RSS
Old 8th Jan 2007, 14:15   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Shuttle SD37P2
http://www.bit-tech.net/hardware/200..._sd37p2/1.html
Tim S is offline   Reply With Quote
Old 8th Jan 2007, 14:26   #2
atanum141
I fapped to your post!
atanum141's Avatar
atanum141 is on a distinguished road
Top stuff, been awhile since i seen a shuttle.
__________________
Welcome to Thunderdome, B*tch
XBL: atanum141
atanum141 is online now   Reply With Quote
Old 8th Jan 2007, 14:27   #3
DougEdey
I pwn all your storage
DougEdey's Avatar
DougEdey is just really niceDougEdey is just really niceDougEdey is just really niceDougEdey is just really nice
Not too shabby performance for a smaller board. Could the shorter traces help with faster times d'ya think?
__________________
Burnout: Paradise Stats!XBL: DougEdey Bindi
PSN ID: DougEdey
Twitter
DougEdey is offline   Reply With Quote
Old 8th Jan 2007, 14:52   #4
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
Uh, not really because it's one electron in one electron out in any wire. But there will be less chance for crosstalk soooooooo less ECC corrections made? The 975x is better at sub 350 speeds anyway.
Bindibadgi is offline   Reply With Quote
Old 8th Jan 2007, 15:18   #5
Evenge
Supermodder
Evenge is on a distinguished road
Shuttle's are always cool! Nice that shuttle has put 4 ram slots in there!
__________________
We are human. After all.
Evenge is offline   Reply With Quote
Old 8th Jan 2007, 15:20   #6
DougEdey
DougEdey's Avatar
Less distance for the energy to pass between electrons, less signal loss aswell.
__________________
PSN ID: DougEdey
Twitter
Old 8th Jan 2007, 15:28   #7
DXR_13KE
Madeira's banana is the best!!!
DXR_13KE's Avatar
DXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to behold
small.... i like my computers big!!!!! but this one is cool.
__________________
Renegade X - 0.40 Release! <---- CLICK!
DXR_13KE is offline   Reply With Quote
Old 8th Jan 2007, 15:33   #8
PA!N
Hypermodder
PA!N's Avatar
PA!N will become famous soon enough
Mhhhhm so sexy that little black beauty...but to expensive for me.
Nice review of it
__________________
Originally Posted by Ramble View Post
So..what's the cup for Mankz?
Originally Posted by dom_ View Post
two girls
PA!N is offline   Reply With Quote
Old 8th Jan 2007, 17:00   #9
eddtox
Supermodder
eddtox is on a distinguished road
I'm with DXR.. It's a cool, sleek case, but i tend to prefer the big meaty monster which would give the world's strangest man a hernia if he tried to lift it... that being said, I'm sure it would make a pretty good media center pc with a bit of work.
-ed out
eddtox is offline   Reply With Quote
Old 8th Jan 2007, 17:04   #10
DeX
Mube Codder
DeX's Avatar
DeX is on a distinguished road
But what does it sound like? You forgot to mention how noisy or quiet it is.
Also, does it manage to run stably with a 8800GTS in there? Does the GTS even fit?
Oh and pleonasm alert: a cubic litre doesn't make sense. I think you mean litre.
Good review though. I've been wanting to find out more about this system.
__________________
Play my game: Shyguy's Cave of Death!
If you dont have the time to check your spelling and grammar, you dont have the time to post! -Liquid K9
DeX is offline   Reply With Quote
Old 8th Jan 2007, 17:09   #11
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
yea, should be just litres. I was working in cubic centimeters at the time. It's all so confusing.
Never tried it with a GTS, I only had a 7900GTX to hand over Christmas when I was using it, it'll fit a GTS just fine and a 400W PSU is more than powerful enough.
Im sure I mentioned noise, somewhere in there about keeping my hand warm as I played FEAR?? It's quiet as a mouse. I really really had to struggle to tell if it was on. Obviously the processor runs hotter than your normal case but it still keeps it stable as a rock under hours of load. The fan management is superb.
Old 8th Jan 2007, 18:51   #12
Sim0n
Ahhh Jimlad
Sim0n's Avatar
Sim0n is on a distinguished road
Test Setup:
Intel Core 2 Extreme X6800 (operating at 2.93GHz - 11x266); 2x 1GB Corsair XMS2-8500C5 (running at DDR2-800 in dual channel with 3.0-3-3-9 timings); BFGTech GeForce 7900 GTX OC video card (operating at 670/1640MHz); Seagate 7200.9 200GB 7200RPM SATA 3Gbps hard disk drive; OCZ GameXStream 700W power supply unit; Windows XP Professional Service Pack 2; DirectX 9.0c; NVIDIA Forceware 93.74WHQL.
Am i reading that right, you didnt use the shuttle PSU ??
Also, i cant see you mentioning heatlevels anywhere in the review, which im sure will be a key issue to anyone wanting to get one (like me)
Sim0n is offline   Reply With Quote
Old 8th Jan 2007, 19:51   #13
duc
Minimodder
duc is on a distinguished road
I believe the OCZ GameXStream PSU was used to power the other motherboards in the test. The SD37P2 (along other other P-series Shuttles) use a proprietary PSU connection, 2x 8pins and not 24pin atx.
According to the review posted on Sudhian CPU temps look pretty good (41c idle, 39c load). Can't find anywhere that shows temps when both CPU and GPU are loaded though.
duc is offline   Reply With Quote
Old 8th Jan 2007, 21:02   #14
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Originally Posted by Sim0n
Test Setup:
the GameXStream was used for the comparison boards.
Old 8th Jan 2007, 22:18   #15
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
I don't really see the point in temp readings if it's stable. I know they are a good reference but it's a Shuttle so it's going to be hotter than a normal system, but as long as it's below tdp and works it's not really an issue. Plus, what do you test with? A Prescott or Core 2? Passively cooled X1300 or 8800GTS? You could go on forever trying out any number of hardware scenarios.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
