Reply
Thread Tools View Mode
Old 7th Jul 2007, 17:35   #161
Franklin
Supermodder
Franklin's Avatar
Franklin has yet to learn the way of the Dremel
Ok the thing is ready for sawing.
Here we go.
The last bit has to be done outside the sawing mold.
Almost ready.
Franklin is offline   Reply With Quote
Old 7th Jul 2007, 18:32   #162
Nsonic
Minimodder
Nsonic has yet to learn the way of the Dremel
Really nice, Did you sanded the circle with hand?
__________________
Keep breathing.
Did you ever got a DremelSlap in your face?
Nsonic is offline   Reply With Quote
Old 8th Jul 2007, 10:17   #163
330td
Multimodder
330td's Avatar
330td has yet to learn the way of the Dremel
Wow impressive works
__________________
DREMEL ON - Remèdes de grand-mère
330td is offline   Reply With Quote
Old 8th Jul 2007, 10:43   #164
Colossous
Hypermodder
Colossous's Avatar
Colossous can run CrysisColossous can run CrysisColossous can run CrysisColossous can run CrysisColossous can run CrysisColossous can run CrysisColossous can run CrysisColossous can run Crysis
That really is some great work Franklin !
Colossous is offline   Reply With Quote
Old 8th Jul 2007, 12:52   #165
Pfaffen
Supermodder
Pfaffen's Avatar
Pfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run Crysis
Very nice work.
__________________
Pfaffen
Wood Case Mods: Completed: World Map, Fibonacci, Canary Mesa, Molesworth, Cray-1, Federal Cellarette, Newbery TARDIS
Wood Case Mods: Under Construction: Vogel Haus, Four Hokusai Cases
Pfaffen is offline   Reply With Quote
Old 8th Jul 2007, 21:18   #166
Franklin
Supermodder
Franklin's Avatar
@ Nsonic: yes it's done by hand.
I tried to make the first polyester airintake, but I had some problems. The shape was to difficult to make this way. I have a solution but that needs to be painted three times with the polyurethane again. I'm sure the problem is solved, so you can expect a photograph off an polyester airintake this week.
Just to give you an impression of what it will look like I Photoshopped a picture from the mold.
So this is what you will see on the left and right side from the case.
Old 8th Jul 2007, 21:28   #167
Nsonic
Minimodder
Nice work franklin, thx for the reply
__________________
Keep breathing.
Old 10th Jul 2007, 23:26   #168
Franklin
Supermodder
Franklin's Avatar
After the small problem I'm ready to give it another try.
Time to put on the latex gloves again and mix the resin. I used more layers of fiber glass this time, because it has to be much stronger this time and the outside isn't important, because this polyester part will only be the mold that I will use to make the final product. I need a negative.
It's important that the polyester part is a perfect negative of the MDF mold. So I used a MDF disk to push the fiber glass in the corners and keep it there untill the resin is cured.
Just before the resin had cured I pulled out the disk with the hook. I had some problems this time getting the polyester off from the MDF mold. Drilled a hole in the middle to let the air in, but that wasn't enough to do the job. My old man had a great idea, put the mold with the polyester in the freezer and yes it worked The polyester came of without any problem.
This is the final mold I need. This polyester mold I will use to create the four intakes.
Old 10th Jul 2007, 23:51   #169
jokkos
too busy to mod *sigh*
jokkos's Avatar
jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.
that mold looks pretty sweet, good job!
__________________
Der_Meister: 100% completed, again... project log here.
jokkos is offline   Reply With Quote
Old 11th Jul 2007, 01:45   #170
wbdog206
Supermodder
wbdog206's Avatar
wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.
very nice.
__________________
Of all the things I have lost,
I miss my mind the most.
wbdog206 is offline   Reply With Quote
Old 11th Jul 2007, 02:31   #171
GAM
Multimodder
GAM's Avatar
GAM has yet to learn the way of the Dremel
Good job Franklin. Heat and cool are good things to remember when things are tight, well done!
GAM is offline   Reply With Quote
Old 12th Jul 2007, 19:29   #172
HollowFrank
Minimodder
HollowFrank has yet to learn the way of the Dremel
Well it's quite a beast, but one of precision engineering. I've always been a fan of the ducting, no pun intended. Keep it up and it'll be a cracker of a case.
__________________
If great minds think alike, does that mean all great revolutionary thinkers were dumb, nutters or both?
