News Intel silently revises Core 2 Duo
Discussion in 'Article Discussion' started by Da Dego, 19 Dec 2006.
  1. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
  2. Guest-23315
    Guest-23315 Guest
    that seems like a good move by Intel.
  3. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    I've been told that the 6300 and 6400 are actually cut-down Conroes. The "true" Allendales are the future 4300 etc chips from Intel, with lower FSB's etc.. :)
  4. Da Dego
    17 Aug 2004
    Yep, that's true - at the time C2D was released, Allendale was the name applied to all 2MB cores. However, it is actually a cut down Conroe, as the article states :)
  5. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    hmm. would that imply that one might be able to hack the core and activate the remaining 2 mb cache on the older ones??
  6. Guest-23315
    Guest-23315 Guest
  7. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    You'd think they would have / Should have done this when they disabled that section :wallbash: Was there any reason for not doing it then?
  8. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    nice power characteristics.... might get one for my server, or to connect it to my tv as a media center.
    lets hope that C2D becomes revised and consumes less...
  9. Aankhen
    Aankhen What's a Dremel?
    15 Oct 2005
    Blast. Just a week or so after I bought mine.
    Yes, I know technology keeps moving on. You should, too. :p
  10. mclean007
    mclean007 Officious Bystander
    22 May 2003
    If you fancy taking off the heatspreader, pulling out your electron microscope and repairing a load of 65nm traces that have been burnt through with a laser, go ahead. And please remember to video the results and post in the forums. Kudos!
  11. specofdust
    specofdust Banned
    26 Feb 2005
    Seems like a simple update, but one which will save many people some money, good stuff.
    Oh btw, I scream, you scream, we all scream for a new intel image :-D
Tags: Add Tags
