Thread Tools |
#1 |
Brett Thomas
Biggest malware threats still work on Vista
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo |
#2 |
Supermodder
They might be the biggest threats in Nov but then again Vista did go Gold at the start of november meaning MS would be unable to fix the bugs at the time of release of Vista, unless an update has been released.
I will have to check mine when back at home Kimbie |
#3 |
Madeira's banana is the best!!!
lets see if this is limited to malwares and not viruses and trojans.
__________________
Renegade X - 0.40 Release! <---- CLICK! |
#4 | |
Can't mod my way out of a paper bag
__________________
Notice: If we see you flaming we will assume you are on fire and take appropriate measures
- The Bit-Tech Fire Brigade. |
#5 |
Supermodder
-__-
anyway i ordered a macbook
__________________
Teh Case coming soon............maybe (well...by now it's just a lian li a05b )
#6 |
Multimodder
I started a thread on this yesterday, but it kind of flew under the radar I guess. Anyway, I don't think any OS can be completely secure, as it's difficult to mitigate against the actions of the user, like for example opening attachements on emails that contain trojans and phishing scams. One of the good things about the MS os is that they work with just about any application out there. That's one of the weaknesses, as applications can make a system vulnerable. As has been said before, the only secure sytem is one thats switched off! Most of us are going to use our own preferred apps for email etc, so it sounds like the same old same old.
| trailblazer |
| View Public Profile |
| Find More Posts by trailblazer |
#7 |
Multimodder
Malware...I am more concerned that Vista has a virgin IP stack that is completely unproven in the wild as yet, that has the potential to be really scary.
As trailblazer rightly says you can only protect so much before the actions of the user overide your best coded intentions anyway. I think MS will always lose the battle when it comes to security, nothing written cannot be cracked at some point, it just happens quicker with windows as it is the most attractive target.
__________________
I wish I hadn't said that!
| Thread Tools | |
