RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 19th Dec 2006, 18:30   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
NVIDIA releases new 680i BIOS - fixes problems?
http://www.bit-tech.net/news/2006/12...ixes_problems/
Tim S is offline   Reply With Quote
Old 19th Dec 2006, 18:43   #2
Gunsmith
my supersonic radar will help me!
Gunsmith's Avatar
Gunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant future
i must be one of the lucky ones, ive not had a single problem since installing it, could it be that im running my drives at 3GBs?
__________________
People who optimise code are wimps. My code knows it's awesome, so it'll take all the time it needs. You can wait in awe
Gunsmith is offline   Reply With Quote
Old 19th Dec 2006, 19:11   #3
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
It doesn't affect every board, which is why it's a tricky problem to track down (and fix) - I'm glad you've been luckier than we have, I'd be about ready to throw the board back at NVIDIA/EVGA if I was a paying customer and had gone through three boards.
Old 19th Dec 2006, 21:52   #4
samkiller42
KEEP IT CLEAN!
samkiller42's Avatar
samkiller42 is a jewel in the roughsamkiller42 is a jewel in the roughsamkiller42 is a jewel in the roughsamkiller42 is a jewel in the rough
Hum, i also think im lucky with my board, just unlucky with the ram im using, would you recomend me upgrading the bios with this tim?
Thanks for using a small slice of my thread as well
Thanks
Sam
Edit: Tim, this is the ram im using (2*1gb)http://www.corsairmemory.com/corsair...X1024-6400.pdf, can you tell me if it is good or not, im also thinking of replacing the EVGA with a striker, would this ram be ok in the striker, cheers Tim
__________________
The Rig: i7 920 D0, Gigabyte EX58-UD5, 12GB DDR3 1600mhz, BFG GTX295, Samsung 64gb SSD, WD 640gb Black, Samsung F2 Eco 1TB, Dell 3007WFP, Windows 7 RC.
The Netbook: Samsung NC10 Black, Intel Atom, 2gb DDR2
Xbox Live: samkiller42¦PSN: samkiller42¦Bungie: samkiller42
samkiller42 is offline   Reply With Quote
Old 20th Dec 2006, 10:47   #5
phat-ant
Modder
phat-ant is on a distinguished road
no problems on my board so far touch wood.
but will probably update the bios just for fun
phat-ant is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