Tinkering and learning, my mods shall come and they will be great for all to behold.
HollowFrank is offline   Reply With Quote
Old 15th Jul 2007, 20:06   #173
Franklin
Supermodder
Franklin's Avatar
I had to adjust my plans slightly. It was to difficult to use the negative as a mold, so I will use the mdf mod. This means I will have to spend more time to give the surface a smooth finish with polyester bondo and sanding. No big problem.
I started with drawing a shape on paper. This is the shape I need to cut from the fiber glass. Put the paper on top of the fiber glass and mark it.
Cut it out three times, because I need three layers.
and ready for use.
The mdf mold is waxed and ready to be used again. First apply some resin on the mold. When the mold is waxed in the right way, the resin seems to try pulling together and form some kind of drops. This is good, because it means the polyester will come off easier later on.
Put the first layer over the mold.
Applied the resin in the middle.
With the tip of the bruh I tapped the resin onto the fiber glass. Tap, because you want the remove any aitbubbles underneath the fiber glass.
To prevent the fiber glass coming loose again, when tapping the outside of the mold I used some kind of plug. Also made from mdf and also treated with the molding wax.
The plug is slightly smaller then the hole, this because the lauyers of fiber glass will need some space ofcourse.
Working from the edge on top of the mold, down to the bottom of the mold.
It's easy to see when all the fiber glass is soaked with resin.
Time to take out the plug and repeat the whole processa another two times.
I will have to sand the intakes and apply one more layer of surface tissue. This because it will be easier to smoothen the surface. Right now the intakes look like this, a bit rough but that will change in a couple of days.
I will remove the orange area. Some sort of fingerguard will be placed in this opening later on.
Old 16th Jul 2007, 00:53   #174
zhangmaster12
Hypermodder
zhangmaster12's Avatar
zhangmaster12 has yet to learn the way of the Dremel
evolutionary work dude!
__________________
Project Dimension 2400
zhangmaster12 is offline   Reply With Quote
Old 16th Jul 2007, 02:16   #175
KaotiK
Modder
KaotiK's Avatar
KaotiK has yet to learn the way of the Dremel
WOW. Love your fiberglass work. Been following this on another forum but things are much more exciting over here. Keep it up
KaotiK is offline   Reply With Quote
Old 16th Jul 2007, 05:03   #176
Dean MF
PC Freak!
Dean MF's Avatar
Dean MF has yet to learn the way of the Dremel
Nice work Dude
__________________
My PC:
ECS KA3MVP Extreme Motherboard : AMD Athlon 64 X2 Dual Core 6000+ : 4 x 512mb DDRII 667mhz RAM : Radeon X1950 PRO GPU : 320 gig SATA2, 120 gig SATA2, 80 gig IDE : Raidmax Volcano 620W PSU : LG 18x DVD Writer with Lightscribe
Dean MF is offline   Reply With Quote
Old 16th Jul 2007, 11:41   #177
TapperSwe
Supermodder
TapperSwe's Avatar
TapperSwe has yet to learn the way of the Dremel
Im amazed at all the work u are puting in to this project,i also love the fact that u are making all the parts by yourself since i know how much more work that is than buy ready-made parts.I cant wait to see this scratch build finished.
__________________
Build done:The Legacy of King Khufu:
http://forums.bit-tech.net/showthread.php?t=129157
Speakers Done:
http://forums.bit-tech.net/showthrea...129157&page=11
TapperSwe is offline   Reply With Quote
Old 16th Jul 2007, 17:54   #178
Franklin
Supermodder
Franklin's Avatar
After sanding the polyester intake it already looks a lot better. I sanded the part with sandingpaper grid 400 and I will have to sand it further with sandingpaper up to 1200. Also started making a paper model from the guard that will be mounted inside the opening of this intake.
It will be made from white frosted acrylic and it will be mounted somewhat deeper then the paper model.
Old 16th Jul 2007, 18:38   #179
Hugo.B
Supermodder
Hugo.B has yet to learn the way of the Dremel
This mod is the one I anticipate most, it looks very good so far.
H.B.
Hugo.B is offline   Reply With Quote
Old 16th Jul 2007, 20:05   #180
500mph
The Right man in the Wrong place
500mph's Avatar
500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel
wow, i love what you are doing here. it looks absolutely fantastic.
500mph is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
