RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 2nd Jan 2007, 16:01   #1
WilHarris
Just another nobody
WilHarris's Avatar
WilHarris is on a distinguished road
Vista activation cracked
http://www.bit-tech.net/news/2007/01...ation_cracked/
WilHarris is offline   Reply With Quote
Old 2nd Jan 2007, 16:02   #2
Nexxo
...like a geek!
Moderator
Nexxo's Avatar
Nexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud of
What, already?
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust
"There is no Real Life, only Away From Keyboard" --gpw111
"...my wife says I can't have any trolls, cause they argue with the dog and eat the fish" --KayinBlack
Nexxo is offline   Reply With Quote
Old 2nd Jan 2007, 16:09   #3
Buzzons
Mod Master
Buzzons is on a distinguished road
its not a crack, its just deactivating a timer -- and its already been fixed by MS (some blog went into details on technet somewhere)
they will be checking the regkeys for all windows updates now -- so if you do that, your updates wont work -- and you will not pass the WGA checks -- and get revoked back to the limited status... yay!
or.. just block all MS data out of your network on a hardware firewall and hope.
Buzzons is offline   Reply With Quote
Old 2nd Jan 2007, 16:17   #4
PA!N
Hypermodder
PA!N's Avatar
PA!N will become famous soon enough
Thats quite "old" news, as there are alreaddy numorus cracked and fully working versions of vista for over a month on the internet.
__________________
Originally Posted by Ramble View Post
So..what's the cup for Mankz?
Originally Posted by dom_ View Post
two girls
PA!N is offline   Reply With Quote
Old 2nd Jan 2007, 16:47   #5
quack
\o/
quack's Avatar
quack will become famous soon enough
I've experimented with this particular "crack" and while it does currently work (validates WGA/Windows Update), I'm sure that won't last for long. The registry value created is pretty obvious, at the moment anyway.
It doesn't actually activate Vista, just disables the timer that tells Vista to prompt the user to do so, and leaves it in the "Initial Grace Period". Microsoft will find it very simple to detect this, I'm sure.
Unfortunately I've not been able to do much else with the copy of Vista I got through MSDN since my PC isn't very well supported seeing as it's got an nForce2 chipset. Every time I try to install the official Nvidia drivers for my GeForce6 card, it bluescreens, and I can't get any more than 2 speaker audio which sucks.
I've seen more BSODs in Vista than I've ever seen with XP!
__________________
Denying Rights to Music lovers.
Denying Rights to Movie lovers.
quack is offline   Reply With Quote
Old 2nd Jan 2007, 17:18   #6
DXR_13KE
Madeira's banana is the best!!!
DXR_13KE's Avatar
DXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to behold
it will be completely hacked soon enough.... and have buckets of virus for it.
__________________
Renegade X - 0.40 Release! <---- CLICK!
DXR_13KE is offline   Reply With Quote
Old 2nd Jan 2007, 17:20   #7
TomH
Bwahahahahaha
TomH's Avatar
TomH is on a distinguished road
Doesn't the thought of MS being able to scan your registry, changing whatever they see fit, worry anyone anymore? I'm sure it does, but back in the '98 days this sort of behaviour from Microsoft was mainly myth and rumour.
Now they do it and [almost] everyone accepts it? You've paid for the damn software. Cha-ching, thank you, see you in '08 for Vista 2.
XP's activation was bad enough, but acceptable. If it's so easy to crack, the answer is to make it impossible to crack. Not to have you re-activate constantly whilst checking up to see if you've tried to re-engineer something. Doing so is only one step short of sending a lawyer around to look over your shoulder.
I'm still using an Abit NF7, so there's no chance I'll be upgrading, or at least anytime soon (student loan doesn't stretch to a new Core 2 system unfortunately ).
Ubuntu, dual-booted with XP Pro, is looking increasingly popular.
Might try rubuntu actually!
TomH is offline   Reply With Quote
Old 2nd Jan 2007, 17:45   #8
fev
Corporate Whore
fev's Avatar
fev will become famous soon enough
exploit's been given the green light at MS HQ
aka: well on the way to being fixed
__________________
I know what I'm doing... do you?
Follow me on Twitter..go on
fev is offline   Reply With Quote
Old 2nd Jan 2007, 19:18   #9
Cthippo
Can't mod my way out of a paper bag
Cthippo's Avatar
Cthippo is on a distinguished road
Let them update, the sword always defeats the shield in the end.
<snip>
Yes it does bother me and that's why I'm running linux. It's MY computer and I am the only one who says what goes on it, not MS, thank you.
Vista may be the greatest gift ever to the FOSS movement.
__________________
Notice: If we see you flaming we will assume you are on fire and take appropriate measures
- The Bit-Tech Fire Brigade.
Cthippo is offline   Reply With Quote
Old 2nd Jan 2007, 22:34   #10
HugoB
H to the U to the G to the O to the B
HugoB's Avatar
HugoB has a spectacular aura aboutHugoB has a spectacular aura aboutHugoB has a spectacular aura about
Yeah, cracked is the wrong word really, bipassed would be better methinks. Still, the point remains, the only working cracks are ones that will be redundant after the first update/service patch.
Roll on publically released buisiness activtion codes.
