Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 3rd Jan 2007, 19:45   #1
Confused Fishcake
Hypermodder
Confused Fishcake's Avatar
Confused Fishcake has yet to learn the way of the Dremel
Remote Serial Console?
Hi all,
I have just managed to get an old B&W laptop, with no cd, no usb, no anything really. Windows 3.1 was running on it, I forgot the specs exactly, but they are pretty bad if the 80mb hard drive is anything to go by. I would like to use it as a serial console for a slightly better pc running xubuntu edgy. I don't know if my usage of serial console is correct, I basically want a bash shell running. I can easily make the null modem (?) cable required. The only possible issue is that I can only use a floppy to transfer files, so I might have to resort to something like a tomsrtbt floppy. I really have no idea as to the software side of things though
__________________
My Laptop: Inspiron 1501: Turion64 X2 TL-52 @ 1.6GHz, 1GB DDR2, 120GB SATA HD, 256Mb ATI 1150, 15.4" widescreen lcd, 8x DVD+/-RW, running Gentoo amd64.
My Server #1: Pentium III @ 500MHz, 192MB DDR, 290GB in total, running headless Gentoo x86.
My Server #2: Athlon 4 @ 1.7 GHz, 128MB DDR, 40GB, running headless Gentoo x86.
Confused Fishcake is offline   Reply With Quote
Old 3rd Jan 2007, 21:14   #2
Shagbag
All glory to the Hypnotoad!
Shagbag has yet to learn the way of the Dremel
Now THAT sounds like a challenge.
If you can boot it with a linux floppy distro and get it to talk to another, more powerful linux box you might be able to mount the 80MB hard drive from the second machine and install Damn Small Linux (50MB) on it. Achieving that could be your command line masterpiece.
__________________
Worth thinking about: do Firefox exploits affect non-Windows users?
Shagbag is offline   Reply With Quote
Reply
Tags
linux
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
