder
Almost there....
![]() I started filing all the pieces as you can see. The outer piece on the right is the best place to look what I mean. I will have to add one small piece of acrylic on the sides and then it needs more filing and sanding before I can use a small torch to make it shiny again. It already took me four days to get this far and I will have to do this work another three times
#145 | |
Supermodder
I don't think you need to incorporate a horizontal piece for aesthetic reasons. To me it would clutter up the clean look that the vent has. However, you mentioned that the grill is a bit fragile so perhaps it is necessary. |
#146 |
I like wood ಠ_ಠ
great looking mod, keep up the good work
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
#147 |
Ganzerli Mino
The look is fantastic!
Now I know what you told previously, and it's f++ink awesome!
__________________
ItaliaModding.it Staff - Italia Modding Club Member
My project ::: Project AralT3 - Project UltraViolet - Impossible Modding |
#148 | |
Multimodder
Secondly, g'day Franklin. I've just registered on Bit-Tech and noticed someone and their mod that I'm familiar with. ![]() Oh, and you've heard my praises before, but one more for the record won't hurt. Top work! Looking forward to each update. |
#149 |
Supermodder
Welcome to Bit-tech GAM. I don't post much in other worklogs here or on other forums, but I read almost every worklog.
The first fingerguard is finished for now. I will clean it up later. I starting to doubt wether I should add that reinforcement. I will create one and if it doesn't look better I will forget it. The construction doesn't need it. I expected the contruction to be much more fragile before I started on the fingerguard. ![]() Now you can see why I made the aluminium construction the way I did, with that strange looking top. That's the place, lefttop and righttop where the vents are now. ![]() ![]() I will start on the other three guards later on. Want to do some other things now. I hope the weather will get better so I can start on the fibreglass sides for the case. Last edited by Franklin; 26th Dec 2007 at 15:07. |
#150 |
mmm, yep
I'm diggin' the vent covers, they look great! Keep it up!!!
__________________
::: Phoenix ::: Secret of the Ooze ::: Blue Flame ::: Cavalier 3 ::: First Mod ::: |
#151 |
PC Freak!
I must say - this is coming out better than i expected - Great work Franklin!!
#152 |
Supermodder
After all the work on the fingerguard I wanted to work on other things for a while. A little less fragile parts. I had to close the gap from the radiator to the top of the lid. This because the air must be forced to go from the radiator to the vents on the lid. I used a piece of acrylic and cut out a small piece for the aluminium frame.
![]() Here the part is in place. You can see it on the right of the picture. Another piece will be mounted on the left as well. ![]() The piece I cut out to fit around the aluminium tubing. ![]() And a photograph with the radiator in place. ![]() Right now you can still see through the transparant acrylic, but that will have to change. Last edited by Franklin; 26th Dec 2007 at 15:08. |
#153 |
Supermodder
After a long time without any updates, a small update again. I've been very busy with "real life" stuff and had very little time to work on the case. I also had some problems getting the materials I needed, still have b.t.w.
The car airintakes I wanted to use still are not delivered and I'm not going to wait for those anymore. I will make them myself from fibreglass ofcourse. I use some MDF to create a mold for the fibreglass. This is a drawing frm the mold. I will glue three layers of MDF together. On the left you can see what material I will have to file of to get the shape I want, on the right side. ![]() When this is done I will saw the mold under an angle like this. ![]() So first saw some MDF. ![]() Drill a hole in the smallest one. ![]() Now I can saw a bigger hole in this layer. ![]() Time to glue these parts together. ![]() With a file I will remove the material to get a rounded shape. ![]() I made a paper mold with the rounded shape. When I hold it against the side of the MDF I can spot the places I have to file more to get the right shape. ![]() and after sanding the mold.
#154 |
Supermodder
very nice :P
__________________
NEW!!! X2 4200+| 2 x XFX Geforce 6600 gt in SLI | Asus A8N-SLI Deluxe | 4 x hitachi 250 gb sata hdd + Maxtor 160 usb 2.0 total of 1160 GB | 2 x 1024 MB DDR-400 (2 GB ) | Tagan U force 580 Watt | Saving money for an macbook and an Iphone (2nd edition)
#155 |
mmm, yep
He's back!!! WOOOO!
![]() I'm still having a hard time visualizing all these parts together, so I can't make any "real" comments quite yet. But I just wanted you to know I think you're doing great work so far, thanks for the update!
__________________
#156 |
Supermodder
glad to see you back at it.
nice work on the mold there.
__________________
Of all the things I have lost, I miss my mind the most.
#157 |
Multimodder
this looks freakin awesome man... cant wait to see the continued progress . lovin it w00t!
__________________
DiBRoM
#158 |
Ganzerli Mino
It's amazing to see how you work with fiberglass!
Go on, show me more :-]
__________________
#159 |
The Right man in the Wrong place
i cant wait to see more! this looks like it will be a truly amazing custom case
#160 |
Supermodder
It's time to finish the fibre glass mold. The most difficult part right now to saw the mold under an angle of 20 degrees. For this I made another mold. The base of the sawingmold has to be 90 degrees.
![]() Now add the sides of the sawingmold. ![]() The glue will be dry in a couple of hours. Before I start sawing I will add some scres in the mold. So I will put in the MDF fiber glass mold and secure it there. A sawblade will be guided by the opening in the sides of the sawing mold. ![]() I should and up with a nice 20 degrees angle like in this sketch ![]() The last job will be glueing the fiber glass mold onto a piece of MDF and finish the surfae with polyurethane resin. I will use this mold a least four times, maybe even 6 times. I will have to see what looks better, 4 or 6 airintakes. Last edited by Franklin; 26th Dec 2007 at 15:10. |
| Thread Tools | |
| View Mode | |