__________________
TrustedReviews.com - things I write about for a job
HugoB is offline   Reply With Quote
Old 2nd Jan 2007, 22:47   #11
quack
\o/
quack's Avatar
Those don't really help if you're after Ultimate. Plus you'll need a cracked KMS server for Business.
__________________
Old 3rd Jan 2007, 03:09   #12
metarinka
I *am* a Dremel
metarinka's Avatar
metarinka is on a distinguished road
I prefer to get my hardware the quasi legal way, ala major universities get bundle liscence deals where they give full liscences to students for $5 of course you can only buy one copy, I just found a student with a mac and viola a legit copy for $5. I'll do the same for vista when I feel the need to.
and bypasses will be a dime a dozen, it's more in the patch/upgrade path that whether or not the continue to work will be questioned
metarinka is offline   Reply With Quote
Old 3rd Jan 2007, 03:18   #13
Generic42
Supermodder
Generic42's Avatar
Generic42 is on a distinguished road
Why can MS just give up? Linux is totally free which is great, Mac OS is at least liked by it's users even if it does cost money, and no one in their right mind even likes or wants Windows... why don't they just conform? The world is changing and a corporate bully, essentially, is shoving everyone into their pocket so they can make money and screw over all of us who just want something that works like Windows. This isn't because it's the best OS, it's only because it's the richest.
And on the topic of Linux, it's far more versatile, accessible, powerful, and cheap. It'd be great if only there weren't two limiting factors: It's unsupported by anything commonly used, and it's bleeding hard to learn how to use all of it's power. Make Linux easy to use (already is with some distros I guess) and make it common and Windows is out of business. Same with the Mac OS probably, but I root for Linux over that...
I say good job hackers! Keep them on their toes! Show them that they can't control us and our PC use!
Generic42 is offline   Reply With Quote
Old 3rd Jan 2007, 03:29   #14
Firehed
Why not? I own a domain to match.
Firehed's Avatar
Firehed has a spectacular aura aboutFirehed has a spectacular aura aboutFirehed has a spectacular aura about
But will this let you pass WGA? The Chinese activation servers do (*cough* or so I've heard *cough*). I'm only running it to play around though - by and large, Windows is dead to me.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net
40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8
MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD
Firehed is offline   Reply With Quote
Old 3rd Jan 2007, 04:41   #15
OtakuHawk
Hypermodder
OtakuHawk is on a distinguished road
helloooo "Winborg Vista"
__________________
Ultra-Lurker
OtakuHawk is offline   Reply With Quote
Old 3rd Jan 2007, 06:20   #16
Tyinsar
6 screens / 1 card
Tyinsar's Avatar
Tyinsar is on a distinguished road
Once upon a time, before OSs Needed regular security updates, this would have been a bigger accomplishment. I suspect it will be an easy fix for MS.
Edit: Changed "great" to "a bigger accomplishment" since my original wording sounded like I condone piracy, which I don't.
__________________
It's not about how life treats you, it's about how you treat life.
Tyinsar is offline   Reply With Quote
Old 3rd Jan 2007, 06:50   #17
Gravemind123
avatar not found
Gravemind123 is on a distinguished road
It won't take long for hackers to get around all of this, as long as people can make security, people can break it!
__________________
E4400 - Asus P5B-Plus - Antec NeoHE 500 - 4GB OCZ SLI XTC - EVGA 8800GT - 250GB WD + 320GB Seagate
Lian-Li PC-61 - Zalman Cooling - Creative GigaWorks T20 - AG Neovo M-17
Dell XPS M1330 - T8300 - 4GB Ram - 8400M GS - 250GB HDD
Gravemind123 is offline   Reply With Quote
Old 3rd Jan 2007, 09:22   #18
scq
Hypermodder
scq's Avatar
scq is on a distinguished road
Psh - as if Microsoft is that swift in making software revisions (Vista?)
I know what you're getting at. I don't like the thought of my software calling home. Just like when I buy a video camera, I want to know it's not sending video back to the company.
scq is offline   Reply With Quote
Old 3rd Jan 2007, 09:36   #19
DougEdey
I pwn all your storage
DougEdey's Avatar
DougEdey is just really niceDougEdey is just really niceDougEdey is just really niceDougEdey is just really nice
I have no qualms with my Vista, it's legit.
I don't agree with calling back constantly however, thats just perverse.
I don't mind it if I do an update on security issues that Microsoft know how often I check for updates and how often I use my machine. If however they modify my registry I'll be angry.
*Goes off to make a registry monitor*
__________________
Burnout: Paradise Stats!XBL: DougEdey Bindi
PSN ID: DougEdey
Twitter
DougEdey is offline   Reply With Quote
Old 3rd Jan 2007, 18:15   #20
TomH
Bwahahahahaha
TomH's Avatar
A lot of analysts/journos have already speculated that Vista is going to mark a few changes in regards to Microsoft's development life cycle. They've spent billions on Vista and that's partly-due to how late it is.
And it's still not what they originally said it would be. Where's WinFS, for example?
I can see MS releasing another similar product in a few years. Think what Windows 98 was to Windows 95 -- similar, but with a few changes. Though with the added speculation of Vista's delayed mass-adoption, they might just shoot themselves in the foot.
But marketing aside, I don't think they want to wait another 5.5 years before a product release. Little and often is the way forward.
I'm sure there was an article on the Inq about it not so long ago, but I couldn't see it.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
